clé usb infectée Réparation PC
par jimmyom52000
#6076
bonjour, depuis hier ma clé ucb est infecté et voici le rapport usb fix! Que faire??? merci
############################## | UsbFix V 7.129 | [Suppression]
Utilisateur: Jimmy et laura (Administrateur) # JIMMYETLAURA-PC
Mis à  jour le 24/06/2013 par El Desaparecido
Lancé à  10:15:35 | 30/07/2013
Site Web: https://www.sosvirus.net/
Upload Malware: https://www.sosvirus.net/upload-malware-pour-analyse-t489.html
Contact: contact@sosvirus.net
PC: ASUSTeK Computer Inc. (K52JT) (x64-based PC)
CPU: Intel(R) Core(TM) i3 CPU M 380 @ 2.53GHz (2533)
RAM -> [Total : 3949 | Free : 1366]
BIOS: BIOS Date: 10/30/09 15:13:23 Ver: 08.00.10
BOOT: Normal boot
OS: Microsoft Windows 7 à‰dition Familiale Premium (6.1.7600 64-Bit) #
C:\ (%systemdrive%) -> Disque fixe # 254 Go (158 Go libre(s) - 62%) [OS] # NTFS
D:\ -> Disque fixe # 317 Go (81 Mo libre(s) - 0%) [DATA] # NTFS
E:\ -> CD-ROM
HKLM\SOFTWARE | Run : [UpdateLBPShortCut] - "C:\Program Files (x86)\CyberLink\LabelPrint\MUITransfer\MUIStartMenu.exe" "C:\Program Files (x86)\CyberLink\LabelPrint" UpdateWithCreateOnce "Software\CyberLink\LabelPrint\2.5"
HKLM\SOFTWARE | Run : [UpdateP2GoShortCut] - "C:\Program Files (x86)\CyberLink\Power2Go\MUITransfer\MUIStartMenu.exe" "C:\Program Files (x86)\CyberLink\Power2Go" UpdateWithCreateOnce "SOFTWARE\CyberLink\Power2Go\6.0"
HKLM\SOFTWARE | Run : [Nuance PDF Reader-reminder] - "C:\Program Files (x86)\Nuance\PDF Reader\Ereg\Ereg.exe" -r "C:\ProgramData\Nuance\PDF Reader\Ereg\Ereg.ini"
HKLM\SOFTWARE | Run : [StartCCC] - "C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe" MSRun
HKLM\SOFTWARE | Run : [ATKOSD2] - C:\Program Files (x86)\ASUS\ATK Package\ATKOSD2\ATKOSD2.exe
HKLM\SOFTWARE | Run : [ATKMEDIA] - C:\Program Files (x86)\ASUS\ATK Package\ATK Media\DMedia.exe
HKLM\SOFTWARE | Run : [HControlUser] - C:\Program Files (x86)\ASUS\ATK Package\ATK Hotkey\HControlUser.exe
HKLM\SOFTWARE | Run : [Wireless Console 3] - C:\Program Files (x86)\ASUS\Wireless Console 3\wcourier.exe
HKLM\SOFTWARE | Run : [RemoteControl10] - "C:\Program Files (x86)\CyberLink\PowerDVD10\PDVD10Serv.exe"
HKLM\SOFTWARE | Run : [BDRegion] - C:\Program Files (x86)\Cyberlink\Shared files\brs.exe
HKLM\SOFTWARE | Run : [DATAMNGR] - C:\PROGRA~2\SEARCH~1\Datamngr\DATAMN~1.EXE
HKLM\SOFTWARE | Run : [EEventManager] - "C:\Program Files (x86)\Epson Software\Event Manager\EEventManager.exe"
HKLM\SOFTWARE | Run : [SearchProtectAll] - C:\Program Files (x86)\SearchProtect\bin\cltmng.exe
HKLM\SOFTWARE\wow6432Node | Run : [UpdateLBPShortCut] - "C:\Program Files (x86)\CyberLink\LabelPrint\MUITransfer\MUIStartMenu.exe" "C:\Program Files (x86)\CyberLink\LabelPrint" UpdateWithCreateOnce "Software\CyberLink\LabelPrint\2.5"
HKLM\SOFTWARE\wow6432Node | Run : [UpdateP2GoShortCut] - "C:\Program Files (x86)\CyberLink\Power2Go\MUITransfer\MUIStartMenu.exe" "C:\Program Files (x86)\CyberLink\Power2Go" UpdateWithCreateOnce "SOFTWARE\CyberLink\Power2Go\6.0"
HKLM\SOFTWARE\wow6432Node | Run : [Nuance PDF Reader-reminder] - "C:\Program Files (x86)\Nuance\PDF Reader\Ereg\Ereg.exe" -r "C:\ProgramData\Nuance\PDF Reader\Ereg\Ereg.ini"
HKLM\SOFTWARE\wow6432Node | Run : [StartCCC] - "C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe" MSRun
HKLM\SOFTWARE\wow6432Node | Run : [ATKOSD2] - C:\Program Files (x86)\ASUS\ATK Package\ATKOSD2\ATKOSD2.exe
HKLM\SOFTWARE\wow6432Node | Run : [ATKMEDIA] - C:\Program Files (x86)\ASUS\ATK Package\ATK Media\DMedia.exe
HKLM\SOFTWARE\wow6432Node | Run : [HControlUser] - C:\Program Files (x86)\ASUS\ATK Package\ATK Hotkey\HControlUser.exe
HKLM\SOFTWARE\wow6432Node | Run : [Wireless Console 3] - C:\Program Files (x86)\ASUS\Wireless Console 3\wcourier.exe
HKLM\SOFTWARE\wow6432Node | Run : [RemoteControl10] - "C:\Program Files (x86)\CyberLink\PowerDVD10\PDVD10Serv.exe"
HKLM\SOFTWARE\wow6432Node | Run : [BDRegion] - C:\Program Files (x86)\Cyberlink\Shared files\brs.exe
HKLM\SOFTWARE\wow6432Node | Run : [DATAMNGR] - C:\PROGRA~2\SEARCH~1\Datamngr\DATAMN~1.EXE
HKLM\SOFTWARE\wow6432Node | Run : [EEventManager] - "C:\Program Files (x86)\Epson Software\Event Manager\EEventManager.exe"
HKLM\SOFTWARE\wow6432Node | Run : [SearchProtectAll] - C:\Program Files (x86)\SearchProtect\bin\cltmng.exe
HKU\S-1-5-21-4085161647-3734010171-3011228962-1001\SOFTWARE | Run : [Syncables] - C:\Program Files (x86)\syncables\syncables desktop\Syncables.exe
HKU\S-1-5-21-4085161647-3734010171-3011228962-1001\SOFTWARE | Run : [KiesTrayAgent] - C:\Program Files (x86)\Samsung\Kies\KiesTrayAgent.exe
HKU\S-1-5-21-4085161647-3734010171-3011228962-1001\SOFTWARE | Run : [KiesPDLR] - C:\Program Files (x86)\Samsung\Kies\External\FirmwareUpdate\KiesPDLR.exe
HKU\S-1-5-21-4085161647-3734010171-3011228962-1001\SOFTWARE | Run : [iCloudServices] - C:\Program Files (x86)\Common Files\Apple\Internet Services\iCloudServices.exe
