par Evasion60
#4522
:hello: Bonsoir akiyola971
Bien joué avec MBAM & AdwCleaner :bravo1:
/!\ Je t'engage vivivement à  changer tes comportements Web, via les flux pourris en P2P + tes cracks :yanger:
Vecteurs de graves infections !
Applique ce correctif =>
P2 - FPN:Firefox Plugin Navigator . (.BitComet - BitCometAgent v1.23 for Firefox.) -- C:\Program Files\Mozilla Firefox\Plugins\npBitCometAgent.dll    => P2P.BitComet*
O39 - APT:Automatic Planified Task  - C:\Windows\Tasks\OptimizerProUpdaterTask{F12180C7-3FBC-4656-B8F0-1037E05226B7}.job   [406]    => Infection PUP (PUP.OptimizerPro)*
[MD5.00000000000000000000000000000000] [APT] [OptimizerProUpdaterTask{F12180C7-3FBC-4656-B8F0-1037E05226B7}] (...) -- C:\ProgramData\Premium\OptimizerPro\OptimizerPro.exe (.not file.)   [0]    => Infection PUP (PUP.OptimizerPro)*
[MD5.00000000000000000000000000000000] [APT] [Scheduled Update for Ask Toolbar] (...) -- C:\Program Files\Ask.com\UpdateTask.exe (.not file.)   [0]    => Toolbar.Ask
[MD5.00000000000000000000000000000000] [APT] [YourFile Update] (...) -- C:\Program Files\YourFileDownloader\YourFileUpdater.exe (.not file.)   [0]    => Infection PUP (PUP.YourFileDownloader)
[MD5.00000000000000000000000000000000] [APT] [{0B4322C0-2A3E-4603-A0E6-991F1DD79902}] (...) -- L:\setup.exe (.not file.)   [0]    => Existe aussi en malware DELF-CA.Troj
[MD5.00000000000000000000000000000000] [APT] [{32CFB9F8-0518-41E3-BAC3-EC73CD3FBAE2}] (...) -- C:\Program Files\Mega Bloc Notes\desinstall.exe (.not file.)   [0]
[MD5.00000000000000000000000000000000] [APT] [{33D1502A-7596-46F2-99DB-66908331960A}] (...) -- C:\Users\Anick\Downloads\HiJackThis.exe (.not file.)   [0]    => HiJackThis.exe
[MD5.00000000000000000000000000000000] [APT] [{91AC181B-71CF-4DA5-AEF6-F5BFBE428715}] (...) -- C:\Program Files\QuickTime\QTSystem\QuickTime.cpl" -c QuickTime (.not file.)   [0]    => QuickTime QTSystem
[MD5.00000000000000000000000000000000] [APT] [{A62D5FE7-C2FE-41BA-A869-13BAA9EF7137}] (...) -- C:\Program Files\7-Zip\Uninstall.exe (.not file.)   [0]    => 7-Zip Sotfware Uninstaller
[HKCU\Software\IncrediMail]    => Messaging.Incredimail
[HKCU\Software\wscontb]    => Toolbar.Agent
O43 - CFD: 27/11/2012 - 03:42:24 - [0,403] ----D C:\Program Files\DNA    => BitTorrent DNA PeerToPeer
O43 - CFD: 27/11/2012 - 03:48:31 - [0,000] ----D C:\ProgramData\IM    => Messaging.IncrediMail
O43 - CFD: 27/11/2012 - 04:02:16 - [0,341] ----D C:\Users\Anick\AppData\Roaming\BitComet    => P2P.BitComet*
O43 - CFD: 27/11/2012 - 04:00:17 - [-1703,113] ----D C:\Users\Anick\AppData\Local\Ares    => Ares Galaxy PeerToPeer
O43 - CFD: 27/11/2012 - 04:00:26 - [0,610] ----D C:\Users\Anick\AppData\Local\eSupport.com    => Infection Rogue (Rogue.RegistryWizard)
O43 - CFD: 27/11/2012 - 04:00:30 - [6,711] ----D C:\Users\Anick\AppData\Local\IM    => Messaging.IncrediMail
O69 - SBI: prefs.js [Anick - 6ejitbmq.default] user_pref("extensions.helperbar.DockingPositionDown", false);    => Infection PUP (Hijacker.SmartBar)*
