Voici mon rapport
############################## | UsbFix V 7.150 | [Suppression]
Utilisateur: Bastian (Administrateur) # BABA
Mis à jour le 08/11/2013 par El Desaparecido - Team SosVirus
Lancé à 18:32:25 | 20/11/2013
Site Web :
https://www.usbfix.net
Forum :
https://www.sosvirus.net/
Upload Malware :
https://www.sosvirus.net/upload_malware.php
Contact :
https://www.usbfix.net/contact/
PC: Type2 - Board Vendor Name1 (Type2 - Board Product Name1)
CPU: Intel(R) Core(TM) i7-4700MQ CPU @ 2.40GHz
RAM -> [Total : 16136 | Free : 12800]
Bios: Insyde Corp.
OS: Microsoft Windows 8 (6.2.9200 64-Bit)
WB: Windows Internet Explorer : 10.0.9200.16736
WB: Mozilla Firefox : 25.0.1
AV: Windows Defender [(!) Disabled | Updated]
AS: Windows Defender : 4.3.0215.0
C:\ (%systemdrive%) -> Disque fixe # 918 Go (778 Go libre(s) - 85%) [TI31107200A] # NTFS
D:\ -> CD-ROM
F:\ -> Disque amovible # 4 Go (888 Mo libre(s) - 23%) [] # FAT32
Stoppé! C:\Program Files (x86)\Avira\AntiVir Desktop\sched.exe (ID: 1504 |ParentID: 704)
Stoppé! C:\Program Files (x86)\Avira\AntiVir Desktop\avguard.exe (ID: 1952 |ParentID: 704)
Stoppé! C:\Program Files (x86)\Avira\AntiVir Desktop\avshadow.exe (ID: 2988 |ParentID: 1952)
Stoppé! C:\Program Files (x86)\Avira\AntiVir Desktop\avwebg7.exe (ID: 3008 |ParentID: 704)
Stoppé! C:\Program Files\Toshiba\Hotkey\TCrdMain_Win8.exe (ID: 9788 |ParentID: 2284)
Stoppé! C:\Program Files (x86)\Avira\AntiVir Desktop\avgnt.exe (ID: 5504 |ParentID: 15464)
Stoppé! C:\Program Files\Intel\iCLS Client\HeciServer.exe (ID: 10460 |ParentID: 704)
Stoppé! C:\windows\explorer.exe (ID: 5304 |ParentID: 6924)
Stoppé! C:\Windows\System32\WUDFHost.exe (ID: 4540 |ParentID: 348)
Stoppé! C:\windows\system32\DllHost.exe (ID: 10148 |ParentID: 820)
Stoppé! C:\windows\system32\SearchIndexer.exe (ID: 7960 |ParentID: 704)
Stoppé! C:\windows\System32\spoolsv.exe (ID: 5844 |ParentID: 704)
Stoppé! C:\Users\Bastian\AppData\Roaming\Spotify\Spotify.exe (ID: 6408 |ParentID: 12200)
Stoppé! C:\Users\Bastian\AppData\Roaming\Spotify\Data\SpotifyHelper.exe (ID: 15080 |ParentID: 6408)
Stoppé! C:\Users\Bastian\AppData\Roaming\Spotify\Data\SpotifyHelper.exe (ID: 4420 |ParentID: 6408)
Stoppé! C:\Users\Bastian\AppData\Roaming\Spotify\Data\SpotifyHelper.exe (ID: 12696 |ParentID: 6408)
Stoppé! C:\Users\Bastian\AppData\Roaming\Spotify\Data\SpotifyHelper.exe (ID: 9568 |ParentID: 6408)
Stoppé! C:\Users\Bastian\AppData\Roaming\Spotify\Data\SpotifyHelper.exe (ID: 16368 |ParentID: 6408)
Stoppé! C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe (ID: 12340 |ParentID: 704)
Stoppé! C:\windows\system32\dashost.exe (ID: 7132 |ParentID: 348)