HKU\S-1-5-21-4085161647-3734010171-3011228962-1001\SOFTWARE | Run : [MobileDocuments] - C:\Program Files (x86)\Common Files\Apple\Internet Services\ubd.exe
HKU\S-1-5-21-4085161647-3734010171-3011228962-1001\SOFTWARE | Run : [Facebook Update] - "C:\Users\Jimmy et laura\AppData\Local\Facebook\Update\FacebookUpdate.exe" /c /nocrashserver
HKU\S-1-5-21-4085161647-3734010171-3011228962-1001\SOFTWARE | Run : [KiesPreload] - C:\Program Files (x86)\Samsung\Kies\Kies.exe /preload
HKU\S-1-5-21-4085161647-3734010171-3011228962-1001\SOFTWARE | Run : [MailNotifier] - C:\Program Files (x86)\Orange\MailNotifier\MailNotifier.exe
HKU\S-1-5-21-4085161647-3734010171-3011228962-1001\SOFTWARE | Run : [TomTomHOME.exe] - "C:\Program Files (x86)\TomTom HOME 2\TomTomHOMERunner.exe"
HKU\S-1-5-21-4085161647-3734010171-3011228962-1001\SOFTWARE | Run : [Yontoo Desktop] - "C:\Users\Jimmy et laura\AppData\Roaming\Yontoo\YontooDesktop.exe"
HKU\S-1-5-21-4085161647-3734010171-3011228962-1001\SOFTWARE | Run : [SearchProtect] - C:\Users\Jimmy et laura\AppData\Roaming\SearchProtect\bin\cltmng.exe
Stoppé! C:\Windows\system32\atiesrxx.exe (956)
Stoppé! C:\Windows\system32\atieclxx.exe (1312)
Stoppé! C:\Windows\system32\FBAgent.exe (1376)
Stoppé! C:\Program Files (x86)\ASUS\ATK Package\ATK Hotkey\ASLDRSrv.exe (1416)
Stoppé! C:\Program Files (x86)\ASUS\ATK Package\ATKGFNEX\GFNEXSrv.exe (1516)
Stoppé! C:\Program Files\AVAST Software\Avast\AvastSvc.exe (1548)
Stoppé! C:\Windows\System32\spoolsv.exe (1728)
Stoppé! C:\Windows\system32\taskeng.exe (1740)
Stoppé! C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe (1912)
Stoppé! C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe (1940)
Stoppé! C:\Program Files\Bonjour\mDNSResponder.exe (2008)
Stoppé! C:\Program Files (x86)\SearchProtect\bin\CltMngSvc.exe (1124)
Stoppé! C:\Program Files (x86)\Orange\Assistance Livebox\dedicarz\DedicarzService.exe (1580)
Stoppé! C:\Program Files\Common Files\EPSON\EPW!3 SSRP\E_S50STB.EXE (1620)
Stoppé! C:\Program Files\Common Files\EPSON\EPW!3 SSRP\E_S50RPB.EXE (552)
Stoppé! C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe (1168)
Stoppé! C:\Program Files (x86)\Microsoft Application Virtualization Client\sftvsa.exe (2604)
Stoppé! C:\Program Files (x86)\TomTom HOME 2\TomTomHOMEService.exe (2684)
Stoppé! C:\Program Files (x86)\Wajam\Updater\WajamUpdater.exe (2716)
Stoppé! C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE (2756)
Stoppé! C:\Program Files (x86)\Yontoo\Y2Desktop.Updater.exe (2788)
Stoppé! C:\Program Files (x86)\Microsoft Application Virtualization Client\sftlist.exe (2868)
Stoppé! C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSvcM.exe (2892)
Stoppé! C:\Program Files (x86)\Common Files\Microsoft Shared\Virtualization Handler\CVHSVC.EXE (3148)
Stoppé! C:\Windows\system32\taskhost.exe (4056)
Stoppé! C:\Windows\system32\taskeng.exe (1188)
Stoppé! C:\Windows\system32\taskeng.exe (3896)
Stoppé! C:\Program Files (x86)\Google\Update\GoogleUpdate.exe (2200)
Stoppé! C:\Program Files (x86)\ASUS\ATK Package\ATKOSD2\ATKOSD2.exe (4140)
Stoppé! C:\Program Files\P4G\BatteryLife.exe (4172)
Stoppé! C:\Program Files (x86)\ASUS\ASUS Live Update\ALU.exe (4192)
Stoppé! C:\Program Files (x86)\ASUS\Splendid\ACMON.exe (4220)
Stoppé! C:\Windows\System32\rundll32.exe (4320)
Stoppé! C:\Program Files (x86)\Orange\Assistance Livebox\AssistanceLivebox.exe (4332)
Stoppé! C:\Program Files (x86)\ASUS\ASUS Data Security Manager\ADSMSrv.exe (4808)
Stoppé! C:\Windows\AsScrPro.exe (4852)
Stoppé! C:\Program Files\ASUS\NB Probe\SPM\spmgr.exe (4912)
Stoppé! C:\Program Files (x86)\CyberLink\Power2Go\CLMLSvc.exe (4952)
Stoppé! C:\Program Files (x86)\ASUS\ASUS WebStorage\SERVICE\AsusWSService.exe (5060)
Stoppé! C:\Program Files\Elantech\ETDCtrl.exe (1868)
Stoppé! C:\Program Files (x86)\syncables\syncables desktop\syncables.exe (4236)
Stoppé! C:\Program Files (x86)\Samsung\Kies\KiesTrayAgent.exe (4304)
Stoppé! C:\Program Files (x86)\syncables\syncables desktop\jre\bin\javaw.exe (4256)
Stoppé! C:\Program Files (x86)\Samsung\Kies\Kies.exe (4000)
Stoppé! C:\Program Files (x86)\Orange\MailNotifier\MailNotifier.exe (2452)
Stoppé! C:\Program Files (x86)\TomTom HOME 2\TomTomHOMERunner.exe (3804)
Stoppé! C:\Users\Jimmy et laura\AppData\Roaming\Yontoo\YontooDesktop.exe (4552)
Stoppé! C:\Users\Jimmy et laura\AppData\Roaming\SearchProtect\bin\cltmng.exe (4656)
Stoppé! C:\Windows\system32\SearchIndexer.exe (4296)
Stoppé! C:\Program Files\SRS Labs\SRS Premium Sound Control Panel\srspremiumpanel_64.exe (4708)
Stoppé! C:\Program Files (x86)\ASUS\ATK Package\ATK Media\DMedia.exe (5184)
Stoppé! C:\Program Files (x86)\ASUS\ATK Package\ATK Hotkey\HControlUser.exe (5220)
Stoppé! C:\Program Files (x86)\OpenOffice.org 3\program\soffice.exe (5232)
Stoppé! C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\MOM.exe (5240)
Stoppé! C:\Program Files (x86)\ASUS\Wireless Console 3\wcourier.exe (5296)
Stoppé! C:\Program Files (x86)\CyberLink\PowerDVD10\PDVD10Serv.exe (5304)