O69 - SBI: SearchScopes [HKCU] {AB85108A-7723-4B6D-BAA4-875AD5E04CD6} - (WhiteSmoke US New Customized Web Search) - https://search.conduit.com    => Toolbar.Conduit*
[HKLM\Software\Microsoft\Tracing\YourFile_RASAPI32]    => Infection PUP (PUP.YourFileDownloader)
[HKLM\Software\Microsoft\Tracing\YourFileUpdater_RASAPI32]    => Infection PUP (PUP.YourFileDownloader)
[HKLM\Software\Microsoft\Tracing\YourFileUpdater_RASMANCS]    => Infection PUP (PUP.YourFileDownloader)
[HKLM\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{11111111-1111-1111-1111-110211181110}]    => Infection PUP (PUP.CrossRider)
C:\Users\Anick\Downloads\Keygen_Zemana_AntiLogger_1.9.x.xxx_-_SND.exe    => Crack, KeyGen, Keymaker - Possible Malware
EmptyCLSID
Emptytemp
Passe ce scanner en ligne =>
  • Clic sur Démarrer
Reviens dans ta réponses avec les deux rapports demandés ;)
par akiyola971
#4529
bonjour bonne journée, je vous mets le rapport ZHPfix en attendant l'autre
Rapport de ZHPFix 2013.6.4.1 par Nicolas Coolman, Update du 04/06/2013
Fichier d'export Registre :
Run by Anick at 07/06/2013 10:48:05
High Elevated Privileges : OK
Windows 7 Home Premium Edition, 32-bit Service Pack 1 (Build 7601)
Corbeille vidée
SUPPRIME Memory Process: C:\Users\Anick\Downloads\Keygen_Zemana_AntiLogger_1.9.x.xxx_-_SND.exe
SUPPRIME Key: HKCU\Software\IncrediMail
SUPPRIME Key: HKCU\Software\wscontb
SUPPRIME Key: SearchScopes :{AB85108A-7723-4B6D-BAA4-875AD5E04CD6}
SUPPRIME Key: HKLM\Software\Microsoft\Tracing\YourFile_RASAPI32
SUPPRIME Key: HKLM\Software\Microsoft\Tracing\YourFileUpdater_RASAPI32
SUPPRIME Key: HKLM\Software\Microsoft\Tracing\YourFileUpdater_RASMANCS
SUPPRIME Key: HKLM\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{11111111-1111-1111-1111-110211181110}
SUPPRIME Mozilla Pref: user_pref("extensions.helperbar.DockingPositionDown", false);
SUPPRIME Temporaires Windows
SUPPRIME Flash Cookies
SUPPRIME File: c:\program files\mozilla firefox\plugins\npbitcometagent.dll
SUPPRIME File: c:\windows\tasks\optimizerproupdatertask{f12180c7-3fbc-4656-b8f0-1037e05226b7}.job
ABSENT Folder/File: c:\users\anick\appdata\local\esupport.com
SUPPRIME File: c:\users\anick\downloads\keygen_zemana_antilogger_1.9.x.xxx_-_snd.exe
ABSENT Folder/File: c:\users\anick\downloads\keygen_zemana_antilogger_1.9.x.xxx_-_snd.exe
SUPPRIME Task: OptimizerProUpdaterTask{F12180C7-3FBC-4656-B8F0-1037E05226B7}
SUPPRIME Task: Scheduled Update for Ask Toolbar
SUPPRIME Task: YourFile Update
SUPPRIME Task: {0B4322C0-2A3E-4603-A0E6-991F1DD79902}
SUPPRIME Task: {32CFB9F8-0518-41E3-BAC3-EC73CD3FBAE2}
SUPPRIME Task: {33D1502A-7596-46F2-99DB-66908331960A}
SUPPRIME Task: {91AC181B-71CF-4DA5-AEF6-F5BFBE428715}
SUPPRIME Task: {A62D5FE7-C2FE-41BA-A869-13BAA9EF7137}
1 : Processus mémoire
7 : Clé(s) du Registre
3 : Dossier(s)
7 : Fichier(s)
1 : Préférences navigateur
8 : Tache planifiée
End of clean in 02mn 41s
C:\ZHP\ZHPFix[R1].txt - 07/06/2013 10:48:05 [2426]
par Evasion60
#4531
:hello: Re
Aucun problème !
