Re
Je m'en doutais un peu, tu as rechopé un Moteur de Recheche, via tes clics sur le Web !!!
Applique correctif avec ZHPFix =>
* Dans la fenêtre qui s'ouvre, valide par "
OK "
Code : Tout sélectionnerO69 - SBI: prefs.js [coulondre - xgscu74z.default-1365244550937] user_pref("extensions.delta.admin", false); => Toolbar.DeltaSearch)*
O69 - SBI: prefs.js [coulondre - xgscu74z.default-1365244550937] user_pref("extensions.delta.aflt", "babsst"); => Toolbar.DeltaSearch)*
O69 - SBI: prefs.js [coulondre - xgscu74z.default-1365244550937] user_pref("extensions.delta.appId", "{C26644C4-2A12-4CA6-8F2E-0EDE6CF018F3}"); => Toolbar.DeltaSearch)*
O69 - SBI: prefs.js [coulondre - xgscu74z.default-1365244550937] user_pref("extensions.delta.autoRvrt", "false"); => Toolbar.DeltaSearch)*
O69 - SBI: prefs.js [coulondre - xgscu74z.default-1365244550937] user_pref("extensions.delta.dfltLng", "en"); => Toolbar.DeltaSearch)*
O69 - SBI: prefs.js [coulondre - xgscu74z.default-1365244550937] user_pref("extensions.delta.excTlbr", false); => Toolbar.DeltaSearch)*
O69 - SBI: prefs.js [coulondre - xgscu74z.default-1365244550937] user_pref("extensions.delta.ffxUnstlRst", true); => Toolbar.DeltaSearch)*
O69 - SBI: prefs.js [coulondre - xgscu74z.default-1365244550937] user_pref("extensions.delta.id", "e8513531000000000000000fea559a61"); => Toolbar.DeltaSearch)*
O69 - SBI: prefs.js [coulondre - xgscu74z.default-1365244550937] user_pref("extensions.delta.instlDay", "15810"); => Toolbar.DeltaSearch)*
O69 - SBI: prefs.js [coulondre - xgscu74z.default-1365244550937] user_pref("extensions.delta.instlRef", "sst"); => Toolbar.DeltaSearch)*
O69 - SBI: prefs.js [coulondre - xgscu74z.default-1365244550937] user_pref("extensions.delta.newTab", false); => Toolbar.DeltaSearch)*
O69 - SBI: prefs.js [coulondre - xgscu74z.default-1365244550937] user_pref("extensions.delta.prdct", "delta"); => Toolbar.DeltaSearch)*
O69 - SBI: prefs.js [coulondre - xgscu74z.default-1365244550937] user_pref("extensions.delta.prtnrId", "delta"); => Toolbar.DeltaSearch)*
O69 - SBI: prefs.js [coulondre - xgscu74z.default-1365244550937] user_pref("extensions.delta.rvrt", "false"); => Toolbar.DeltaSearch)*
O69 - SBI: prefs.js [coulondre - xgscu74z.default-1365244550937] user_pref("extensions.delta.smplGrp", "none"); => Toolbar.DeltaSearch)*
O69 - SBI: prefs.js [coulondre - xgscu74z.default-1365244550937] user_pref("extensions.delta.tlbrId", "base"); => Toolbar.DeltaSearch)*
O69 - SBI: prefs.js [coulondre - xgscu74z.default-1365244550937] user_pref("extensions.delta.tlbrSrchUrl", ""); => Toolbar.DeltaSearch)*
O69 - SBI: prefs.js [coulondre - xgscu74z.default-1365244550937] user_pref("extensions.delta.vrsn", "1.8.16.16"); => Toolbar.DeltaSearch)*
O69 - SBI: prefs.js [coulondre - xgscu74z.default-1365244550937] user_pref("extensions.delta.vrsnTs", "1.8.16.1610:01:47"); => Toolbar.DeltaSearch)*
O69 - SBI: prefs.js [coulondre - xgscu74z.default-1365244550937] user_pref("extensions.delta.vrsni", "1.8.16.16"); => Toolbar.DeltaSearch)*
O69 - SBI: SearchScopes [HKCU] ${searchCLSID} - (Bing) - https://www.bing.com => bing.com
O69 - SBI: SearchScopes [HKCU] {0633EE93-D776-472f-A0FF-E1416B8B2E3A} - (@ieframe.dll,-12512) - https://www.bing.com => bing.com
O69 - SBI: SearchScopes [HKCU] {6A1806CD-94D4-4689-BA73-E35EA1EA9990} - (@ieframe.dll,-12512) - https://www.bing.com => bing.com
[MD5.F455684D93F9091B95B60D8E14ECA5E0] [SPRF][23/05/2012] (.scochran@chattanooga.net - DBXtract version 4.50.) -- C:\Program Files\DBXtract.exe [73728]
EmptyCLSID
Emptytemp
Clique sur le bouton
Presse-papier encadré en rouge sur l'image.
GO en bas à gauche.
Puis ZHPFix se relance, il faudra à nouveau cliquer sur le bouton "Presse-papier" pour coller les lignes, puis sur le bouton "GO"
Une fois le résultat affiché, clique sur la croix rouge pour refermer l'outil (en haut à doite).
Le rapport se trouve aussi à cet emplacement => C:\ZHP\ZHPFix.txt