Stoppé! C:\Windows\SysWOW64\ACEngSvr.exe (5376)
Stoppé! C:\Program Files (x86)\CyberLink\Shared files\brs.exe (5384)
Stoppé! C:\Program Files\AVAST Software\Avast\AvastUI.exe (5392)
Stoppé! C:\Program Files (x86)\OpenOffice.org 3\program\soffice.bin (5456)
Stoppé! C:\Program Files (x86)\Epson Software\Event Manager\EEventManager.exe (5472)
Stoppé! C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe (5480)
Stoppé! C:\Program Files (x86)\ASUS\ControlDeck\ControlDeck.exe (4920)
Stoppé! C:\Program Files\Elantech\ETDCtrlHelper.exe (6124)
Stoppé! C:\Windows\System32\WUDFHost.exe (5808)
Stoppé! C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\CCC.exe (6380)
Stoppé! C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\UNS\UNS.exe (6568)
Stoppé! C:\Program Files\Windows Media Player\wmpnetwk.exe (6576)
Stoppé! C:\Windows\Microsoft.Net\Framework64\v3.0\WPF\PresentationFontCache.exe (6916)
Stoppé! C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_7_700_224_ActiveX.exe (1060)
Stoppé! C:\Program Files (x86)\Common Files\Java\Java Update\jucheck.exe (5112)
Stoppé! C:\Program Files (x86)\Orange\Assistance Livebox\dist\ST2.exe (6880)
Stoppé! C:\Program Files (x86)\Internet Explorer\iexplore.exe (5096)
Stoppé! C:\Program Files (x86)\Internet Explorer\iexplore.exe (3740)
Stoppé! C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (7628)
Stoppé! C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (7824)
Stoppé! C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (7924)
Stoppé! C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (7788)
Stoppé! C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (7816)
Stoppé! C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (7312)
Stoppé! C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (7288)
Stoppé! C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (7188)
Stoppé! C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (7696)
Stoppé! C:\Windows\system32\taskhost.exe (8148)
Stoppé! C:\Windows\system32\taskhost.exe (6236)
Stoppé! C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (7408)
[16/09/2011 - 15:14:01 | SHD ] C:\$Recycle.Bin
[19/02/2012 - 22:29:43 | D ] C:\211a5b884fec3e0a402c
[05/05/2013 - 22:59:02 | D ] C:\838b354acb686858b7476980
[01/02/2012 - 12:44:13 | D ] C:\AsusVibeData
[30/07/2013 - 09:48:34 | RASHD ] C:\Autorun.inf
[29/07/2009 - 08:03:34 | SHD ] C:\Boot
[14/07/2009 - 03:38:58 | RASH | 383562] C:\bootmgr
[29/07/2009 - 08:03:37 | N | 8192] C:\BOOTSECT.BAK
[15/09/2011 - 20:21:51 | N | 68] C:\BurnHelp.txt
[19/07/2013 - 09:23:37 | D ] C:\Config.Msi
[24/06/2011 - 19:50:51 | N | 14546] C:\devlist.txt
[14/07/2009 - 07:08:56 | SHD ] C:\Documents and Settings
[22/09/2011 - 20:34:26 | D ] C:\drivers
[08/07/2013 - 16:30:36 | N | 0] C:\END
[24/06/2011 - 19:39:35 | D ] C:\eSupport
[24/06/2011 - 04:50:51 | N | 9] C:\Finish.log
[30/07/2013 - 09:58:44 | ASH | 3105259520] C:\hiberfil.sys
[04/06/2012 - 23:15:26 | D ] C:\hp
[24/06/2011 - 19:28:39 | D ] C:\Intel
[25/01/2011 - 11:32:26 | N | 2097152] C:\K52JT.BIN
[25/01/2011 - 11:42:26 | N | 2097152] C:\K52JU.BIN
[07/06/2011 - 11:58:05 | N | 19] C:\K52JU_K52JT_WIN7.40
[08/11/2012 - 19:49:49 | D ] C:\Kreapixel
[10/09/2012 - 11:34:35 | N | 256] C:\lxdn.log
[30/07/2013 - 09:58:45 | ASH | 4140347392] C:\pagefile.sys
[24/06/2011 - 05:51:53 | N | 303] C:\Pass.txt
[14/07/2009 - 05:20:08 | D ] C:\PerfLogs
[18/07/2013 - 14:05:27 | D ] C:\Program Files
[29/07/2013 - 23:53:56 | D ] C:\Program Files (x86)
[18/07/2013 - 14:05:26 | HD ] C:\ProgramData
[29/09/2011 - 16:19:19 | D ] C:\Programs
[15/09/2011 - 18:55:53 | SHD ] C:\Recovery
[07/06/2011 - 11:58:05 | N | 14] C:\RECOVERY.DAT
[17/09/2011 - 00:52:23 | N | 90] C:\setup.log
[29/07/2013 - 23:29:10 | SHD ] C:\System Volume Information
[24/09/2012 - 14:42:23 | D ] C:\temp
[30/07/2013 - 09:48:35 | N | 4185] C:\Upload_UsbFix.zip
[30/07/2013 - 10:19:21 | D ] C:\UsbFix
[30/07/2013 - 09:48:35 | N | 15994] C:\UsbFix [Clean 1] JIMMYETLAURA-PC.txt
[30/07/2013 - 10:19:30 | A | 16095] C:\UsbFix [Clean 2] JIMMYETLAURA-PC.txt
[15/09/2011 - 18:57:14 | D ] C:\Users
[02/06/2013 - 20:55:48 | D ] C:\videodvdmaker
[21/05/2013 - 17:39:34 | D ] C:\Windows
[15/09/2011 - 18:57:58 | SHD ] D:\$RECYCLE.BIN
[30/07/2013 - 09:48:34 | RASHD ] D:\Autorun.inf
[10/06/2013 - 11:19:14 | D ] D:\JIMMYETLAURA-PC
[19/09/2011 - 11:56:09 | N | 528] D:\MediaID.bin
[23/07/2013 - 18:25:52 | SHD ] D:\System Volume Information
[19/09/2011 - 12:06:55 | D ] D:\WindowsImageBackup
################## | E.O.F | https://www.sosvirus.net |
#6077
salut tu es encore infecté :)
Télécharge et enregistre (lien direct) https://www.bleepingcomputer.com/downloa ... er/dl/125/ ADWCleaner sur ton bureau :
attends que la fenetre de confirmation de telechargement arrive
Lance le,(Pour vista/7/8 => clic droit "executer en tant qu'administrateur")
clique sur suppression et poste C:\Adwcleaner[Sx].txt
par jimmyom52000
#6078
voici le rapport de aw cleaner!!!
