Ordinateur tres lent Réparation PC
par Elise
#6084
Bonjour sosvirus :)
Il y a 2 mois j'avais recu deja votre aide precieuse pour soigner mon netbook. Cette fois-ci c'est le PC d'une amie qui ne tourne pas tres rond. Tout est tres lent. Grace a Malwarebytes antibytes et adwcleaner c'est deja beaucoup plus rapide pour surfer.
Voici les diffenrents rapports
1) Malwarebytes
https://www.malwarebytes.org
Database version: v2013.04.04.07
Windows XP Service Pack 3 x86 NTFS
Internet Explorer 7.0.5730.13
admin :: READS-3 [administrator]
7/31/2013 3:02:24 AM
mbam-log-2013-07-31 (03-02-24).txt
Scan type: Quick scan
Scan options enabled: Memory | Startup | Registry | File System | Heuristics/Extra | Heuristics/Shuriken | PUP | PUM
Scan options disabled: P2P
Objects scanned: 214863
Time elapsed: 9 minute(s), 27 second(s)
Memory Processes Detected: 0
(No malicious items detected)
Memory Modules Detected: 0
Registry Keys Detected: 5
HKCR\CLSID\{f34c9277-6577-4dff-b2d7-7d58092f272f} (PUP.Datamngr) -> Quarantined and deleted successfully.
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{F34C9277-6577-4DFF-B2D7-7D58092F272F} (PUP.Datamngr) -> Quarantined and deleted successfully.
HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Settings\{F34C9277-6577-4DFF-B2D7-7D58092F272F} (PUP.Datamngr) -> Quarantined and deleted successfully.
HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{F34C9277-6577-4DFF-B2D7-7D58092F272F} (PUP.Datamngr) -> Quarantined and deleted successfully.
HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{F34C9277-6577-4DFF-B2D7-7D58092F272F} (PUP.Datamngr) -> Quarantined and deleted successfully.
Registry Values Detected: 3
HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar|{F34C9277-6577-4DFF-B2D7-7D58092F272F} (PUP.Datamngr) -> Data: Search-Results Toolbar -> Quarantined and deleted successfully.
HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar\{f34c9277-6577-4dff-b2d7-7d58092f272f} (PUP.Datamngr) -> Data: -> Quarantined and deleted successfully.
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer\Run|22493 (Trojan.Agent) -> Data: C:\DOCUME~1\ALLUSE~1\LOCALS~1\Temp\ccaiau.cmd -> Delete on reboot.
Registry Data Items Detected: 0
Folders Detected: 0
Files Detected: 1
C:\Program Files\Searchqu Toolbar\Datamngr\SRTOOL~1\searchresultsDx.dll (PUP.Datamngr) -> Quarantined and deleted successfully.
(end)
2) Adw cleaner
R1
# AdwCleaner v2.306 - Logfile created 01/01/2004 at 00:03:44
# Updated 19/07/2013 by Xplode
# Operating system : Microsoft Windows XP Service Pack 3 (32 bits)
# User : admin - READS-3
# Boot Mode : Normal
# Running from : C:\Documents and Settings\admin\Desktop\adwcleaner.exe
# Option [Search]
***** [Services] *****
Found : VideoDownloadConverter_4zService
***** [Files / Folders] *****
File Found : C:\Documents and Settings\All Users\Desktop\iLivid.lnk
File Found : C:\Program Files\Mozilla FireFox\searchplugins\Search_Results.xml
Folder Found : C:\Documents and Settings\admin\Application Data\Babylon
Folder Found : C:\Documents and Settings\admin\Application Data\BabylonToolbar
Folder Found : C:\Documents and Settings\admin\Application Data\DSite
Folder Found : C:\Documents and Settings\admin\Application Data\FromDocToPDF_65
Folder Found : C:\Documents and Settings\admin\Application Data\ilividtoolbarguid
Folder Found : C:\Documents and Settings\admin\Application Data\OpenCandy
Folder Found : C:\Documents and Settings\admin\Application Data\pdfforge
Folder Found : C:\Documents and Settings\admin\Application Data\searchresultstb
Folder Found : C:\Documents and Settings\admin\Application Data\VideoDownloadConverter_4z
Folder Found : C:\Documents and Settings\admin\Local Settings\Application Data\APN
Folder Found : C:\Documents and Settings\admin\Local Settings\Application Data\Babylon
Folder Found : C:\Documents and Settings\admin\Local Settings\Application Data\iac
Folder Found : C:\Documents and Settings\admin\Local Settings\Application Data\Ilivid Player
Folder Found : C:\Documents and Settings\admin\Local Settings\Application Data\OpenCandy
Folder Found : C:\Documents and Settings\admin\Local Settings\Application Data\PackageAware
Folder Found : C:\Documents and Settings\All Users\Application Data\Ask
Folder Found : C:\Documents and Settings\All Users\Application Data\Babylon
Folder Found : C:\Documents and Settings\All Users\Application Data\BabylonUpdater
Folder Found : C:\Documents and Settings\All Users\Application Data\boost_interprocess
Folder Found : C:\Program Files\BabylonToolbar
Folder Found : C:\Program Files\FromDocToPDF_65
Folder Found : C:\Program Files\FunWebProducts
Folder Found : C:\Program Files\Ilivid
Folder Found : C:\Program Files\mapsgalaxy_39
Folder Found : C:\Program Files\Mozilla Firefox\extensions\{1FD91A9C-410C-4090-BBCC-55D3450EF433}
Folder Found : C:\Program Files\QuotationCafe_45EI
Folder Found : C:\Program Files\Searchqu Toolbar
Folder Found : C:\Program Files\TelevisionFanaticEI
Folder Found : C:\Program Files\TotalRecipeSearch_14EI
Folder Found : C:\Program Files\VideoDownloadConverter_4z
***** [Registry] *****
Data Found : HKLM\..\Windows [AppInit_DLLs] = C:\PROGRA~1\SEARCH~1\Datamngr\datamngr.dll
Data Found : HKLM\..\Windows [AppInit_DLLs] = C:\PROGRA~1\SEARCH~1\Datamngr\IEBHO.dll
Key Found : HKCU\Software\APN DTX
Key Found : HKCU\Software\BabylonToolbar
Key Found : HKCU\Software\DataMngr
Key Found : HKCU\Software\DataMngr_Toolbar
Key Found : HKCU\Software\ilivid
Key Found : HKCU\Software\ilividtoolbarguid
Key Found : HKCU\Software\InstallCore
Key Found : HKCU\Software\MapsGalaxy_39
Key Found : HKCU\Software\Microsoft\Internet Explorer\MenuExt\&Search
Key Found : HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{0ECDF796-C2DC-4D79-A620-CCE0C0A66CC9}
Key Found : HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{171DEBEB-C3D4-40B7-AC73-056A5EBA4A7E}
Key Found : HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{9BB47C17-9C68-4BB3-B188-DD9AF0FD2406}
Key Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{25A3A431-30BB-47C8-AD6A-E1063801134F}
Key Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{98889811-442D-49DD-99D7-DC866BE87DBC}
Key Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{EF99BD32-C1FB-11D2-892F-0090271D4F88}
