Scan USBfix Réparation PC
par axis80
#3352
Alors je voudrais savoir si la clé USB d'1 ami est saine, quelle est/sont la/les meilleure/s facon/s de la controler ?
Je colle le rapport USBfix :
############################## | UsbFix V 7.123 | [Listing]
Utilisateur: Jork'n9 (Administrateur) # JORKEN9-SAUREMO
Mis à  jour le 19/04/2013 par El Desaparecido
Lancé à  14:44:14 | 21/04/2013
Site Web: https://sosvirus.org/
Upload Malware: https://upload.sosvirus.org/
Contact: contact@sosvirus.org
PC: NVIDIA (AWRDACPI) (X86-based PC)
CPU: AMD Athlon(tm) (1670)
RAM -> [Total : 2047 | Free : 1494]
BIOS: Phoenix - AwardBIOS v6.00PG
BOOT: Normal boot
OS: Microsoft Windows XP à‰dition familiale (5.1.2600 32-Bit) # Service Pack 2
WB: Windows Internet Explorer 8.0.6001.18702
SC: Security Center Service [(!) Disabled]
C:\ (%systemdrive%) -> Disque fixe # 78 Go (12 Go libre(s) - 15%) [] # NTFS
D:\ -> Disque fixe # 36 Go (9 Go libre(s) - 24%) [] # NTFS
E:\ -> CD-ROM
F:\ -> Disque amovible # 8 Go (2 Go libre(s) - 26%) [] # FAT32
[30/07/2010 - 20:55:25 | D ] C:\8bf81479916b8ab4f196b46e
[04/01/2013 - 12:32:15 | A | 9540] C:\AdwCleaner[R1].txt
[13/01/2013 - 12:50:54 | A | 1091] C:\AdwCleaner[R2].txt
[04/01/2013 - 12:34:05 | A | 9683] C:\AdwCleaner[S1].txt
[15/10/2012 - 12:20:21 | D ] C:\Animagic
[29/05/2009 - 22:50:57 | A | 0] C:\AUTOEXEC.BAT
[04/02/2013 - 13:27:09 | AD ] C:\b3
[13/07/2010 - 11:06:59 | A | 216] C:\Boot.bak
[26/12/2012 - 12:44:53 | RASH | 286] C:\boot.ini
[28/08/2001 - 16:00:00 | RASH | 4952] C:\Bootfont.bin
[30/07/2010 - 13:59:08 | RASHD ] C:\cmdcons
[03/08/2004 - 23:00:08 | A | 263488] C:\cmldr
[20/04/2013 - 18:35:56 | D ] C:\Config.Msi
[29/05/2009 - 22:50:57 | A | 0] C:\CONFIG.SYS
[15/09/2012 - 16:55:05 | D ] C:\Documents and Settings
[26/02/2013 - 14:52:23 | D ] C:\Dossier inconnu
[08/11/2009 - 12:02:08 | A | 120] C:\drmHeader.bin
[21/04/2013 - 13:49:54 | A | 2699804] C:\git_shell_ext_debug.txt
[29/05/2009 - 22:50:57 | RASH | 0] C:\IO.SYS
[27/03/2012 - 14:51:22 | D ] C:\MinGW
[29/05/2009 - 22:50:57 | RASH | 0] C:\MSDOS.SYS
[28/03/2011 - 16:36:15 | D ] C:\msysgit
[18/11/2010 - 18:46:37 | A | 113826] C:\MTC_00.bmp
[30/05/2009 - 12:55:07 | RASH | 47564] C:\NTDETECT.COM
[30/05/2009 - 12:55:07 | RASH | 251712] C:\ntldr
[13/03/2013 - 16:06:52 | D ] C:\NV12962164.TMP
[13/03/2013 - 16:06:52 | D ] C:\NV31043236.TMP
[13/03/2013 - 16:06:54 | D ] C:\NV38963908.TMP
[13/03/2013 - 16:06:54 | D ] C:\NV7803444.TMP
[13/03/2013 - 16:05:46 | D ] C:\NVIDIA
[21/04/2013 - 10:47:27 | ASH | 2146942976] C:\pagefile.sys
