RAPPORT USBFIX Réparation PC
par Hatha Taisho
#4087
Rapport R1
Rapport de ZHPFix 2013.5.11.1 par Nicolas Coolman, Update du 11/05/2013
Fichier d'export Registre :
Run by Boo at 20/05/2013 19:07:21
High Elevated Privileges : OK
Windows 7 Home Basic Edition, 64-bit Service Pack 1 (Build 7601)
Corbeille vidée
SUPPRIME Key*: HKLM\Software\HAL7600
SUPPRIME Key*: HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\482AA67AD25E6E74E9F48BD5FBE8533C
SUPPRIME Key*: HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\29799DE249E7DBC459FC6C8F07EB8375
SUPPRIME Key*: HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\0238BBE24EA3A70408B81E4BB89C15E5
SUPPRIME Key: HKLM\Software\Classes\Installer\Features\A9E0FC7FB84D2494597352E90D65D84F
SUPPRIME Key: HKLM\Software\Classes\Installer\Products\A9E0FC7FB84D2494597352E90D65D84F
SUPPRIME Key*: HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\A9E0FC7FB84D2494597352E90D65D84F
ABSENT Key: HKLM\Software\Wow6432Node\Classes\Installer\Features\A9E0FC7FB84D2494597352E90D65D84F
ABSENT Key: HKLM\Software\Wow6432Node\Classes\Installer\Products\A9E0FC7FB84D2494597352E90D65D84F
SUPPRIME Key*: HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UpgradeCodes\F1057DD419AED0B468AD8888429E139A
ABSENT Key: \Software\Classes\Installer\Products\\A9E0FC7FB84D2494597352E90D65D84F
SUPPRIME Key: Service: McComponentHostService
========== Valeur(s) du Registre ==========
SUPPRIME {5FF1BD56-B644-491D-BE35-6BF7DC7D795A}
SUPPRIME {2C84D825-E4C3-430C-9A04-4A206B4F0B3A}
ABSENT Folder Chrome: C:\Users\Boo\AppData\Local\Google\Chrome\User Data\Default\Extensions\igdhbblpcellaljokkpfhcjlagemhgjl
SUPPRIME Temporaires Windows
SUPPRIME Flash Cookies
SUPPRIME File: c:\users\boo\appdata\roaming\microsoft\internet explorer\quick launch\vuze.lnk
SUPPRIME File: c:\program files (x86)\vuze\azureus.exe
12 : Clé(s) du Registre
2 : Valeur(s) du Registre
3 : Dossier(s)
4 : Fichier(s)
1 : Préférences navigateur
End of clean in 00mn 08s
C:\ZHP\ZHPFix[R1].txt - 20/05/2013 19:07:22 [2429]
Rapport R2
Fichier d'export Registre : C:\ZHP\ZHPExportRegistry-20-05-2013-19-07-22.txt
Run by Boo at 20/05/2013 19:09:59
Corbeille vidée
ABSENT Key: HKLM\Software\HAL7600
ABSENT Key: HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\482AA67AD25E6E74E9F48BD5FBE8533C
ABSENT Key: HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\29799DE249E7DBC459FC6C8F07EB8375
ABSENT Key: HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\0238BBE24EA3A70408B81E4BB89C15E5
ABSENT Key: HKLM\Software\Classes\Installer\Features\A9E0FC7FB84D2494597352E90D65D84F
ABSENT Key: HKLM\Software\Classes\Installer\Products\A9E0FC7FB84D2494597352E90D65D84F
ABSENT Key: HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\A9E0FC7FB84D2494597352E90D65D84F
ABSENT Key: HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UpgradeCodes\F1057DD419AED0B468AD8888429E139A
ABSENT Key: Service: McComponentHostService
ABSENT {5FF1BD56-B644-491D-BE35-6BF7DC7D795A}
ABSENT {2C84D825-E4C3-430C-9A04-4A206B4F0B3A}
ABSENT File: c:\users\boo\appdata\roaming\microsoft\internet explorer\quick launch\vuze.lnk
ABSENT File: c:\program files (x86)\vuze\azureus.exe
3 : Dossier(s)
4 : Fichier(s)
End of clean in 00mn 00s
C:\ZHP\ZHPFix[R1].txt - 20/05/2013 18:07:22 [2481]
C:\ZHP\ZHPFix[R2].txt - 20/05/2013 19:09:59 [2495]
par Evasion60
#4092
:hello: Bonsoir
OK avec le correctif, bien joué :excla:
Passe ce scanner =>
  • Clic sur Démarrer
Reviens avec son rapport / STP
par Hatha Taisho
#4108
Plusieurs menace détecté. :triste:
C:\UsbFix\Quarantine\C\Users\Boo\AppData\Local\Temp\Facebook.vbs.vir VBS/TrojanDownloader.Agent.NHP cheval de troie nettoyé par suppression - mis en quarantaine