Key Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{02478D38-C3F9-4EFB-9B51-7695ECA05670}
Key Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{25A3A431-30BB-47C8-AD6A-E1063801134F}
Key Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{25CEE8EC-5730-41BC-8B58-22DDC8AB8C20}
Key Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{2EECD738-5844-4A99-B4B6-146BF802613B}
Key Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{312F84FB-8970-4FD3-BDDB-7012EAC4AFC9}
Key Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{3CA2F312-6F6E-4B53-A66E-4E65E497C8C0}
Key Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{8F0B76E1-4E46-427B-B55B-B90593468AC6}
Key Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{98889811-442D-49DD-99D7-DC866BE87DBC}
Key Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{9D717F81-9148-4F12-8568-69135F087DB0}
Key Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{C547C6C2-561B-4169-A2A5-20BA771CA93B}
Key Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{C66A678D-5E6C-4AF9-8F57-C6192F42CF74}
Key Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{D4027C7F-154A-4066-A1AD-4243D8127440}
Key Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{E1368B44-60A8-470F-9537-C1BC2390C8E3}
Key Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{EBF2BA02-9094-4C5A-858B-BB198F3D8DE2}
Key Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{EF99BD32-C1FB-11D2-892F-0090271D4F88}
Key Found : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{FD79F359-E577-46DB-AA74-D6E6B8B45BA8}
Key Found : HKCU\Software\Softonic
Key Found : HKLM\Software\Babylon
Key Found : HKLM\Software\BabylonToolbar
Key Found : HKLM\SOFTWARE\Classes\AppID\{09C554C3-109B-483C-A06B-F14172F1A947}
Key Found : HKLM\SOFTWARE\Classes\AppID\{35C1605E-438B-4D64-AAB1-8885F097A9B1}
Key Found : HKLM\SOFTWARE\Classes\AppID\{4E1E9D45-8BF9-4139-915C-9F83CC3D5921}
Key Found : HKLM\SOFTWARE\Classes\AppID\{B12E99ED-69BD-437C-86BE-C862B9E5444D}
Key Found : HKLM\SOFTWARE\Classes\AppID\{BDB69379-802F-4EAF-B541-F8DE92DD98DB}
Key Found : HKLM\SOFTWARE\Classes\AppID\{C26644C4-2A12-4CA6-8F2E-0EDE6CF018F3}
Key Found : HKLM\SOFTWARE\Classes\AppID\{D7EE8177-D51E-4F89-92B6-83EA2EC40800}
Key Found : HKLM\SOFTWARE\Classes\AppID\{D97A8234-F2A2-4AD4-91D5-FECDB2C553AF}
Key Found : HKLM\SOFTWARE\Classes\AppID\BrowserConnection.dll
Key Found : HKLM\SOFTWARE\Classes\AppID\escort.DLL
Key Found : HKLM\SOFTWARE\Classes\AppID\escortApp.DLL
Key Found : HKLM\SOFTWARE\Classes\AppID\escortEng.DLL
Key Found : HKLM\SOFTWARE\Classes\AppID\escorTlbr.DLL
Key Found : HKLM\SOFTWARE\Classes\AppID\esrv.EXE
Key Found : HKLM\SOFTWARE\Classes\b
Key Found : HKLM\SOFTWARE\Classes\Babylon.dskBnd
Key Found : HKLM\SOFTWARE\Classes\Babylon.dskBnd.1
Key Found : HKLM\SOFTWARE\Classes\bbylnApp.appCore
Key Found : HKLM\SOFTWARE\Classes\bbylnApp.appCore.1
Key Found : HKLM\SOFTWARE\Classes\bbylntlbr.bbylntlbrHlpr
Key Found : HKLM\SOFTWARE\Classes\bbylntlbr.bbylntlbrHlpr.1
Key Found : HKLM\SOFTWARE\Classes\BrowserConnection.Loader
Key Found : HKLM\SOFTWARE\Classes\BrowserConnection.Loader.1
Key Found : HKLM\SOFTWARE\Classes\CLSID\{13119113-0854-469D-807A-171568457991}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{1D4DB7D2-6EC9-47A3-BD87-1E41684E07BB}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{1F6F39C1-00A8-4752-A94C-D0EA92D978B6}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{25A3A431-30BB-47C8-AD6A-E1063801134F}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{291BCCC1-6890-484A-89D3-318C928DAC1B}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{2A1260C1-2964-453F-B0BA-FA429472EB5F}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{2EECD738-5844-4A99-B4B6-146BF802613B}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{312F84FB-8970-4FD3-BDDB-7012EAC4AFC9}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{33119133-0854-469D-807A-171568457991}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{363D5C92-10DC-4287-93E5-1832EECC48EC}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{3B41BE90-F731-4137-AFF3-2CA951E7F0D9}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{4128C64D-F0DD-4811-9405-D22294E8151F}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{5354D921-3F52-47C5-938D-77A2FB6DEFE7}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{66292684-B2C2-4C7C-B3D2-BF446E30744C}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{69407823-3494-4400-8D49-612549E8F4EE}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{6BFF4BCB-7A73-45A7-AC4C-389A34E1D1EF}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{71144427-1368-4D18-8DC9-2AE3CC4C4F83}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{8FCA5302-6D6D-4645-BF99-D43CF76CE474}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{97F2FF5B-260C-4CCF-834A-2DDA4E29E39E}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{98889811-442D-49DD-99D7-DC866BE87DBC}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{99E1F6FD-2E94-4CF6-8344-1BA63CD3BD9B}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{9D717F81-9148-4F12-8568-69135F087DB0}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{A40DC6C5-79D0-4CA8-A185-8FF989AF1115}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{B8276A94-891D-453C-9FF3-715C042A2575}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{C547C6C2-561B-4169-A2A5-20BA771CA93B}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{C66A678D-5E6C-4AF9-8F57-C6192F42CF74}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{CC1AC828-BB47-4361-AFB5-96EEE259DD87}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{DD385519-22E7-4BE2-8A8D-35C66DF4858E}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{E1164984-B567-47BD-A7FF-240C2594404A}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{E46C8196-B634-44A1-AF6E-957C64278AB1}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{ED345812-2722-4DCA-9976-D01832DB44EE}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{FD79F359-E577-46DB-AA74-D6E6B8B45BA8}
Key Found : HKLM\SOFTWARE\Classes\CLSID\{FFB9ADCB-8C79-4C29-81D3-74D46A93D370}
Key Found : HKLM\SOFTWARE\Classes\escort.escortIEPane
Key Found : HKLM\SOFTWARE\Classes\escort.escortIEPane.1
Key Found : HKLM\SOFTWARE\Classes\escort.escrtBtn.1
Key Found : HKLM\SOFTWARE\Classes\esrv.BabylonESrvc
Key Found : HKLM\SOFTWARE\Classes\esrv.BabylonESrvc.1