Je serais absent une partie de cet AM, mais présent un peu plus tard ;)
par akiyola971
#4534
voilà  le rapport du scan d'eset
C:\Users\Anick\AppData\Roaming\Mozilla\Firefox\Profiles\6ejitbmq.default\extensions\50b4d3607af86@50b4d3607afbf.com\content\bg.js Win32/Adware.MultiPlug.H Application nettoyé par suppression - mis en quarantaine
par Evasion60
#4535
:hello: Re
OK, nous terminons =>
Supprimé : C:\ZHP
########## - EOF - ##########
Infos =>
/!\ Le meilleur antivirus, c'est le comportement entre l'écran, la page Web et la souris => Ne pas cliquer sur n'importe quoi // Prendre le temps de lire avant de cliquer !
- A l'installation d'un logiciel, bien choisir le site de téléchargement /!\ ne plus télécharger sur 01Net et Softonic ( pourris => question de "Gros sous" ! )
- Préfère des Serveurs propres => PCAstuces // Zebulon // CCM // etc ...
- Tjrs préférer les sites Editeurs des softs
- Bien lire avant installation les options à  décocher => AskBar // Google Chrome // GoogleToolBar // Etc ...
/!\ En aucun cas télécharger/pomper en sites Warez // P2P // Cracks // Keygens
/!\ Banir les sites pornos, sources de grosses mde !! // Ils installent de faux codecs // Attention à  votre carte bancaire !!!
Ensuite en résidents =>
- Un anti virus à  jour
- Un FireWall
- MalwareBytes AM est un bon produit // La version Pro coute 27euros mises à  jour automatique + résident // Pour la Free, la tenir à  jour en manuel et un scan par semaine
- CCleaner ( vidage des fichiers temporaire de navigation ) // Tous les trois jours
- Spyware Blaster reste aussi un bon produit free, il n'est pas "dépassé" (navigateurs Web est IE et Firefox)
/!\ Tenir à  jour ses logiciels de Sécurité ( Java // Adobe Reader // FlashPlayer // etc ...... )
/!\ Vacciner les HDD, et supports externes USB, contre les infections venant de support externe USB infectés, avec MKV
Nota =>
pour les mises à  jour =>
https://forum.pcastuces.com/maj_logiciel ... s25842.htm
Pour vacciner les supports externes USB, et disques durs =>
Télécharge => https://services.service-webmaster.fr/cp ... -6507.html de El Desaparecido, sur le bureau
/!\ Dans ton cas ne pas revaccinner les supports USB, déjà  fait avec USBFix :)
J'attends ta lecture de ce final, puis je metterais ton sujet en " Résolu "
Bonne continuation, et bon surf ! ;) :alcool:
par akiyola971
#4536
voilà
# DelFix v10.2 - Rapport créé le 07/06/2013 à  14:51:26
# Mis à  jour le 02/04/2013 par Xplode
# Nom d'utilisateur : Anick - PC-DE-ANICK
# Système d'exploitation : Windows 7 Home Premium Service Pack 1 (32 bits)
Supprimé : C:\USBFix
Supprimé : C:\MyHosts
Supprimé : C:\ZHP
Supprimé : C:\UsbFix [Clean 1] PC-DE-ANICK.txt
Supprimé : C:\UsbFix [Clean 2] PC-DE-ANICK.txt
Supprimé : C:\UsbFix [Scan 1] PC-DE-ANICK.txt
Supprimé : C:\UsbFix [Scan 2] PC-DE-ANICK.txt
Supprimé : C:\UsbFix [Scan 3] PC-DE-ANICK.txt
Supprimé : C:\UsbFix [Scan 4] PC-DE-ANICK.txt
Supprimé : C:\Users\Anick\Desktop\Desktop\adwcleaner.exe
Supprimé : C:\Users\Anick\Desktop\Desktop\esetsmartinstaller_fra.exe
Supprimé : C:\Users\Anick\Desktop\Desktop\MKV.exe
Supprimé : C:\Users\Anick\Desktop\Desktop\ZHPFixReport.txt