Stoppé! C:\Program Files\WindowsApps\microsoft.windowscommunicationsapps_16.4.4406.1205_x64__8wekyb3d8bbwe\LiveComm.exe (ID: 184 |ParentID: 820)
Stoppé! C:\Windows\System32\RuntimeBroker.exe (ID: 10596 |ParentID: 820)
Stoppé! C:\windows\SysWOW64\NOTEPAD.EXE (ID: 3868 |ParentID: 13468)
Stoppé! C:\Program Files (x86)\Mozilla Firefox\firefox.exe (ID: 10336 |ParentID: 5304)
Stoppé! C:\Program Files (x86)\Mozilla Firefox\plugin-container.exe (ID: 756 |ParentID: 10336)
Stoppé! C:\windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_11_9_900_117.exe (ID: 4288 |ParentID: 756)
Stoppé! C:\windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_11_9_900_117.exe (ID: 7276 |ParentID: 4288)
Stoppé! C:\windows\system32\wwahost.exe (ID: 11756 |ParentID: 820)
Stoppé! C:\windows\syswow64\wwahost.exe (ID: 1500 |ParentID: 820)
Stoppé! C:\Program Files (x86)\Movies Toolbar\SafetyNut\SafetyNutManager.exe (ID: 1476 |ParentID: 704)
Stoppé! C:\Program Files (x86)\Movies Toolbar\SafetyNut\SafetyNutManager.exe (ID: 5412 |ParentID: 1476)
Stoppé! C:\Program Files (x86)\Movies Toolbar\SafetyNut\safetynut.exe (ID: 5424 |ParentID: 1476)
04 - HKLM\SOFTWARE | Run : [Intel AppUp(R) center] - "C:\Program Files (x86)\Intel\IntelAppStore\bin\ismagent.exe" --domain-id F0399437-FD0C-4A48-B101-F0314A6172E4
04 - HKLM\SOFTWARE | Run : [TSVU] - "c:\Program Files\TOSHIBA\TOSHIBA Smart View Utility\TosSmartViewLauncher.exe"
04 - HKLM\SOFTWARE | Run : [APSDaemon] - "C:\Program Files (x86)\Common Files\Apple\Apple Application Support\APSDaemon.exe"
04 - HKLM\SOFTWARE | Run : [iTunesHelper] - "C:\Program Files (x86)\iTunes\iTunesHelper.exe"
04 - HKLM\SOFTWARE | Run : [SwitchBoard] - C:\Program Files (x86)\Common Files\Adobe\SwitchBoard\SwitchBoard.exe
04 - HKLM\SOFTWARE | Run : [AdobeCS6ServiceManager] - "C:\Program Files (x86)\Common Files\Adobe\CS6ServiceManager\CS6ServiceManager.exe" -launchedbylogin
04 - HKLM\SOFTWARE | Run : [Adobe Acrobat Speed Launcher] - "C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\Acrobat_sl.exe"
04 - HKLM\SOFTWARE | Run : [Acrobat Assistant 8.0] - "C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\Acrotray.exe"
04 - HKLM\SOFTWARE | Run : [avgnt] - "C:\Program Files (x86)\Avira\AntiVir Desktop\avgnt.exe" /min
04 - HKLM\SOFTWARE | Run : [ApnTBMon] - "C:\Program Files (x86)\AskPartnerNetwork\Toolbar\Updater\TBNotifier.exe"
04 - HKLM\SOFTWARE\wow6432Node | Run : [Intel AppUp(R) center] - "C:\Program Files (x86)\Intel\IntelAppStore\bin\ismagent.exe" --domain-id F0399437-FD0C-4A48-B101-F0314A6172E4
04 - HKLM\SOFTWARE\wow6432Node | Run : [TSVU] - "c:\Program Files\TOSHIBA\TOSHIBA Smart View Utility\TosSmartViewLauncher.exe"