Key Found : HKLM\SOFTWARE\Classes\FunWebProductsInstaller.Start
Key Found : HKLM\SOFTWARE\Classes\FunWebProductsInstaller.Start.1
Key Found : HKLM\SOFTWARE\Classes\ilivid
Key Found : HKLM\SOFTWARE\Classes\Interface\{17B10E59-09E1-4C39-A738-6774D7AB7778}
Key Found : HKLM\SOFTWARE\Classes\Interface\{1AD2049E-E483-4425-8555-8E0775ACB631}
Key Found : HKLM\SOFTWARE\Classes\Interface\{1B730ACF-26A3-447B-9994-14AEE0EB72CC}
Key Found : HKLM\SOFTWARE\Classes\Interface\{23119123-0854-469D-807A-171568457991}
Key Found : HKLM\SOFTWARE\Classes\Interface\{2D73F2D0-2FAB-458E-977D-2F9050E0ED60}
Key Found : HKLM\SOFTWARE\Classes\Interface\{3B181CF2-878B-4758-8FBD-59D8AC5AB12D}
Key Found : HKLM\SOFTWARE\Classes\Interface\{3E9469AF-E866-4476-B767-810630F1F6E7}
Key Found : HKLM\SOFTWARE\Classes\Interface\{44C3C1DB-2127-433C-98EC-4C9412B5FC3A}
Key Found : HKLM\SOFTWARE\Classes\Interface\{47700C35-9E3E-4DAD-934C-0CE28A87237C}
Key Found : HKLM\SOFTWARE\Classes\Interface\{490A5A0F-1471-47FF-8BB5-719F1F5238AD}
Key Found : HKLM\SOFTWARE\Classes\Interface\{4D5132DD-BB2B-4249-B5E0-D145A8C982E1}
Key Found : HKLM\SOFTWARE\Classes\Interface\{6E4C89CF-3061-4EE4-B22A-B7A8AAEA5CB3}
Key Found : HKLM\SOFTWARE\Classes\Interface\{706D4A4B-184A-4434-B331-296B07493D2D}
Key Found : HKLM\SOFTWARE\Classes\Interface\{716E443D-7CAA-44F1-866B-F45D00E712CC}
Key Found : HKLM\SOFTWARE\Classes\Interface\{72063D77-7590-4DA9-A7F8-F5ECAF3632C4}
Key Found : HKLM\SOFTWARE\Classes\Interface\{7FC87AC5-FA93-476E-A32C-A941229DED0B}
Key Found : HKLM\SOFTWARE\Classes\Interface\{8BE10F21-185F-4CA0-B789-9921674C3993}
Key Found : HKLM\SOFTWARE\Classes\Interface\{94C0B25D-3359-4B10-B227-F96A77DB773F}
Key Found : HKLM\SOFTWARE\Classes\Interface\{B0B75FBA-7288-4FD3-A9EB-7EE27FA65599}
Key Found : HKLM\SOFTWARE\Classes\Interface\{B173667F-8395-4317-8DD6-45AD1FE00047}
Key Found : HKLM\SOFTWARE\Classes\Interface\{B32672B3-F656-46E0-B584-FE61C0BB6037}
Key Found : HKLM\SOFTWARE\Classes\Interface\{BFE569F7-646C-4512-969B-9BE3E580D393}
Key Found : HKLM\SOFTWARE\Classes\Interface\{C2434722-5C85-4CA0-BA69-1B67E7AB3D68}
Key Found : HKLM\SOFTWARE\Classes\Interface\{C2996524-2187-441F-A398-CD6CB6B3D020}
Key Found : HKLM\SOFTWARE\Classes\Interface\{E047E227-5342-4D94-80F7-CFB154BF55BD}
Key Found : HKLM\SOFTWARE\Classes\Interface\{E3F79BE9-24D4-4F4D-8C13-DF2C9899F82E}
Key Found : HKLM\SOFTWARE\Classes\Interface\{E77EEF95-3E83-4BB8-9C0D-4A5163774997}
Key Found : HKLM\SOFTWARE\Classes\Prod.cap
Key Found : HKLM\SOFTWARE\Classes\SearchQUIEHelper.DNSGuard
Key Found : HKLM\SOFTWARE\Classes\SearchQUIEHelper.DNSGuard.1
Key Found : HKLM\SOFTWARE\Classes\TotalRecipeSearch_14Installer.Start
Key Found : HKLM\SOFTWARE\Classes\TotalRecipeSearch_14Installer.Start.1
Key Found : HKLM\SOFTWARE\Classes\TypeLib\{03119103-0854-469D-807A-171568457991}
Key Found : HKLM\SOFTWARE\Classes\TypeLib\{1D4DB7D0-6EC9-47A3-BD87-1E41684E07BB}
Key Found : HKLM\SOFTWARE\Classes\TypeLib\{2D3826A1-F3E8-45D6-94B5-C26D8EC0073B}
Key Found : HKLM\SOFTWARE\Classes\TypeLib\{35C1605E-438B-4D64-AAB1-8885F097A9B1}
Key Found : HKLM\SOFTWARE\Classes\TypeLib\{3EE17DD1-E28B-4AED-A3B2-9C29CB2C19D6}
Key Found : HKLM\SOFTWARE\Classes\TypeLib\{4E1E9D45-8BF9-4139-915C-9F83CC3D5921}
Key Found : HKLM\SOFTWARE\Classes\TypeLib\{5B4144E1-B61D-495A-9A50-CD1A95D86D15}
Key Found : HKLM\SOFTWARE\Classes\TypeLib\{6A4BCABA-C437-4C76-A54E-AF31B8A76CB9}
Key Found : HKLM\SOFTWARE\Classes\TypeLib\{6E8BF012-2C85-4834-B10A-1B31AF173D70}
Key Found : HKLM\SOFTWARE\Classes\TypeLib\{886F93AD-3CBB-4424-8442-A7340243540F}
Key Found : HKLM\SOFTWARE\Classes\TypeLib\{8E5B29C2-BC6E-40BE-B881-AEE35B1F4035}
Key Found : HKLM\SOFTWARE\Classes\TypeLib\{AA289DBC-59B6-40A5-AC7D-C90DF850289C}
Key Found : HKLM\SOFTWARE\Classes\TypeLib\{CA723163-6FAD-43D4-8B93-0D8C52BD9974}
Key Found : HKLM\SOFTWARE\Classes\TypeLib\{D7EE8177-D51E-4F89-92B6-83EA2EC40800}
Key Found : HKLM\SOFTWARE\Classes\TypeLib\{F1F328EB-F5A5-432B-A54C-05F3EF5B0BD8}
Key Found : HKLM\SOFTWARE\Classes\TypeLib\{FB0E8A09-F08C-44CF-9E15-97ADAC016248}
Key Found : HKLM\SOFTWARE\Classes\TypeLib\{FE8DBB09-C3D3-4477-80CB-D38914B94BB8}
Key Found : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.DynamicBarButton
Key Found : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.DynamicBarButton.1
Key Found : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.FeedManager
Key Found : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.FeedManager.1
Key Found : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.HTMLMenu
Key Found : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.HTMLMenu.1
Key Found : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.HTMLPanel
Key Found : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.HTMLPanel.1
Key Found : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.MultipleButton
Key Found : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.MultipleButton.1
Key Found : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.PseudoTransparentPlugin
Key Found : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.PseudoTransparentPlugin.1
Key Found : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.Radio
Key Found : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.Radio.1
Key Found : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.RadioSettings
Key Found : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.RadioSettings.1
Key Found : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.ScriptButton
Key Found : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.ScriptButton.1
Key Found : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.SettingsPlugin
Key Found : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.SettingsPlugin.1
Key Found : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.SkinLauncher
Key Found : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.SkinLauncher.1
Key Found : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.ThirdPartyInstaller
Key Found : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.ThirdPartyInstaller.1
Key Found : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.UrlAlertButton
Key Found : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.UrlAlertButton.1
Key Found : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.XMLSessionPlugin