[20/04/2013 - 18:35:55 | RD ] C:\Program Files
[13/10/2012 - 16:32:57 | D ] C:\Q3Map2Build
[10/07/2011 - 13:58:26 | A | 377970] C:\Q3Map2Build.zip
[26/12/2012 - 12:38:59 | SHD ] C:\RECYCLER
[13/03/2013 - 16:01:37 | SHD ] C:\System Volume Information
[21/04/2013 - 13:34:57 | A | 449] C:\TCleaner.txt
[24/03/2012 - 12:49:51 | D ] C:\temp
[21/04/2013 - 14:44:15 | D ] C:\UsbFix
[21/04/2013 - 14:44:15 | A | 2942] C:\UsbFix [Listing 1 ] JORKEN9-SAUREMO.txt
[21/04/2013 - 14:12:46 | A | 3162] C:\UsbFix [Scan 2] JORKEN9-SAUREMO.txt
[16/03/2011 - 10:32:29 | D ] C:\wamp
[17/04/2013 - 16:19:44 | A | 59] C:\wepkeys.txt
[21/04/2013 - 13:51:32 | D ] C:\WINDOWS
[30/07/2010 - 17:01:05 | A | 880] C:\ZHPExportRegistry-30-07-2010-17-01-05.txt
[02/02/2013 - 16:50:10 | D ] D:\AVSVideoEditor
[06/11/2012 - 13:19:41 | D ] D:\FFOutput
[12/02/2013 - 12:22:59 | D ] D:\JEUX
[28/02/2013 - 14:01:34 | D ] D:\Recup Photos
[12/03/2013 - 14:14:54 | D ] D:\Recup Videos
[26/12/2012 - 12:38:59 | SHD ] D:\RECYCLER
[30/07/2010 - 14:34:40 | SHD ] D:\System Volume Information
[17/02/2012 - 12:32:10 | D ] D:\Urt-Vidéos
[25/02/2013 - 14:52:21 | D ] D:\Urt-Vidéos 2
[30/03/2012 - 12:05:02 | D ] D:\VIDEOS
[08/07/2010 - 11:08:00 | AH | 4096] F:\._.Trashes
[08/07/2010 - 11:08:00 | HD ] F:\.Trashes
[08/07/2010 - 11:08:00 | HD ] F:\.Spotlight-V100
[08/07/2010 - 11:08:00 | HD ] F:\.fseventsd
[17/07/2012 - 19:04:24 | A | 525] F:\Raccourci vers WALL-E.2008.TRUEFRENCH.720p.BluRay.x264.AC3-WHATELSE.lnk
[19/01/2012 - 19:35:32 | A | 725468258] F:\Les Tuche.avi
[25/04/2012 - 23:29:12 | A | 537294934] F:\Les.Hommes.Viennent.De.Mars.Les.Femmes.De.Venus.FRENCH.DVDRiP.DiVX.avi
[01/01/2007 - 12:31:00 | A | 732665086] F:\l'age de glace 2- Divx Francais - DVD RIP.AVI
[16/11/2011 - 19:34:22 | A | 734308352] F:\Scooby-Doo et le monstre du Loch Ness.avi
[14/12/2011 - 21:28:20 | A | 733802496] F:\Les Schtrumphs - 2011 [DVDRIP].avi
[19/04/2013 - 16:35:44 | D ] F:\Navigateurs Web
[16/11/2010 - 00:40:10 | A | 739436544] F:\La_Belle_et_le_Clochard.avi
[15/12/2011 - 16:21:28 | A | 524263424] F:\Lego Ninjago Le Film.DvDRIP.?Asia666?.avi
[04/12/2011 - 22:28:54 | A | 733048832] F:\Niko Le Petit Renne.DvDRIP.?Asia666?.avi
[19/04/2013 - 16:39:34 | D ] F:\Net Fix programes
[16/04/2013 - 14:07:18 | D ] F:\Dell latitude d600
[18/04/2013 - 14:55:40 | D ] F:\Antivirus cleaners
################## | E.O.F |
#3409
Hello,
:welcome:
Cette clé semble propre ;)
Tu peux aussi la scanner avec ton antivirus. Va dans poste de travail -> clic droit sur la clé , choisi scanner avec ton antivirus .