04 - HKLM\SOFTWARE\wow6432Node | Run : [APSDaemon] - "C:\Program Files (x86)\Common Files\Apple\Apple Application Support\APSDaemon.exe"
04 - HKLM\SOFTWARE\wow6432Node | Run : [iTunesHelper] - "C:\Program Files (x86)\iTunes\iTunesHelper.exe"
04 - HKLM\SOFTWARE\wow6432Node | Run : [SwitchBoard] - C:\Program Files (x86)\Common Files\Adobe\SwitchBoard\SwitchBoard.exe
04 - HKLM\SOFTWARE\wow6432Node | Run : [AdobeCS6ServiceManager] - "C:\Program Files (x86)\Common Files\Adobe\CS6ServiceManager\CS6ServiceManager.exe" -launchedbylogin
04 - HKLM\SOFTWARE\wow6432Node | Run : [] -
04 - HKLM\SOFTWARE\wow6432Node | Run : [Adobe Acrobat Speed Launcher] - "C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\Acrobat_sl.exe"
04 - HKLM\SOFTWARE\wow6432Node | Run : [Acrobat Assistant 8.0] - "C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\Acrotray.exe"
04 - HKLM\SOFTWARE\wow6432Node | Run : [avgnt] - "C:\Program Files (x86)\Avira\AntiVir Desktop\avgnt.exe" /min
04 - HKLM\SOFTWARE\wow6432Node | Run : [ApnTBMon] - "C:\Program Files (x86)\AskPartnerNetwork\Toolbar\Updater\TBNotifier.exe"
04 - HKU\S-1-5-21-2314414145-2179725052-4188640036-1002\SOFTWARE | Run : [Akamai NetSession Interface] - "C:\Users\Bastian\AppData\Local\Akamai\netsession_win.exe"
04 - HKU\S-1-5-21-2314414145-2179725052-4188640036-1002\SOFTWARE | Run : [AdobeBridge] -
Supprimé! F:\.lnk
Supprimé! F:\ROBOT.lnk
Supprimé! F:\template.lnk
Supprimé! F:\formu.lnk
Supprimé! F:\maison3D.lnk
Supprimé! F:\WMPInfo.lnk
Supprimé! F:\~WRL2580.lnk
Supprimé! F:\.Spotlight-V100.lnk
Supprimé! F:\.Trashes.lnk
Supprimé! F:\IMAGESmaj.lnk
Supprimé! F:\Fichier HDD sur clé.lnk
Supprimé! F:\ex1-css.lnk
Supprimé! F:\TUTO ROBOT.lnk
Supprimé! F:\Bab création page web.lnk
Supprimé! F:\.mayaSwatches.lnk
Supprimé! F:\Keyboard.lnk
Supprimé! F:\CI2D - PS1.lnk
Supprimé! F:\Clé USB.lnk
Supprimé! F:\2191-Jimmy Havenith.lnk
Supprimé! F:\2191-BOUCHAT-BASTIAN.lnk
Supprimé! F:\PDF.lnk
Supprimé! F:\GABARITS.lnk
Supprimé! F:\Nouveau dossier.lnk
Supprimé! C:\Users\Bastian\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\iTunesHelper.vbe
Supprimé! C:\Users\Bastian\AppData\Local\Temp\utt3FC3.tmp.exe
Supprimé! C:\Users\Bastian\AppData\Local\Temp\iTunesHelper.vbe
Supprimé! F:\iTunesHelper.vbe
Md5 : 32BEF3BB4B558ADE6CF41113628FC86D -> C:\Users\Bastian\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\iTunesHelper.vbe
Md5 : 32BEF3BB4B558ADE6CF41113628FC86D -> C:\Users\Bastian\AppData\Local\Temp\iTunesHelper.vbe
Md5 : 32BEF3BB4B558ADE6CF41113628FC86D -> F:\iTunesHelper.vbe
[11/10/2013 - 15:46:09 | SHD ] C:\$RECYCLE.BIN
[13/10/2013 - 19:23:33 | D ] C:\Autodesk
[26/07/2012 - 04:44:30 | RAS | 398156] C:\bootmgr