Key Found : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.XMLSessionPlugin.1
Key Found : HKLM\Software\DataMngr
Key Found : HKLM\Software\FirstSearch\Winamp Toolbar
Key Found : HKLM\Software\FunWebProducts
Key Found : HKLM\Software\ilivid
Key Found : HKLM\Software\MapsGalaxy_39
Key Found : HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{8375D9C8-634F-4ECB-8CF5-C7416BA5D542}
Key Found : HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{9BB47C17-9C68-4BB3-B188-DD9AF0FD2406}
Key Found : HKLM\SOFTWARE\Microsoft\Shared Tools\MSConfig\startupreg\ApnUpdater
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Management\ARPCache\BabylonToolbar
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Management\ARPCache\ilivid
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Management\ARPCache\ilividtoolbarguid
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Management\ARPCache\Search Settings
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Management\ARPCache\VideoDownloadConverter_4zbar Uninstall
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Management\ARPCache\Winamp Toolbar
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{02478D38-C3F9-4EFB-9B51-7695ECA05670}
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{2EECD738-5844-4A99-B4B6-146BF802613B}
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{312F84FB-8970-4FD3-BDDB-7012EAC4AFC9}
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{C547C6C2-561B-4169-A2A5-20BA771CA93B}
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{02478D38-C3F9-4EFB-9B51-7695ECA05670}
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{1D4DB7D2-6EC9-47A3-BD87-1E41684E07BB}
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{1F6F39C1-00A8-4752-A94C-D0EA92D978B6}
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{5354D921-3F52-47C5-938D-77A2FB6DEFE7}
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{71144427-1368-4D18-8DC9-2AE3CC4C4F83}
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{8F0B76E1-4E46-427B-B55B-B90593468AC6}
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{99E1F6FD-2E94-4CF6-8344-1BA63CD3BD9B}
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{E1368B44-60A8-470F-9537-C1BC2390C8E3}
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{ED345812-2722-4DCA-9976-D01832DB44EE}
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{EF99BD32-C1FB-11D2-892F-0090271D4F88}
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{FD79F359-E577-46DB-AA74-D6E6B8B45BA8}
Key Found : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\0E12F736682067FDE4D1158D5940A82E
Key Found : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\1A24B5BB8521B03E0C8D908F5ABC0AE6
Key Found : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\2B0D56C4F4C46D844A57FFED6F0D2852
Key Found : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\49D4375FE41653242AEA4C969E4E65E0
Key Found : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\6AA0923513360135B272E8289C5F13FA
Key Found : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\6F7467AF8F29C134CBBAB394ECCFDE96
Key Found : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\922525DCC5199162F8935747CA3D8E59
Key Found : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\BCDA179D619B91648538E3394CAC94CC
Key Found : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\D677B1A9671D4D4004F6F2A4469E86EA
Key Found : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\DD1402A9DD4215A43ABDE169A41AFA0E
Key Found : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\E36E114A0EAD2AD46B381D23AD69CDDF
Key Found : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\EF8E618DB3AEDFBB384561B5C548F65E
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\BabylonToolbar
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ilivid
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ilividtoolbarguid
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Search Settings
Key Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\VideoDownloadConverter_4zbar Uninstall
Key Found : HKLM\SOFTWARE\MozillaPlugins\@ei.TelevisionFanatic.com/Plugin
Key Found : HKLM\SOFTWARE\MozillaPlugins\@ei.TotalRecipeSearch_14.com/Plugin
Key Found : HKLM\SOFTWARE\MozillaPlugins\@funwebproducts.com/Plugin
Key Found : HKLM\SOFTWARE\MozillaPlugins\@MapsGalaxy_39.com/Plugin
Key Found : HKLM\Software\SearchquSRTB
Key Found : HKLM\Software\TotalRecipeSearch_14EI
Key Found : HKU\S-1-5-21-1960408961-1202660629-682003330-1003\Software\Microsoft\Internet Explorer\SearchScopes\{0ECDF796-C2DC-4D79-A620-CCE0C0A66CC9}
Key Found : HKU\S-1-5-21-1960408961-1202660629-682003330-1003\Software\Microsoft\Internet Explorer\SearchScopes\{171DEBEB-C3D4-40B7-AC73-056A5EBA4A7E}
Key Found : HKU\S-1-5-21-1960408961-1202660629-682003330-1003\Software\Microsoft\Internet Explorer\SearchScopes\{9BB47C17-9C68-4BB3-B188-DD9AF0FD2406}
Value Found : HKCU\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser [{C66A678D-5E6C-4AF9-8F57-C6192F42CF74}]
Value Found : HKCU\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser [{D4027C7F-154A-4066-A1AD-4243D8127440}]
Value Found : HKCU\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser [{EF99BD32-C1FB-11D2-892F-0090271D4F88}]
Value Found : HKCU\Software\Microsoft\Internet Explorer\URLSearchHooks [{93A3111F-4F74-4ED8-895E-D9708497629E}]
Value Found : HKCU\Software\Microsoft\Internet Explorer\URLSearchHooks [{EF99BD32-C1FB-11D2-892F-0090271D4F88}]
Value Found : HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar [{25A3A431-30BB-47C8-AD6A-E1063801134F}]
Value Found : HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar [{98889811-442D-49DD-99D7-DC866BE87DBC}]
Value Found : HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar [{C66A678D-5E6C-4AF9-8F57-C6192F42CF74}]
Value Found : HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar [10]
Value Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run [MapsGalaxy Search Scope Monitor]
Value Found : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run [VideoDownloadConverter Search Scope Monitor]
Value Found : HKLM\SOFTWARE\Mozilla\Firefox\Extensions [39ffxtbr@MapsGalaxy_39.com]
***** [Internet Browsers] *****
-\\ Internet Explorer v7.0.6000.21342
[OK] Registry is clean.