C:\UsbFix\Quarantine\C\Users\Boo\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\Facebook.vbs.vir VBS/TrojanDownloader.Agent.NHP cheval de troie nettoyé par suppression - mis en quarantaine
C:\UsbFix\Quarantine\H\Facebook.vbs.vir VBS/TrojanDownloader.Agent.NHP cheval de troie nettoyé par suppression - mis en quarantaine
C:\UsbFix\Quarantine\H\zouqaaj.scr.vir Win32/AutoRun.VB.NI ver nettoyé par suppression - mis en quarantaine
C:\UsbFix\Quarantine\H\RECYCLER\S-5-3-42-2819952290-8240758988-879315005-3665\jwgkvsq.vmx.vir une variante de Win32/Conficker.X ver nettoyé par suppression - mis en quarantaine
C:\Users\Boo\Downloads\rld-aoe2hd-zone-telechargement.com.iso une variante de Win32/Packed.VMProtect.AAH cheval de troie supprimé - mis en quarantaine
par Evasion60
#4110
:hello: Bonsoir
Ok, le reste est en quarantine, et va être supprimé avec la fin de désinfection
Supprimé : C:\ZHP
########## - EOF - ##########
Infos =>
/!\ Le meilleur antivirus, c'est le comportement entre l'écran, la page Web et la souris => Ne pas cliquer sur n'importe quoi // Prendre le temps de lire avant de cliquer !
- A l'installation d'un logiciel, bien choisir le site de téléchargement /!\ ne plus télécharger sur 01Net et Softonic ( pourris => question de "Gros sous" ! )
- Préfère des Serveurs propres => PCAstuces // Zebulon // CCM // etc ...
- Tjrs préférer les sites Editeurs des softs
- Bien lire avant installation les options à  décocher => AskBar // Google Chrome // GoogleToolBar // Etc ...
/!\ En aucun cas télécharger/pomper en sites Warez // P2P // Cracks // Keygens
/!\ Banir les sites pornos, sources de grosses mde !! // Ils installent de faux codecs // Attention à  votre carte bancaire !!!
Ensuite en résidents =>
- Un anti virus à  jour
- Un FireWall
- MalwareBytes AM est un bon produit // La version Pro coute 27euros mises à  jour automatique + résident // Pour la Free, la tenir à  jour en manuel et un scan par semaine
- CCleaner ( vidage des fichiers temporaire de navigation ) // Tous les trois jours
- Spyware Blaster reste aussi un bon produit free, il n'est pas "dépassé" (navigateurs Web est IE et Firefox)
/!\ Tenir à  jour ses logiciels de Sécurité ( Java // Adobe Reader // FlashPlayer // etc ...... )
/!\ Vacciner les HDD, et supports externes USB, contre les infections venant de support externe USB infectés, avec MKV
Nota =>
pour les mises à  jour =>
https://forum.pcastuces.com/maj_logiciel ... s25842.htm
Pour vacciner les supports externes USB, et disques durs =>
Télécharge => https://services.service-webmaster.fr/cp ... -6507.html de El Desaparecido, sur le bureau
Bonne continuation, et bon surf ;)
par Hatha Taisho
#4124
Voilà  le rapport
# DelFix v10.2 - Rapport créé le 23/05/2013 à  17:30:27
# Mis à  jour le 02/04/2013 par Xplode
# Nom d'utilisateur : Boo - BOO-PC
# Système d'exploitation : Windows 7 Home Basic Service Pack 1 (64 bits)
Supprimé : C:\USBFix
Supprimé : C:\ZHP
Supprimé : C:\AdwCleaner[R1].txt
Supprimé : C:\AdwCleaner[S2].txt
Supprimé : C:\UsbFix [Clean 1] BOO-PC.txt
Supprimé : C:\UsbFix [Scan 2] BOO-PC.txt
Supprimé : C:\Users\Boo\Desktop\esetsmartinstaller_fra.exe
Supprimé : C:\Users\Boo\Downloads\AdwCleaner[R1].txt
Supprimé : C:\Users\Boo\Downloads\ZHPDiag.txt
Supprimé : RP #789 [Point de contrôle planifié | 05/22/2013 17:07:22]
Supprimé : RP #791 [Windows Update | 05/23/2013 05:17:54]
par Evasion60
#4131
:hello: Bonsoir
Pour moi c'est bon ;)
Je marque ton sujet en résolu
Bon surf
par Evasion60
#4157
:hello: Bonjour
Merci !
Bon surf, attention au Web :alcool:
Bonne continuation ;)