[02/06/2012 - 15:30:55 | N | 1] C:\BOOTNXT
[26/07/2012 - 08:22:08 | SHD ] C:\Documents and Settings
[15/11/2013 - 09:27:57 | ASH | 13536083968] C:\hiberfil.sys
[02/08/2013 - 16:00:55 | D ] C:\Intel
[15/11/2013 - 09:27:59 | ASH | 2415919104] C:\pagefile.sys
[26/07/2012 - 08:33:46 | D ] C:\PerfLogs
[10/11/2013 - 12:50:33 | D ] C:\Program Files
[18/11/2013 - 12:25:31 | D ] C:\Program Files (x86)
[11/11/2013 - 09:48:21 | D ] C:\ProgramData
[13/10/2013 - 19:29:10 | D ] C:\sources
[15/11/2013 - 09:28:00 | ASH | 268435456] C:\swapfile.sys
[18/11/2013 - 21:44:05 | SHD ] C:\System Volume Information
[06/05/2013 - 21:12:59 | D ] C:\Toshiba
[20/11/2013 - 18:33:14 | D ] C:\UsbFix
[20/11/2013 - 18:33:18 | A | 9869] C:\UsbFix [Clean 2] BABA.txt
[12/11/2013 - 19:51:33 | N | 9927] C:\UsbFix [Scan 3] BABA.txt
[20/11/2013 - 18:17:30 | N | 14587] C:\UsbFix [Scan 4] BABA.txt
[11/10/2013 - 15:37:46 | RD ] C:\Users
[16/10/2013 - 14:43:22 | D ] C:\Windows
[26/11/2011 - 11:45:58 | SD ] F:\.Spotlight-V100
[14/04/2010 - 20:19:40 | SD ] F:\.Trashes
[14/04/2010 - 20:19:40 | S | 4096] F:\._.Trashes
[17/04/2010 - 18:33:46 | N | 6148] F:\.DS_Store
[05/11/2013 - 10:19:16 | N | 695904] F:\ROBOT.mb
[24/01/2012 - 13:34:44 | N | 4096] F:\._Boom.mov
[26/02/2013 - 20:18:36 | D ] F:\Fichier HDD sur clé
[24/01/2012 - 13:34:42 | N | 4096] F:\._Montaigle.mov
[31/03/2012 - 14:08:00 | N | 4096] F:\._Rusko - 2012 - Songs
[14/04/2012 - 12:57:02 | N | 4096] F:\._FLASHMOB.mp4
[21/10/2013 - 14:15:02 | N | 527527] F:\ROBOT.pdf
[31/03/2012 - 14:08:16 | N | 4096] F:\._Featurecast - EP Mini Mix.mp3
[24/10/2013 - 10:14:08 | N | 317172] F:\maison3D.mb
[22/10/2013 - 08:30:10 | D ] F:\IMAGESmaj
[25/10/2013 - 15:29:38 | D ] F:\ex1-css
[24/09/2013 - 08:52:52 | D ] F:\TUTO ROBOT
[18/10/2013 - 08:31:20 | D ] F:\Bab création page web
[01/10/2013 - 10:18:12 | D ] F:\.mayaSwatches
[01/10/2013 - 10:18:30 | D ] F:\Keyboard
[25/10/2013 - 14:17:00 | N | 2565] F:\template.html
[18/10/2013 - 15:31:06 | N | 2574] F:\formu.html
[18/10/2013 - 15:32:24 | N | 4096] F:\._formu.html
[25/10/2013 - 14:18:10 | N | 4096] F:\._template.html
[04/10/2013 - 10:20:58 | N | 94722] F:\._Bouchat Bastian exercice 1.psd
[04/10/2013 - 10:21:52 | D ] F:\CI2D - PS1
[07/11/2013 - 08:35:46 | D ] F:\2191-Jimmy Havenith
[07/11/2013 - 08:43:48 | D ] F:\2191-BOUCHAT-BASTIAN
[30/09/2013 - 07:37:12 | D ] F:\PDF
[30/09/2013 - 07:37:10 | D ] F:\GABARITS
[07/11/2013 - 16:29:02 | D ] F:\Nouveau dossier
[25/10/2008 - 20:26:08 | N | 296] F:\WMPInfo.xml
[16/05/2009 - 15:46:50 | N | 2206720] F:\~WRL2580.tmp
[07/06/2011 - 20:56:30 | D ] F:\Clé USB
################## | E.O.F |
https://www.usbfix.net -
https://www.sosvirus.net |