# AdwCleaner v2.306 - Rapport créé le 30/07/2013 à  12:22:31
# Mis à  jour le 19/07/2013 par Xplode
# Système d'exploitation : Windows 7 Home Premium (64 bits)
# Nom d'utilisateur : Jimmy et laura - JIMMYETLAURA-PC
# Mode de démarrage : Normal
# Exécuté depuis : C:\Users\Jimmy et laura\Downloads\AdwCleaner (1).exe
# Option [Suppression]
***** [Services] *****
Arrêté & Supprimé : Browser Manager
Arrêté & Supprimé : CltMngSvc
Arrêté & Supprimé : dqupdate
Arrêté & Supprimé : dqupdatem
Arrêté & Supprimé : Partner Service
Arrêté & Supprimé : supdate
Arrêté & Supprimé : WajamUpdater
Arrêté & Supprimé : Yontoo Desktop Updater
Dossier Supprimé : C:\Program Files (x86)\Boxore
Dossier Supprimé : C:\Program Files (x86)\Conduit
Dossier Supprimé : C:\Program Files (x86)\delta
Dossier Supprimé : C:\Program Files (x86)\Duuqu
Dossier Supprimé : C:\Program Files (x86)\FrameFox
Dossier Supprimé : C:\Program Files (x86)\Mysearchdial
Dossier Supprimé : C:\Program Files (x86)\Search Results Toolbar
Dossier Supprimé : C:\Program Files (x86)\SearchProtect
Dossier Supprimé : C:\Program Files (x86)\Software
Dossier Supprimé : C:\Program Files (x86)\Wajam
Dossier Supprimé : C:\Program Files (x86)\Webplayer setup
Dossier Supprimé : C:\Program Files (x86)\Yontoo
Dossier Supprimé : C:\ProgramData\boost_interprocess
Dossier Supprimé : C:\ProgramData\Browser Manager
Dossier Supprimé : C:\ProgramData\Tarma Installer
Dossier Supprimé : C:\Users\Jimmy et laura\AppData\Local\Conduit
Dossier Supprimé : C:\Users\Jimmy et laura\AppData\Local\Google\Chrome\User Data\Default\Extensions\ehdmaehkiiampolokajdcelladmnopgp
Dossier Supprimé : C:\Users\Jimmy et laura\AppData\Local\Google\Chrome\User Data\Default\Extensions\eooncjejnppfjjklapaamhcdmjbilmde
Dossier Supprimé : C:\Users\Jimmy et laura\AppData\Local\Google\Chrome\User Data\Default\Extensions\jpmbfleldcgkldadpdinhjjopdfpjfjp
Dossier Supprimé : C:\Users\Jimmy et laura\AppData\Local\Google\Chrome\User Data\Default\Extensions\niapdbllcanepiiimjjndipklodoedlc
Dossier Supprimé : C:\Users\Jimmy et laura\AppData\Local\Google\Chrome\User Data\Default\Extensions\pgafcinpmmpklohkojmllohdhomoefph
Dossier Supprimé : C:\Users\Jimmy et laura\AppData\Local\Ilivid
Dossier Supprimé : C:\Users\Jimmy et laura\AppData\Local\PackageAware
Dossier Supprimé : C:\Users\Jimmy et laura\AppData\Local\Wajam
Dossier Supprimé : C:\Users\Jimmy et laura\AppData\LocalLow\BabylonToolbar
Dossier Supprimé : C:\Users\Jimmy et laura\AppData\LocalLow\Conduit
Dossier Supprimé : C:\Users\Jimmy et laura\AppData\LocalLow\delta
Dossier Supprimé : C:\Users\Jimmy et laura\AppData\LocalLow\ilividtoolbarguid
Dossier Supprimé : C:\Users\Jimmy et laura\AppData\LocalLow\Mysearchdial
Dossier Supprimé : C:\Users\Jimmy et laura\AppData\Roaming\BabSolution
Dossier Supprimé : C:\Users\Jimmy et laura\AppData\Roaming\Babylon
Dossier Supprimé : C:\Users\Jimmy et laura\AppData\Roaming\delta
Dossier Supprimé : C:\Users\Jimmy et laura\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Browser Manager
Dossier Supprimé : C:\Users\Jimmy et laura\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Wajam
Dossier Supprimé : C:\Users\Jimmy et laura\AppData\Roaming\Mysearchdial
Dossier Supprimé : C:\Users\Jimmy et laura\AppData\Roaming\SearchProtect
Dossier Supprimé : C:\Users\Jimmy et laura\AppData\Roaming\WebPlayerBdd
Dossier Supprimé : C:\Users\Jimmy et laura\AppData\Roaming\Yontoo
Fichier Supprimé : C:\END
Fichier Supprimé : C:\Users\Jimmy et laura\AppData\Local\Google\Chrome\User Data\Default\bProtector Web Data
Fichier Supprimé : C:\Users\Jimmy et laura\AppData\Local\Google\Chrome\User Data\Default\bprotectorpreferences
Fichier Supprimé : C:\Users\Jimmy et laura\AppData\Local\Google\Chrome\User Data\Default\Local Storage\hxxp_search.conduit.com_0.localstorage
Fichier Supprimé : C:\Users\Jimmy et laura\AppData\Local\Google\Chrome\User Data\Default\Local Storage\hxxp_search.conduit.com_0.localstorage-journal
Fichier Supprimé : C:\Users\Jimmy et laura\AppData\Local\mysearchdial.crx
Fichier Supprimé : C:\Users\Jimmy et laura\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\iLivid.lnk
Fichier Supprimé : C:\Users\Jimmy et laura\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\WebPlayerV2.lnk
Fichier Supprimé : C:\Users\Jimmy et laura\Desktop\WebPlayerV2.lnk
Fichier Supprimé : C:\Users\Public\Desktop\Get The Best Facebook Chat Messenger.lnk
Fichier Supprimé : C:\Windows\Tasks\DuuquUpdateTaskMachineCore.job
Fichier Supprimé : C:\Windows\Tasks\DuuquUpdateTaskMachineUA.job
Fichier Supprimé : C:\Windows\Tasks\MySearchDial.job
Fichier Supprimé : C:\Windows\Tasks\SoftwareUpdateTaskMachineCore.job
Fichier Supprimé : C:\Windows\Tasks\SoftwareUpdateTaskMachineUA.job
Supprimé au redémarrage : C:\ProgramData\BrowserProtect
Supprimé au redémarrage : C:\Users\Jimmy et laura\AppData\Local\Google\Chrome\User Data\Default\Extensions\ehdmaehkiiampolokajdcelladmnopgp
***** [Registre] *****
Clé Supprimée : HKCU\Software\AppDataLow\Software\SmartBar
Clé Supprimée : HKCU\Software\DataMngr_Toolbar
Clé Supprimée : HKCU\Software\Google\Chrome\Extensions\ehdmaehkiiampolokajdcelladmnopgp
Clé Supprimée : HKCU\Software\ilivid
Clé Supprimée : HKCU\Software\ilividtoolbarguid
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{3004627E-F8E9-4E8B-909D-316753CBA923}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{82E1477C-B154-48D3-9891-33D83C26BCD3}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{83FF80F4-8C74-4B80-B5BA-C8DDD434E5C4}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{8E5025C2-8EA3-430D-80B8-A14151068A6D}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{A7A6995D-6EE1-4FD1-A258-49395D5BF99C}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{B939CF93-F2CB-443D-956C-DC523D85C9DB}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{C1AF5FA5-852C-4C90-812E-A7F75E011D87}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{C1ED9DA0-AFD0-4B90-AC6A-D3874F591014}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{C2D64FF7-0AB8-4263-89C9-EA3B0F8F050C}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{C9A6357B-25CC-4BCF-96C1-78736985D412}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{D0F4A166-B8D4-48B8-9D63-80849FE137CB}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{EF5625A3-37AB-4BDB-9875-2A3D91CD0DFD}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{F34C9277-6577-4DFF-B2D7-7D58092F272F}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{FD72061E-9FDE-484D-A58A-0BAB4151CAD8}