Supprimé : C:\Users\Public\Desktop\MBRCheck.lnk
Supprimé : C:\Users\Public\Desktop\ZHPDiag.lnk
Supprimé : C:\Users\Public\Desktop\ZHPFix.lnk
Supprimé : C:\Users\Anick\Downloads\ZHPDiag2.exe
Supprimé : C:\Windows\system32\404Fix.exe
Supprimé : C:\Windows\system32\VACFix.exe
Supprimé : C:\Windows\system32\VCCLSID.exe
Supprimé : C:\Windows\system32\IEDFix.exe
Supprimé : C:\Windows\system32\IEDFix.C.exe
Supprimé : C:\Windows\system32\WS2Fix.exe
Supprimé : C:\Windows\system32\Process.exe
Supprimé : C:\Windows\system32\SWReg.exe
Supprimé : C:\Windows\system32\SWSC.exe
Supprimé : C:\Windows\system32\SWXCacls.exe
Supprimé : C:\Windows\system32\SrchSTS.exe
Supprimé : C:\Windows\system32\Dumphive.exe
Supprimé : RP #122 [Windows Update | 04/19/2013 10:59:50]
Supprimé : RP #123 [Opération de restauration | 04/19/2013 13:48:34]
Supprimé : RP #124 [Windows Update | 04/19/2013 13:57:33]
Supprimé : RP #126 [Revo Uninstaller Pro's restore point - Kaspersky PURE 3.0 | 04/19/2013 14:43:54]
Supprimé : RP #127 [Windows Update | 04/19/2013 14:54:36]
Supprimé : RP #128 [Installed Java 7 Update 21 | 04/19/2013 18:31:16]
Supprimé : RP #129 [Windows Update | 04/25/2013 14:52:31]
Supprimé : RP #130 [Windows Update | 04/25/2013 16:04:20]
Supprimé : RP #131 [Windows Update | 04/30/2013 22:09:32]
Supprimé : RP #132 [Installed OpenOffice.org 3.4.1 | 05/02/2013 14:31:15]
Supprimé : RP #133 [Windows Update | 05/07/2013 17:44:59]
Supprimé : RP #134 [Windows Update | 05/17/2013 19:26:00]
Supprimé : RP #135 [Windows Update | 05/17/2013 19:36:33]
Supprimé : RP #137 [Revo Uninstaller Pro's restore point - Surf Anonymous Free | 05/17/2013 19:59:18]
Supprimé : RP #138 [Windows Update | 05/22/2013 16:05:44]
Supprimé : RP #139 [Windows Update | 05/28/2013 09:00:32]
Supprimé : RP #140 [Installed AVG 2013 | 05/28/2013 09:46:45]
Supprimé : RP #141 [Installed AVG 2013 | 05/28/2013 09:47:06]
Supprimé : RP #142 [Installed Microsoft Office Professionnel Plus 2013 | 05/28/2013 11:41:40]
Supprimé : RP #143 [PROPLUSR | 05/28/2013 11:42:09]
Supprimé : RP #144 [Installed Microsoft Office Professionnel Plus 2013 | 05/28/2013 11:44:58]
Supprimé : RP #145 [PROPLUSR | 05/28/2013 11:45:14]
Supprimé : RP #146 [Installed Microsoft Fix it 50450 | 05/28/2013 11:47:11]
Supprimé : RP #147 [Installed Microsoft Office Professionnel Plus 2013 | 05/28/2013 11:52:55]
Supprimé : RP #148 [PROPLUSR | 05/28/2013 11:53:10]
Supprimé : RP #149 [Installed Microsoft Office Professionnel Plus 2013 | 05/28/2013 11:57:39]
Supprimé : RP #150 [PROPLUSR | 05/28/2013 11:57:57]
Supprimé : RP #151 [Installed Microsoft Office Professionnel Plus 2013 | 05/28/2013 12:08:19]
Supprimé : RP #152 [PROPLUSR | 05/28/2013 12:08:36]
Supprimé : RP #153 [Installed Microsoft Office Professionnel Plus 2013 | 05/28/2013 12:14:13]
Supprimé : RP #154 [PROPLUSR | 05/28/2013 12:14:27]
Supprimé : RP #155 [Installed Microsoft Office Professionnel Plus 2013 | 05/28/2013 12:26:03]
Supprimé : RP #156 [PROPLUSR | 05/28/2013 12:26:18]
Supprimé : RP #157 [Installed Microsoft Fix it 50450 | 05/28/2013 12:32:54]
Supprimé : RP #158 [Point de contrôle planifié | 06/04/2013 12:55:24]
Et re remerçie pour tout :merci2:
