#18638
Désinstalle :
Adobe Flash Player
Adobe Reader
Java (toutes si il y en a plusieurs)
SweetIM (Si tu le trouve dans la liste)
Met à  jours les 3 :
https://get.adobe.com/fr/flashplayer/
https://get.adobe.com/fr/reader/
https://www.java.com/fr/download/
    G2 - GCE: Preference [User Data\Default] [jcdgjdiieiljkfkdcloehkohchhpekkn] SweetIM for Facebook v.1.0.0.0 (Activé) =>PUP.SweetIM
    O4 - HKCU\..\Run: [msnmsgr] ~"C:\Program Files\Windows Live\Messenger\msnmsgr.exe (.not file.)
    O4 - HKUS\S-1-5-21-979085209-3591522650-3062641118-1001\..\Run: [msnmsgr] ~"C:\Program Files\Windows Live\Messenger\msnmsgr.exe (.not file.)
    O51 - MPSK:{9a8ea266-37c7-11e1-85e3-1c7508e7e67b}\AutoRun\command - Clé orpheline
    O69 - SBI: SearchScopes [HKCU] {B7DA11D2-D361-4C26-AFF3-76F86003558C} - (Ask Search) - https://websearch.ask.com =>Toolbar.Ask
    O87 - FAEL: "{B08F7C44-DB04-4054-8CE8-926732D17945}" |In - Private - P6 - TRUE | .(...) -- C:\Program Files\SweetIM\Communicator\SweetPacksUpdateManager.exe (.not file.) =>PUP.SweetIM
    O87 - FAEL: "{97C84A59-14EE-4C18-BC19-EE5B7AAF2372}" |In - Private - P17 - TRUE | .(...) -- C:\Program Files\SweetIM\Communicator\SweetPacksUpdateManager.exe (.not file.) =>PUP.SweetIM
    O90 - PUC: "16FE85B52F587794795A481CF9295697" . (.SweetPacks Toolbar for Internet Explorer 4.5.) -- C:\Windows\Installer\{5B58EF61-85F2-4977-97A5-84C19F926579}\ARPPRODUCTICON.exe =>PUP.SweetIM
    O90 - PUC: "9FEB8FB96CD4CF54A95AB4311193C2DA" . (.Boxore Client.) -- C:\Windows\Installer\{9BF8BEF9-4DC6-45FC-9AA5-4B1311392CAD}\boxore.ico =>Adware.Boxore
    C:\ProgramData\boost_interprocess
    [HKLM\Software\Google\Chrome\Extensions\jcdgjdiieiljkfkdcloehkohchhpekkn]   =>PUP.SweetIM^
    [HKCU\Software\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{A5AA24EA-11B8-4113-95AE-9ED71DEAF12A}]   =>Toolbar.Ask
    [HKLM\Software\Classes\Installer\Features\16FE85B52F587794795A481CF9295697]   =>PUP.SweetIM
    [HKLM\Software\Classes\Installer\Products\16FE85B52F587794795A481CF9295697]   =>PUP.SweetIM
    [HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\16FE85B52F587794795A481CF9295697]   =>PUP.SweetIM
    [HKLM\Software\Classes\Installer\Features\758F5690DAAD39F40845E0E23C8C5C0B]   =>PUP.SweetIM
    [HKLM\Software\Classes\Installer\Products\758F5690DAAD39F40845E0E23C8C5C0B]   =>PUP.SweetIM
    [HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\758F5690DAAD39F40845E0E23C8C5C0B]   =>PUP.SweetIM
    [HKLM\SOFTWARE\SOFTWARE\UPDATE\CLIENTS\{5B54E9B6-D6C4-11E0-8E9D-92FB4824019B}]   =>Adware.Boxore
    [HKLM\Software\Classes\Installer\Features\9FEB8FB96CD4CF54A95AB4311193C2DA]   =>Adware.Boxore
    [HKLM\Software\Classes\Installer\Products\9FEB8FB96CD4CF54A95AB4311193C2DA]   =>Adware.Boxore
    [HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\9FEB8FB96CD4CF54A95AB4311193C2DA]   =>Adware.Boxore
    [HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\0FF2AEFF45EEA0A48A4B33C1973B6094]   =>PUP.SweetIM^
    [HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\305B09CE8C53A214DB58887F62F25536]   =>PUP.SweetIM^
    C:\Users\nie\AppData\Local\Google\Chrome\User Data\Default\Extensions\jcdgjdiieiljkfkdcloehkohchhpekkn   =>PUP.SweetIM^
    C:\Users\nie\AppData\Local\Software   =>Adware.Boxore
    C:\Windows\Installer\cb3fda8.msi   =>Adware.Boxore^
    EmptyCLSID
    Emptytemp
par francky
#18790
j'ai bien supprimé les 2 adobe + java , mais impossible de les réinstaller :unhappy:
#18846
Applique le script ZHPFix, transmet moi le rapport, puis redémarre et retente les installations adobe et java stp.
par francky
#18883
:hello:
Pour java c'est tout bon :bravo1:
Pour Adobe , j'ai ce message : la connexion a échoué , impossible de terminer l'installation :unhappy:
Francky
par francky
#18890
Beaucoup mieux, plus rien à  voir depuis que tu l'as pris en main ;)
c'est un plaisir de l'utiliser