-\\ Google Chrome v28.0.1500.72
File : C:\Documents and Settings\LocalService\Local Settings\Application Data\Google\Chrome\User Data\Default\Preferences
[OK] File is clean.
File : C:\Documents and Settings\admin\Local Settings\Application Data\Google\Chrome\User Data\Default\Preferences
Found [l.29] : search_url = "hxxp://www.my-online-search.com/?q={searchTerms}&babsrc=SP_ofln&mntrId=4CEA001D92BA971E&cat=delta&dlb=2&affID=119370&tt=gc_",
Found [l.2231] : homepage = "hxxp://www.my-online-search.com/?babsrc=HP_ofln&mntrId=4CEA001D92BA971E&cat=delta&dlb=2&affID=119370&tt=gc_",
Found [l.2604] : urls_to_restore_on_startup = [ "hxxp://www.my-online-search.com/?babsrc=HP_ofln&mntrId=4CEA001D92BA971E&cat=delta&dlb=2&affID=119370&tt=gc_" ]
AdwCleaner[R1].txt - [24423 octets] - [01/01/2004 00:03:44]
########## EOF - C:\AdwCleaner[R1].txt - [24484 octets] ##########
S1
# AdwCleaner v2.306 - Logfile created 01/01/2004 at 00:06:10
# Option [Delete]
Stopped & Deleted : VideoDownloadConverter_4zService
Deleted on reboot : C:\Program Files\Mozilla Firefox\extensions\{1FD91A9C-410C-4090-BBCC-55D3450EF433}
File Deleted : C:\Documents and Settings\All Users\Desktop\iLivid.lnk
File Deleted : C:\Program Files\Mozilla FireFox\searchplugins\Search_Results.xml
Folder Deleted : C:\Documents and Settings\admin\Application Data\Babylon
Folder Deleted : C:\Documents and Settings\admin\Application Data\BabylonToolbar
Folder Deleted : C:\Documents and Settings\admin\Application Data\DSite
Folder Deleted : C:\Documents and Settings\admin\Application Data\FromDocToPDF_65
Folder Deleted : C:\Documents and Settings\admin\Application Data\ilividtoolbarguid
Folder Deleted : C:\Documents and Settings\admin\Application Data\OpenCandy
Folder Deleted : C:\Documents and Settings\admin\Application Data\pdfforge
Folder Deleted : C:\Documents and Settings\admin\Application Data\searchresultstb
Folder Deleted : C:\Documents and Settings\admin\Application Data\VideoDownloadConverter_4z
Folder Deleted : C:\Documents and Settings\admin\Local Settings\Application Data\APN
Folder Deleted : C:\Documents and Settings\admin\Local Settings\Application Data\Babylon
Folder Deleted : C:\Documents and Settings\admin\Local Settings\Application Data\iac
Folder Deleted : C:\Documents and Settings\admin\Local Settings\Application Data\Ilivid Player
Folder Deleted : C:\Documents and Settings\admin\Local Settings\Application Data\OpenCandy
Folder Deleted : C:\Documents and Settings\admin\Local Settings\Application Data\PackageAware
Folder Deleted : C:\Documents and Settings\All Users\Application Data\Ask
Folder Deleted : C:\Documents and Settings\All Users\Application Data\Babylon
Folder Deleted : C:\Documents and Settings\All Users\Application Data\BabylonUpdater
Folder Deleted : C:\Documents and Settings\All Users\Application Data\boost_interprocess
Folder Deleted : C:\Program Files\BabylonToolbar
Folder Deleted : C:\Program Files\FromDocToPDF_65
Folder Deleted : C:\Program Files\FunWebProducts
Folder Deleted : C:\Program Files\Ilivid
Folder Deleted : C:\Program Files\mapsgalaxy_39
Folder Deleted : C:\Program Files\QuotationCafe_45EI
Folder Deleted : C:\Program Files\Searchqu Toolbar
Folder Deleted : C:\Program Files\TelevisionFanaticEI
Folder Deleted : C:\Program Files\TotalRecipeSearch_14EI
Folder Deleted : C:\Program Files\VideoDownloadConverter_4z
Data Deleted : HKLM\..\Windows [AppInit_DLLs] = C:\PROGRA~1\SEARCH~1\Datamngr\datamngr.dll
Data Deleted : HKLM\..\Windows [AppInit_DLLs] = C:\PROGRA~1\SEARCH~1\Datamngr\IEBHO.dll
Key Deleted : HKCU\Software\APN DTX
Key Deleted : HKCU\Software\BabylonToolbar
Key Deleted : HKCU\Software\DataMngr
Key Deleted : HKCU\Software\DataMngr_Toolbar
Key Deleted : HKCU\Software\ilivid
Key Deleted : HKCU\Software\ilividtoolbarguid
Key Deleted : HKCU\Software\InstallCore
Key Deleted : HKCU\Software\MapsGalaxy_39
Key Deleted : HKCU\Software\Microsoft\Internet Explorer\MenuExt\&Search
Key Deleted : HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{0ECDF796-C2DC-4D79-A620-CCE0C0A66CC9}
Key Deleted : HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{171DEBEB-C3D4-40B7-AC73-056A5EBA4A7E}
Key Deleted : HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{9BB47C17-9C68-4BB3-B188-DD9AF0FD2406}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{25A3A431-30BB-47C8-AD6A-E1063801134F}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{98889811-442D-49DD-99D7-DC866BE87DBC}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{EF99BD32-C1FB-11D2-892F-0090271D4F88}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{02478D38-C3F9-4EFB-9B51-7695ECA05670}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{25A3A431-30BB-47C8-AD6A-E1063801134F}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{25CEE8EC-5730-41BC-8B58-22DDC8AB8C20}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{2EECD738-5844-4A99-B4B6-146BF802613B}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{312F84FB-8970-4FD3-BDDB-7012EAC4AFC9}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{3CA2F312-6F6E-4B53-A66E-4E65E497C8C0}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{8F0B76E1-4E46-427B-B55B-B90593468AC6}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{98889811-442D-49DD-99D7-DC866BE87DBC}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{9D717F81-9148-4F12-8568-69135F087DB0}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{C547C6C2-561B-4169-A2A5-20BA771CA93B}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{C66A678D-5E6C-4AF9-8F57-C6192F42CF74}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{D4027C7F-154A-4066-A1AD-4243D8127440}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{E1368B44-60A8-470F-9537-C1BC2390C8E3}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{EBF2BA02-9094-4C5A-858B-BB198F3D8DE2}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{EF99BD32-C1FB-11D2-892F-0090271D4F88}
Key Deleted : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{FD79F359-E577-46DB-AA74-D6E6B8B45BA8}
Key Deleted : HKCU\Software\Softonic
Key Deleted : HKLM\Software\Babylon
Key Deleted : HKLM\Software\BabylonToolbar
Key Deleted : HKLM\SOFTWARE\Classes\AppID\{09C554C3-109B-483C-A06B-F14172F1A947}