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{3004627E-F8E9-4E8B-909D-316753CBA923}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{82E1477C-B154-48D3-9891-33D83C26BCD3}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{83FF80F4-8C74-4B80-B5BA-C8DDD434E5C4}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{8E5025C2-8EA3-430D-80B8-A14151068A6D}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{A7A6995D-6EE1-4FD1-A258-49395D5BF99C}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{B939CF93-F2CB-443D-956C-DC523D85C9DB}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{C1AF5FA5-852C-4C90-812E-A7F75E011D87}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{C1ED9DA0-AFD0-4B90-AC6A-D3874F591014}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{C2D64FF7-0AB8-4263-89C9-EA3B0F8F050C}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{C9A6357B-25CC-4BCF-96C1-78736985D412}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{DF7770F7-832F-4BDF-B144-100EDDD0C3AE}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{EF5625A3-37AB-4BDB-9875-2A3D91CD0DFD}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{F34C9277-6577-4DFF-B2D7-7D58092F272F}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{FD72061E-9FDE-484D-A58A-0BAB4151CAD8}
Clé Supprimée : HKCU\Software\mysearchdial
Clé Supprimée : HKCU\Software\SearchProtect
Clé Supprimée : HKCU\Software\Wajam
Clé Supprimée : HKCU\Software\590d9dfe06aba43
Clé Supprimée : HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{9BB47C17-9C68-4BB3-B188-DD9AF0FD22}
Clé Supprimée : HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{9BB47C17-9C68-4BB3-B188-DD9AF0FD2406}
Clé Supprimée : HKLM\Software\Boxore
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\{1FAEE6D5-34F4-42AA-8025-3FD8F3EC4634}
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\{28A88B70-D874-4F73-BBBA-9B2B222FB7D6}
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\{32451DFC-C23B-4E12-866C-FC7982238504}
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\{39CB8175-E224-4446-8746-00566302DF8D}
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\{4D076AB4-7562-427A-B5D2-BD96E19DEE56}
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\{AC662AF2-4601-4A68-84DF-A3FE83F1A5F9}
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\{CFDAFE39-20CE-451D-BD45-A37452F39CF0}
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\{D97A8234-F2A2-4AD4-91D5-FECDB2C553AF}
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\BrowserConnection.dll
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\DNSBHO.dll
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\kt_bho_dll.dll
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\priam_bho.DLL
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\secman.DLL
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\YontooIEClient.DLL
Clé Supprimée : HKLM\SOFTWARE\Classes\Applications\ilividsetupv1.exe
Clé Supprimée : HKLM\SOFTWARE\Classes\BrowserConnection.Loader
Clé Supprimée : HKLM\SOFTWARE\Classes\BrowserConnection.Loader.1
Clé Supprimée : HKLM\SOFTWARE\Classes\delta.deltaappCore
Clé Supprimée : HKLM\SOFTWARE\Classes\delta.deltaappCore.1
Clé Supprimée : HKLM\SOFTWARE\Classes\delta.deltadskBnd
Clé Supprimée : HKLM\SOFTWARE\Classes\delta.deltadskBnd.1
Clé Supprimée : HKLM\SOFTWARE\Classes\delta.deltaHlpr
Clé Supprimée : HKLM\SOFTWARE\Classes\delta.deltaHlpr.1
Clé Supprimée : HKLM\SOFTWARE\Classes\DnsBHO.BHO
Clé Supprimée : HKLM\SOFTWARE\Classes\DnsBHO.BHO.1
Clé Supprimée : HKLM\SOFTWARE\Classes\esrv.deltaESrvc
Clé Supprimée : HKLM\SOFTWARE\Classes\esrv.deltaESrvc.1
Clé Supprimée : HKLM\SOFTWARE\Classes\esrv.mysearchdialESrvc
Clé Supprimée : HKLM\SOFTWARE\Classes\esrv.mysearchdialESrvc.1
Clé Supprimée : HKLM\SOFTWARE\Classes\iLividIEHelper.DNSGuard
Clé Supprimée : HKLM\SOFTWARE\Classes\iLividIEHelper.DNSGuard.1
Clé Supprimée : HKLM\Software\Classes\Installer\Features\64A6E60055D801F4BB8AC269354B72B8
Clé Supprimée : HKLM\Software\Classes\Installer\Products\64A6E60055D801F4BB8AC269354B72B8
Clé Supprimée : HKLM\SOFTWARE\Classes\kt_bho.KettleBho
Clé Supprimée : HKLM\SOFTWARE\Classes\kt_bho.KettleBho.1
Clé Supprimée : HKLM\SOFTWARE\Classes\MIME\Database\Content Type\application/x-vnd.software.oneclickctrl.8
Clé Supprimée : HKLM\SOFTWARE\Classes\mysearchdial.mysearchdialappCore
Clé Supprimée : HKLM\SOFTWARE\Classes\mysearchdial.mysearchdialappCore.1
Clé Supprimée : HKLM\SOFTWARE\Classes\mysearchdial.mysearchdialdskBnd
Clé Supprimée : HKLM\SOFTWARE\Classes\mysearchdial.mysearchdialdskBnd.1
Clé Supprimée : HKLM\SOFTWARE\Classes\mysearchdial.mysearchdialHlpr
Clé Supprimée : HKLM\SOFTWARE\Classes\mysearchdial.mysearchdialHlpr.1
Clé Supprimée : HKLM\SOFTWARE\Classes\SearchBar.Client
Clé Supprimée : HKLM\SOFTWARE\Classes\Software.OneClickCtrl.8
Clé Supprimée : HKLM\SOFTWARE\Classes\SoftwareUpdate.CoreClass
Clé Supprimée : HKLM\SOFTWARE\Classes\SoftwareUpdate.CoreClass.1
Clé Supprimée : HKLM\SOFTWARE\Classes\SoftwareUpdate.OnDemandCOMClassMachine
Clé Supprimée : HKLM\SOFTWARE\Classes\SoftwareUpdate.OnDemandCOMClassMachine.1.0
Clé Supprimée : HKLM\SOFTWARE\Classes\Toolbar.CT3128284
Clé Supprimée : HKLM\SOFTWARE\Classes\TypeLib\{095BFD3C-4602-4FE1-96F1-AEFAFBFD067D}
Clé Supprimée : HKLM\SOFTWARE\Classes\TypeLib\{11549FE4-7C5A-4C17-9FC3-56FC5162A994}
Clé Supprimée : HKLM\SOFTWARE\Classes\TypeLib\{1FDC0B61-91AC-4157-9B27-CAD9A09AB67E}
Clé Supprimée : HKLM\SOFTWARE\Classes\TypeLib\{39CB8175-E224-4446-8746-00566302DF8D}
Clé Supprimée : HKLM\SOFTWARE\Classes\TypeLib\{4599D05A-D545-4069-BB42-5895B4EAE05B}
Clé Supprimée : HKLM\SOFTWARE\Classes\TypeLib\{75E8DA27-44AF-40AE-927C-F2EEC99D65B1}
Clé Supprimée : HKLM\SOFTWARE\Classes\TypeLib\{86676E13-D6D8-4652-9FCF-F2047F1FB000}
Clé Supprimée : HKLM\SOFTWARE\Classes\TypeLib\{D372567D-67C1-4B29-B3F0-159B52B3E967}
Clé Supprimée : HKLM\SOFTWARE\Classes\wajam.WajamBHO
Clé Supprimée : HKLM\SOFTWARE\Classes\wajam.WajamBHO.1
Clé Supprimée : HKLM\SOFTWARE\Classes\wajam.WajamDownloader
Clé Supprimée : HKLM\SOFTWARE\Classes\wajam.WajamDownloader.1
Clé Supprimée : HKLM\SOFTWARE\Classes\YontooIEClient.Api
Clé Supprimée : HKLM\SOFTWARE\Classes\YontooIEClient.Api.1
Clé Supprimée : HKLM\SOFTWARE\Classes\YontooIEClient.Layers
Clé Supprimée : HKLM\SOFTWARE\Classes\YontooIEClient.Layers.1
Clé Supprimée : HKLM\Software\iLividSRTB
Clé Supprimée : HKLM\Software\InstallCore
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\boxore_RASAPI32
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\boxore_RASMANCS