Key Deleted : HKLM\SOFTWARE\Classes\AppID\{35C1605E-438B-4D64-AAB1-8885F097A9B1}
Key Deleted : HKLM\SOFTWARE\Classes\AppID\{4E1E9D45-8BF9-4139-915C-9F83CC3D5921}
Key Deleted : HKLM\SOFTWARE\Classes\AppID\{B12E99ED-69BD-437C-86BE-C862B9E5444D}
Key Deleted : HKLM\SOFTWARE\Classes\AppID\{BDB69379-802F-4EAF-B541-F8DE92DD98DB}
Key Deleted : HKLM\SOFTWARE\Classes\AppID\{C26644C4-2A12-4CA6-8F2E-0EDE6CF018F3}
Key Deleted : HKLM\SOFTWARE\Classes\AppID\{D7EE8177-D51E-4F89-92B6-83EA2EC40800}
Key Deleted : HKLM\SOFTWARE\Classes\AppID\{D97A8234-F2A2-4AD4-91D5-FECDB2C553AF}
Key Deleted : HKLM\SOFTWARE\Classes\AppID\BrowserConnection.dll
Key Deleted : HKLM\SOFTWARE\Classes\AppID\escort.DLL
Key Deleted : HKLM\SOFTWARE\Classes\AppID\escortApp.DLL
Key Deleted : HKLM\SOFTWARE\Classes\AppID\escortEng.DLL
Key Deleted : HKLM\SOFTWARE\Classes\AppID\escorTlbr.DLL
Key Deleted : HKLM\SOFTWARE\Classes\AppID\esrv.EXE
Key Deleted : HKLM\SOFTWARE\Classes\b
Key Deleted : HKLM\SOFTWARE\Classes\Babylon.dskBnd
Key Deleted : HKLM\SOFTWARE\Classes\Babylon.dskBnd.1
Key Deleted : HKLM\SOFTWARE\Classes\bbylnApp.appCore
Key Deleted : HKLM\SOFTWARE\Classes\bbylnApp.appCore.1
Key Deleted : HKLM\SOFTWARE\Classes\bbylntlbr.bbylntlbrHlpr
Key Deleted : HKLM\SOFTWARE\Classes\bbylntlbr.bbylntlbrHlpr.1
Key Deleted : HKLM\SOFTWARE\Classes\BrowserConnection.Loader
Key Deleted : HKLM\SOFTWARE\Classes\BrowserConnection.Loader.1
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{13119113-0854-469D-807A-171568457991}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{1D4DB7D2-6EC9-47A3-BD87-1E41684E07BB}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{1F6F39C1-00A8-4752-A94C-D0EA92D978B6}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{25A3A431-30BB-47C8-AD6A-E1063801134F}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{291BCCC1-6890-484A-89D3-318C928DAC1B}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{2A1260C1-2964-453F-B0BA-FA429472EB5F}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{2EECD738-5844-4A99-B4B6-146BF802613B}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{312F84FB-8970-4FD3-BDDB-7012EAC4AFC9}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{33119133-0854-469D-807A-171568457991}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{363D5C92-10DC-4287-93E5-1832EECC48EC}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{3B41BE90-F731-4137-AFF3-2CA951E7F0D9}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{4128C64D-F0DD-4811-9405-D22294E8151F}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{5354D921-3F52-47C5-938D-77A2FB6DEFE7}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{66292684-B2C2-4C7C-B3D2-BF446E30744C}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{69407823-3494-4400-8D49-612549E8F4EE}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{6BFF4BCB-7A73-45A7-AC4C-389A34E1D1EF}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{71144427-1368-4D18-8DC9-2AE3CC4C4F83}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{8FCA5302-6D6D-4645-BF99-D43CF76CE474}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{97F2FF5B-260C-4CCF-834A-2DDA4E29E39E}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{98889811-442D-49DD-99D7-DC866BE87DBC}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{99E1F6FD-2E94-4CF6-8344-1BA63CD3BD9B}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{9D717F81-9148-4F12-8568-69135F087DB0}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{A40DC6C5-79D0-4CA8-A185-8FF989AF1115}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{B8276A94-891D-453C-9FF3-715C042A2575}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{C547C6C2-561B-4169-A2A5-20BA771CA93B}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{C66A678D-5E6C-4AF9-8F57-C6192F42CF74}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{CC1AC828-BB47-4361-AFB5-96EEE259DD87}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{DD385519-22E7-4BE2-8A8D-35C66DF4858E}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{E1164984-B567-47BD-A7FF-240C2594404A}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{E46C8196-B634-44A1-AF6E-957C64278AB1}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{ED345812-2722-4DCA-9976-D01832DB44EE}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{FD79F359-E577-46DB-AA74-D6E6B8B45BA8}
Key Deleted : HKLM\SOFTWARE\Classes\CLSID\{FFB9ADCB-8C79-4C29-81D3-74D46A93D370}
Key Deleted : HKLM\SOFTWARE\Classes\escort.escortIEPane
Key Deleted : HKLM\SOFTWARE\Classes\escort.escortIEPane.1
Key Deleted : HKLM\SOFTWARE\Classes\escort.escrtBtn.1
Key Deleted : HKLM\SOFTWARE\Classes\esrv.BabylonESrvc
Key Deleted : HKLM\SOFTWARE\Classes\esrv.BabylonESrvc.1
Key Deleted : HKLM\SOFTWARE\Classes\FunWebProductsInstaller.Start
Key Deleted : HKLM\SOFTWARE\Classes\FunWebProductsInstaller.Start.1
Key Deleted : HKLM\SOFTWARE\Classes\ilivid
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{17B10E59-09E1-4C39-A738-6774D7AB7778}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{1AD2049E-E483-4425-8555-8E0775ACB631}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{1B730ACF-26A3-447B-9994-14AEE0EB72CC}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{23119123-0854-469D-807A-171568457991}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{2D73F2D0-2FAB-458E-977D-2F9050E0ED60}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{3B181CF2-878B-4758-8FBD-59D8AC5AB12D}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{3E9469AF-E866-4476-B767-810630F1F6E7}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{44C3C1DB-2127-433C-98EC-4C9412B5FC3A}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{47700C35-9E3E-4DAD-934C-0CE28A87237C}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{490A5A0F-1471-47FF-8BB5-719F1F5238AD}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{4D5132DD-BB2B-4249-B5E0-D145A8C982E1}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{6E4C89CF-3061-4EE4-B22A-B7A8AAEA5CB3}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{706D4A4B-184A-4434-B331-296B07493D2D}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{716E443D-7CAA-44F1-866B-F45D00E712CC}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{72063D77-7590-4DA9-A7F8-F5ECAF3632C4}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{7FC87AC5-FA93-476E-A32C-A941229DED0B}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{8BE10F21-185F-4CA0-B789-9921674C3993}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{94C0B25D-3359-4B10-B227-F96A77DB773F}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{B0B75FBA-7288-4FD3-A9EB-7EE27FA65599}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{B173667F-8395-4317-8DD6-45AD1FE00047}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{B32672B3-F656-46E0-B584-FE61C0BB6037}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{BFE569F7-646C-4512-969B-9BE3E580D393}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{C2434722-5C85-4CA0-BA69-1B67E7AB3D68}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{C2996524-2187-441F-A398-CD6CB6B3D020}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{E047E227-5342-4D94-80F7-CFB154BF55BD}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{E3F79BE9-24D4-4F4D-8C13-DF2C9899F82E}
Key Deleted : HKLM\SOFTWARE\Classes\Interface\{E77EEF95-3E83-4BB8-9C0D-4A5163774997}
Key Deleted : HKLM\SOFTWARE\Classes\Prod.cap
Key Deleted : HKLM\SOFTWARE\Classes\SearchQUIEHelper.DNSGuard
Key Deleted : HKLM\SOFTWARE\Classes\SearchQUIEHelper.DNSGuard.1
Key Deleted : HKLM\SOFTWARE\Classes\TotalRecipeSearch_14Installer.Start
Key Deleted : HKLM\SOFTWARE\Classes\TotalRecipeSearch_14Installer.Start.1
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{03119103-0854-469D-807A-171568457991}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{1D4DB7D0-6EC9-47A3-BD87-1E41684E07BB}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{2D3826A1-F3E8-45D6-94B5-C26D8EC0073B}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{35C1605E-438B-4D64-AAB1-8885F097A9B1}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{3EE17DD1-E28B-4AED-A3B2-9C29CB2C19D6}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{4E1E9D45-8BF9-4139-915C-9F83CC3D5921}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{5B4144E1-B61D-495A-9A50-CD1A95D86D15}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{6A4BCABA-C437-4C76-A54E-AF31B8A76CB9}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{6E8BF012-2C85-4834-B10A-1B31AF173D70}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{886F93AD-3CBB-4424-8442-A7340243540F}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{8E5B29C2-BC6E-40BE-B881-AEE35B1F4035}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{AA289DBC-59B6-40A5-AC7D-C90DF850289C}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{CA723163-6FAD-43D4-8B93-0D8C52BD9974}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{D7EE8177-D51E-4F89-92B6-83EA2EC40800}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{F1F328EB-F5A5-432B-A54C-05F3EF5B0BD8}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{FB0E8A09-F08C-44CF-9E15-97ADAC016248}
Key Deleted : HKLM\SOFTWARE\Classes\TypeLib\{FE8DBB09-C3D3-4477-80CB-D38914B94BB8}
Key Deleted : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.DynamicBarButton
Key Deleted : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.DynamicBarButton.1
Key Deleted : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.FeedManager
Key Deleted : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.FeedManager.1
Key Deleted : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.HTMLMenu
Key Deleted : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.HTMLMenu.1
Key Deleted : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.HTMLPanel
Key Deleted : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.HTMLPanel.1
Key Deleted : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.MultipleButton
Key Deleted : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.MultipleButton.1
Key Deleted : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.PseudoTransparentPlugin
Key Deleted : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.PseudoTransparentPlugin.1
Key Deleted : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.Radio
Key Deleted : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.Radio.1
Key Deleted : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.RadioSettings
Key Deleted : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.RadioSettings.1
Key Deleted : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.ScriptButton
Key Deleted : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.ScriptButton.1
Key Deleted : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.SettingsPlugin
Key Deleted : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.SettingsPlugin.1
Key Deleted : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.SkinLauncher
Key Deleted : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.SkinLauncher.1
Key Deleted : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.ThirdPartyInstaller
Key Deleted : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.ThirdPartyInstaller.1
Key Deleted : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.UrlAlertButton
Key Deleted : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.UrlAlertButton.1
Key Deleted : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.XMLSessionPlugin
Key Deleted : HKLM\SOFTWARE\Classes\VideoDownloadConverter_4z.XMLSessionPlugin.1
Key Deleted : HKLM\Software\DataMngr
Key Deleted : HKLM\Software\FirstSearch\Winamp Toolbar
Key Deleted : HKLM\Software\FunWebProducts
Key Deleted : HKLM\Software\ilivid
Key Deleted : HKLM\Software\MapsGalaxy_39
Key Deleted : HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{8375D9C8-634F-4ECB-8CF5-C7416BA5D542}
Key Deleted : HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{9BB47C17-9C68-4BB3-B188-DD9AF0FD2406}
Key Deleted : HKLM\SOFTWARE\Microsoft\Shared Tools\MSConfig\startupreg\ApnUpdater
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Management\ARPCache\BabylonToolbar
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Management\ARPCache\ilivid
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Management\ARPCache\ilividtoolbarguid
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Management\ARPCache\Search Settings