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\ConduitInstaller_RASAPI32
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\ConduitInstaller_RASMANCS
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\datamngrUI_RASAPI32
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\datamngrUI_RASMANCS
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\iLivid_RASAPI32
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\iLivid_RASMANCS
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\iLividMediaBar_RASAPI32
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\iLividMediaBar_RASMANCS
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\iLividSetupV1_RASAPI32
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\iLividSetupV1_RASMANCS
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\WajamUpdater_RASAPI32
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\WajamUpdater_RASMANCS
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{42AEFAF9-09D6-4185-87AE-DEDF6E955CB4}
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{DF7770F7-832F-4BDF-B144-100EDDD0C3AE}
Clé Supprimée : HKLM\SOFTWARE\MozillaPlugins\@www.dlmanager.net/omaha/tools//Software Update;version=8
Clé Supprimée : HKLM\SOFTWARE\MozillaPlugins\@www.duuqu.com/omaha/tools//Duuqu Update;version=3
Clé Supprimée : HKLM\SOFTWARE\MozillaPlugins\@www.duuqu.com/omaha/tools//Duuqu Update;version=9
Clé Supprimée : HKLM\Software\mysearchdial
Clé Supprimée : HKLM\Software\SearchProtect
Clé Supprimée : HKLM\Software\Wajam
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\590d9dfe06aba43
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{092A2C6B-43EE-4F9F-8F8E-14ED5E11C14B}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{10DE7085-6A1E-4D41-A7BF-9AF93E351401}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{257A6158-1416-4B31-9BF8-29FF49F3814F}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{261DD098-8A3E-43D4-87AA-63324FA897D8}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{3004627E-F8E9-4E8B-909D-316753CBA923}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{32451DFC-C23B-4E12-866C-FC7982238504}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{3C471948-F874-49F5-B338-4F214A2EE0B1}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{42AEFAF9-09D6-4185-87AE-DEDF6E955CB4}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{431532BD-0AE1-4ABC-BE8C-919F3D1332E2}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{4ED063C9-4A0B-4B44-A9DC-23AFF424A0D3}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{4FCB4630-2A1C-4AA1-B422-345E8DC8A6DE}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{5D64294B-1341-4FE7-B6D8-7C36828D4DD5}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{66EEF543-A9AC-4A9D-AA3C-1ED148AC8EEE}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{80922EE0-8A76-46AE-95D5-BD3C3FE0708D}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{826D7151-8D99-434B-8540-082B8C2AE556}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{82E1477C-B154-48D3-9891-33D83C26BCD3}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{82E74373-58AB-47EB-B0F0-A1D82BB8EB5C}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{83FF80F4-8C74-4B80-B5BA-C8DDD434E5C4}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{86838207-681D-469D-9511-D0DCC6F19F9B}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{8E5025C2-8EA3-430D-80B8-A14151068A6D}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{99066096-8989-4612-841F-621A01D54AD7}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{9FF9AE6F-4553-41A7-B645-B0E88850EABF}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{A7A6995D-6EE1-4FD1-A258-49395D5BF99C}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{AC5C4189-A8A0-4C9D-8910-C9CEF8360077}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{B939CF93-F2CB-443D-956C-DC523D85C9DB}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{C1AF5FA5-852C-4C90-812E-A7F75E011D87}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{C1ED9DA0-AFD0-4B90-AC6A-D3874F591014}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{C2D64FF7-0AB8-4263-89C9-EA3B0F8F050C}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{C358B3D0-B911-41E3-A276-E7D43A6BA56D}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{C9A6357B-25CC-4BCF-96C1-78736985D412}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{CE4DB5A3-58E6-41F1-8761-47238DF4F468}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{DF7770F7-832F-4BDF-B144-100EDDD0C3AE}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{E97A663B-81A6-49C5-A6D3-BCB05BA1DE26}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{EF5625A3-37AB-4BDB-9875-2A3D91CD0DFD}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{F34C9277-6577-4DFF-B2D7-7D58092F272F}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{FD72061E-9FDE-484D-A58A-0BAB4151CAD8}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\CLSID\{FE9271F2-6EFD-44B0-A826-84C829536E93}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{10DE7085-6A1E-4D41-A7BF-9AF93E351401}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{1231839B-064E-4788-B865-465A1B5266FD}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{1AD27395-1659-4DFF-A319-2CFA243861A5}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{2DAC2231-CC35-482B-97C5-CED1D4185080}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{3F1CD84C-04A3-4EA0-9EA1-7D134FD66C82}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{3F83A9CA-B5F0-44EC-9357-35BB3E84B07F}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{431532BD-0AE1-4ABC-BE8C-919F3D1332E2}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{47E520EA-CAD2-4F51-8F30-613B3A1C33EB}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{57C91446-8D81-4156-A70E-624551442DE9}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{66EEF543-A9AC-4A9D-AA3C-1ED148AC8EEE}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{70AFB7B2-9FB5-4A70-905B-0E9576142E1D}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{736EF78E-5A04-46F9-893E-EDEC6EA5DF45}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{7A1BCE27-099C-4628-B63A-AEC00C6376B3}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{7AD65FD1-79E0-406D-B03C-DD7C14726D69}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{97DD820D-2E20-40AD-B01E-6730B2FCE630}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{AF3AFF7C-B9E9-48DD-9002-212B6DEAAC02}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{B177446D-54A4-4869-BABC-8566110B4BE0}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{D9D1DFC5-502D-43E4-B1BB-4D0B7841489A}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{DBE82879-914A-422F-BAE9-2ECC80BE536F}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{E0B07188-A528-4F9E-B2F7-C7FDE8680AE4}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{E12D7149-73EF-45E4-A1E9-99FD7DAE62D3}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{F05B12E1-ADE8-4485-B45B-898748B53C37}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Classes\Interface\{F2B184F1-547C-4EE9-BFC4-AC489C7077D9}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Google\Chrome\Extensions\ehdmaehkiiampolokajdcelladmnopgp
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Google\Chrome\Extensions\eooncjejnppfjjklapaamhcdmjbilmde
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Google\Chrome\Extensions\jpmbfleldcgkldadpdinhjjopdfpjfjp
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Google\Chrome\Extensions\niapdbllcanepiiimjjndipklodoedlc
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Google\Chrome\Extensions\pgafcinpmmpklohkojmllohdhomoefph
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{219046AE-358F-4CF1-B1FD-2B4DE83642A8}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{348C2DF3-1191-4C3E-92A6-B3A89A9D9C85}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{42AEFAF9-09D6-4185-87AE-DEDF6E955CB4}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{C2D64FF7-0AB8-4263-89C9-EA3B0F8F050C}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{F34C9277-6577-4DFF-B2D7-7D58092F272F}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\SearchScopes\{9BB47C17-9C68-4BB3-B188-DD9AF0FD22}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\SearchScopes\{9BB47C17-9C68-4BB3-B188-DD9AF0FD2406}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{83FF80F4-8C74-4B80-B5BA-C8DDD434E5C4}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{8E5025C2-8EA3-430D-80B8-A14151068A6D}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{A7A6995D-6EE1-4FD1-A258-49395D5BF99C}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{B939CF93-F2CB-443D-956C-DC523D85C9DB}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{C1AF5FA5-852C-4C90-812E-A7F75E011D87}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{C1ED9DA0-AFD0-4B90-AC6A-D3874F591014}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{C2D64FF7-0AB8-4263-89C9-EA3B0F8F050C}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{EF5625A3-37AB-4BDB-9875-2A3D91CD0DFD}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{F34C9277-6577-4DFF-B2D7-7D58092F272F}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{FD72061E-9FDE-484D-A58A-0BAB4151CAD8}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{006E6A46-8D55-4F10-BBA8-2C9653B4278B}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{15D2D75C-9CB2-4EFD-BAD7-B9B4CB4BC693}
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Delta
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Delta Chrome Toolbar
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\ilivid
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\ilividtoolbarguid
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\mysearchdial
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Search Results Toolbar
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\SearchProtect
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Wajam
Clé Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Wincore MediaBar
Clé Supprimée : HKLM\SYSTEM\CurrentControlSet\Services\Eventlog\Application\WajamUpdater
Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{83FF80F4-8C74-4B80-B5BA-C8DDD434E5C4}
Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{9FF9AE6F-4553-41A7-B645-B0E88850EABF}
Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{B939CF93-F2CB-443D-956C-DC523D85C9DB}
Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{C1ED9DA0-AFD0-4B90-AC6A-D3874F591014}
Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{CE4DB5A3-58E6-41F1-8761-47238DF4F468}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{10DE7085-6A1E-4D41-A7BF-9AF93E351401}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{1231839B-064E-4788-B865-465A1B5266FD}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{1AD27395-1659-4DFF-A319-2CFA243861A5}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{2DAC2231-CC35-482B-97C5-CED1D4185080}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{3F1CD84C-04A3-4EA0-9EA1-7D134FD66C82}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{3F83A9CA-B5F0-44EC-9357-35BB3E84B07F}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{431532BD-0AE1-4ABC-BE8C-919F3D1332E2}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{47E520EA-CAD2-4F51-8F30-613B3A1C33EB}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{57C91446-8D81-4156-A70E-624551442DE9}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{66EEF543-A9AC-4A9D-AA3C-1ED148AC8EEE}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{70AFB7B2-9FB5-4A70-905B-0E9576142E1D}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{7AD65FD1-79E0-406D-B03C-DD7C14726D69}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{97DD820D-2E20-40AD-B01E-6730B2FCE630}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{B177446D-54A4-4869-BABC-8566110B4BE0}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{D9D1DFC5-502D-43E4-B1BB-4D0B7841489A}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{E0B07188-A528-4F9E-B2F7-C7FDE8680AE4}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{F05B12E1-ADE8-4485-B45B-898748B53C37}
Clé Supprimée : HKLM\SOFTWARE\DataMngr
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{9BB47C17-9C68-4BB3-B188-DD9AF0FD22}
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{9BB47C17-9C68-4BB3-B188-DD9AF0FD2406}
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{83FF80F4-8C74-4B80-B5BA-C8DDD434E5C4}
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{B939CF93-F2CB-443D-956C-DC523D85C9DB}
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{C1ED9DA0-AFD0-4B90-AC6A-D3874F591014}
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UpgradeCodes\1C875DDE39636004CA8CDAEC335B4160
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UpgradeCodes\BA086F2D38A8E1A47912955A68B3AD24
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{889DF117-14D1-44EE-9F31-C5FB5D47F68B}
Clé Supprimée : HKLM\SOFTWARE\Tarma Installer
Clé Supprimée : HKU\.DEFAULT\Software\Microsoft\Internet Explorer\SearchScopes\{0ECDF796-C2DC-4D79-A620-CCE0C0A66CC9}
Donnée Supprimée : [x64] HKLM\..\Windows [AppInit_DLLs] = C:\PROGRA~2\SEARCH~1\Datamngr\x64\datamngr.dll
Donnée Supprimée : [x64] HKLM\..\Windows [AppInit_DLLs] = C:\PROGRA~2\SEARCH~1\Datamngr\x64\IEBHO.dll
Donnée Supprimée : [x64] HKLM\..\Windows [AppInit_DLLs] = C:\PROGRA~3\Wincert\WIN64C~1.DLL
Donnée Supprimée : HKLM\..\Windows [AppInit_DLLs] = c:\progra~3\browse~2\261249~1.132\{c16c1~1\browse~1.dll
Donnée Supprimée : HKLM\..\Windows [AppInit_DLLs] = C:\PROGRA~3\Wincert\WIN32C~1.DLL
Donnée Supprimée : HKLM\..\Windows [AppInit_DLLs] = xxC:\PROGRA~3\BROWSE~1\23762~1.17\{16CDF~1\BROWSE~1.DLL
Valeur Supprimée : HKCU\Software\Microsoft\Internet Explorer\SearchScopes [bProtectorDefaultScope]
Valeur Supprimée : HKCU\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser [{8E5025C2-8EA3-430D-80B8-A14151068A6D}]
Valeur Supprimée : HKCU\Software\Microsoft\Internet Explorer\URLSearchHooks [{8E5025C2-8EA3-430D-80B8-A14151068A6D}]
Valeur Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Run [searchprotect]
Valeur Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Run [Yontoo Desktop]
Valeur Supprimée : HKLM\SOFTWARE\Microsoft\Internet Explorer\URLSearchHooks [{8E5025C2-8EA3-430D-80B8-A14151068A6D}]
Valeur Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run [DataMngr]
Valeur Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run [SearchProtectAll]
Valeur Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Toolbar [{3004627E-F8E9-4E8B-909D-316753CBA923}]
Valeur Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Toolbar [{82E1477C-B154-48D3-9891-33D83C26BCD3}]
Valeur Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Toolbar [{8E5025C2-8EA3-430D-80B8-A14151068A6D}]
Valeur Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Toolbar [{C2D64FF7-0AB8-4263-89C9-EA3B0F8F050C}]
Valeur Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Toolbar [{C9A6357B-25CC-4BCF-96C1-78736985D412}]
Valeur Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Toolbar [{F34C9277-6577-4DFF-B2D7-7D58092F272F}]
Valeur Supprimée : HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Toolbar [10]
Valeur Supprimée : HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar [10]
***** [Navigateurs] *****
-\\ Internet Explorer v9.0.8112.16476
Remplacé : [HKLM\SOFTWARE\Microsoft\Internet Explorer\Main - Start Page] = hxxp://start.mysearchdial.com/?f=1&a=airmsd&cd=2XzuyEtN2Y1L1Qzu0FyEyC0DtDyE0Fzz0ByE0BtD0D0F0FtBtN0D0Tzu0CyEzyzztN1L2XzutBtFtBtFtCtFyCtCzztN1L1Czu1T1L1C1H1B1Q&cr=878607538&ir= --> hxxp://www.google.com
-\\ Google Chrome v22.0.1229.95
Fichier : C:\Users\Jimmy et laura\AppData\Local\Google\Chrome\User Data\Default\Preferences
Supprimée [l.35] : icon_url = "hxxp://start.mysearchdial.com/favicon.ico",
Supprimée [l.38] : keyword = "mysearchdial.com",
Supprimée [l.41] : search_url = "hxxp://start.mysearchdial.com/results.php?f=4&q={searchTerms}&a=airmsd&cd=2Xzuy[...]
AdwCleaner[S1].txt - [33011 octets] - [30/07/2013 12:22:31]
########## EOF - C:\AdwCleaner[S1].txt - [33072 octets] #########
par jimmyom52000
#7054
# AdwCleaner v3.001 - Rapport créé le 26/08/2013 à  18:21:53
# Mis à  jour le 24/08/2013 par Xplode
# Exécuté depuis : C:\Users\Jimmy et laura\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\SLET4SLQ\AdwCleaner.exe
# Option : Nettoyer
***** [ Services ] *****
Service Supprimé : APNMCP
Dossier Supprimé : C:\Kreapixel
Dossier Supprimé : C:\ProgramData\apn
Dossier Supprimé : C:\ProgramData\AskPartnerNetwork
Dossier Supprimé : C:\Program Files (x86)\AskPartnerNetwork
Dossier Supprimé : C:\Users\Jimmy et laura\AppData\Local\cre
Dossier Supprimé : C:\Users\JIMMYE~1\AppData\Local\Temp\apn
Fichier Supprimé : C:\Windows\System32\Tasks\EPUpdater
***** [ Raccourcis ] *****
***** [ Registre ] *****
Clé Supprimée : HKCU\Software\Google\Chrome\Extensions\pflphaooapbgpeakohlggbpidpppgdff
Clé Supprimée : HKLM\SOFTWARE\Google\Chrome\Extensions\pflphaooapbgpeakohlggbpidpppgdff
Clé Supprimée : [x64] HKLM\SOFTWARE\Google\Chrome\Extensions\pflphaooapbgpeakohlggbpidpppgdff
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\ApnSetup_RASAPI32
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\ApnSetup_RASMANCS
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\UpdateTask_RASAPI32
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\UpdateTask_RASMANCS
Valeur Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run [ApnTbMon]
Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{1D970ED5-3EDA-438D-BFFD-715931E2775B}
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{1D970ED5-3EDA-438D-BFFD-715931E2775B}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{1D970ED5-3EDA-438D-BFFD-715931E2775B}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{1D970ED5-3EDA-438D-BFFD-715931E2775B}
Clé Supprimée : HKCU\Software\AskPartnerNetwork
Clé Supprimée : HKCU\Software\Duuqu
Clé Supprimée : HKLM\Software\AskPartnerNetwork
Clé Supprimée : HKLM\Software\Duuqu
***** [ Navigateurs ] *****
[ Fichier : C:\Users\Jimmy et laura\AppData\Local\Google\Chrome\User Data\Default\preferences ]
AdwCleaner[R0].txt - [2588 octets] - [26/08/2013 18:19:54]
AdwCleaner[S0].txt - [2445 octets] - [26/08/2013 18:21:53]
########## EOF - C:\AdwCleaner\AdwCleaner[S0].txt - [2505 octets] ##########
par Evasion60
#7057
:hello: Bonsoir
Téléchargez et enregistrez ZHPDiag => https://telechargement.zebulon.fr/telech ... pdiag.html sur votre ordinateur.
Suite à  ces actions, trois raccourcis bureau sont présents. (MBRCheck,ZHPFix, ZHPDiag)
Cliquez ensuite sur bouton "Loupe +" en bas à  gauche, pour lancer un Diagnostic Full options
Le rapport ZHPDiag.txt sera aussi sur votre bureau. En cas de nécessité, il est sauvegardé dans C:\ZHP\ZHPDiag.txt
Vérifier dans le bloc notes (Notepad) > Format , que "Retour automatique à  la ligne" soit décoché.
Appuyer simultanément sur les touches CTRL et A pour tout sélectionner (surligné en bleu en général) et relàcher les touches.
Appuyer simultanément sur les touches CTRL et C pour copier le contenu du rapport dans le presse-papier de Windows et relàcher les touches.
Rendez vous sur le site Cjoint => https://WWW.Cjoint.com
Cliquez sur "Parcourir" pour recueillir le rapport qui est sur votre ordinateur.
Cochez "21 jours" pour la durée d'hébergement.
Cliquez sur "Créer le lien Cjoint"
Dans la fenêtre suivante, vous "copiez" votre lien Cjoint.
Vous "collez" ce lien dans votre réponse sur le forum qui vous aide.
A te lire avec son rapport hébergé ;)