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Management\ARPCache\VideoDownloadConverter_4zbar Uninstall
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Management\ARPCache\Winamp Toolbar
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{02478D38-C3F9-4EFB-9B51-7695ECA05670}
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{2EECD738-5844-4A99-B4B6-146BF802613B}
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{312F84FB-8970-4FD3-BDDB-7012EAC4AFC9}
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{C547C6C2-561B-4169-A2A5-20BA771CA93B}
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{02478D38-C3F9-4EFB-9B51-7695ECA05670}
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{1D4DB7D2-6EC9-47A3-BD87-1E41684E07BB}
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{1F6F39C1-00A8-4752-A94C-D0EA92D978B6}
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{5354D921-3F52-47C5-938D-77A2FB6DEFE7}
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{71144427-1368-4D18-8DC9-2AE3CC4C4F83}
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{8F0B76E1-4E46-427B-B55B-B90593468AC6}
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{99E1F6FD-2E94-4CF6-8344-1BA63CD3BD9B}
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{E1368B44-60A8-470F-9537-C1BC2390C8E3}
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{ED345812-2722-4DCA-9976-D01832DB44EE}
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{EF99BD32-C1FB-11D2-892F-0090271D4F88}
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{FD79F359-E577-46DB-AA74-D6E6B8B45BA8}
Key Deleted : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\0E12F736682067FDE4D1158D5940A82E
Key Deleted : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\1A24B5BB8521B03E0C8D908F5ABC0AE6
Key Deleted : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\2B0D56C4F4C46D844A57FFED6F0D2852
Key Deleted : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\49D4375FE41653242AEA4C969E4E65E0
Key Deleted : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\6AA0923513360135B272E8289C5F13FA
Key Deleted : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\6F7467AF8F29C134CBBAB394ECCFDE96
Key Deleted : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\922525DCC5199162F8935747CA3D8E59
Key Deleted : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\BCDA179D619B91648538E3394CAC94CC
Key Deleted : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\D677B1A9671D4D4004F6F2A4469E86EA
Key Deleted : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\DD1402A9DD4215A43ABDE169A41AFA0E
Key Deleted : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\E36E114A0EAD2AD46B381D23AD69CDDF
Key Deleted : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\EF8E618DB3AEDFBB384561B5C548F65E
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\BabylonToolbar
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ilivid
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\ilividtoolbarguid
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Search Settings
Key Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\VideoDownloadConverter_4zbar Uninstall
Key Deleted : HKLM\SOFTWARE\MozillaPlugins\@ei.TelevisionFanatic.com/Plugin
Key Deleted : HKLM\SOFTWARE\MozillaPlugins\@ei.TotalRecipeSearch_14.com/Plugin
Key Deleted : HKLM\SOFTWARE\MozillaPlugins\@funwebproducts.com/Plugin
Key Deleted : HKLM\SOFTWARE\MozillaPlugins\@MapsGalaxy_39.com/Plugin
Key Deleted : HKLM\Software\SearchquSRTB
Key Deleted : HKLM\Software\TotalRecipeSearch_14EI
Value Deleted : HKCU\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser [{C66A678D-5E6C-4AF9-8F57-C6192F42CF74}]
Value Deleted : HKCU\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser [{D4027C7F-154A-4066-A1AD-4243D8127440}]
Value Deleted : HKCU\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser [{EF99BD32-C1FB-11D2-892F-0090271D4F88}]
Value Deleted : HKCU\Software\Microsoft\Internet Explorer\URLSearchHooks [{93A3111F-4F74-4ED8-895E-D9708497629E}]
Value Deleted : HKCU\Software\Microsoft\Internet Explorer\URLSearchHooks [{EF99BD32-C1FB-11D2-892F-0090271D4F88}]
Value Deleted : HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar [{25A3A431-30BB-47C8-AD6A-E1063801134F}]
Value Deleted : HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar [{98889811-442D-49DD-99D7-DC866BE87DBC}]
Value Deleted : HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar [{C66A678D-5E6C-4AF9-8F57-C6192F42CF74}]
Value Deleted : HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar [10]
Value Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run [MapsGalaxy Search Scope Monitor]
Value Deleted : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run [VideoDownloadConverter Search Scope Monitor]
Value Deleted : HKLM\SOFTWARE\Mozilla\Firefox\Extensions [39ffxtbr@MapsGalaxy_39.com]
[OK] File is clean.
Deleted [l.29] : search_url = "hxxp://www.my-online-search.com/?q={searchTerms}&babsrc=SP_ofln&mntrId=4CEA001D[...]
Deleted [l.2231] : homepage = "hxxp://www.my-online-search.com/?babsrc=HP_ofln&mntrId=4CEA001D92BA971E&cat=delta&dl[...]
Deleted [l.2604] : urls_to_restore_on_startup = [ "hxxp://www.my-online-search.com/?babsrc=HP_ofln&mntrId=4CEA00[...]
AdwCleaner[R1].txt - [24554 octets] - [01/01/2004 00:03:44]
AdwCleaner[R2].txt - [24615 octets] - [01/01/2004 00:05:02]
AdwCleaner[R3].txt - [24676 octets] - [01/01/2004 00:06:01]
AdwCleaner[S1].txt - [24612 octets] - [01/01/2004 00:06:10]
########## EOF - C:\AdwCleaner[S1].txt - [24673 octets] ##########
3)ZHP diag
https://cjoint.com/data/0GFjSA5NOiv.htm
Que pouvons-nous faire ensuite ?
Merci beaucoup d'avance
Elise
par Evasion60
#6085
:hello: Bonjour Elise
Je vais te prendre en charge
Je regarde tout cela et reviens ;)
par Evasion60
#6086
:hello: Re
[MD5.C04E676CDA28972D41B85256A8D10483] - (.MindSpark - MindSpark Toolbar Platform SearchScope Moni.) -- C:\Program Files\QuotationCafe_45\bar\1.bin\45SrchMn.exe   [38440] [PID.2356]
P2 - FPN: [HKLM] [@FromDocToPDF_65.com/Plugin] - (...) -- C:\Program Files\FromDocToPDF_65\bar\1.bin\NP65Stub.dll (.not file.)    => Fichier absent
P2 - FPN: [HKLM] [@QuotationCafe_45.com/Plugin] - (.MindSpark - MindSpark Toolbar Platform Plugin Stub for 32-bit Windows.) -- C:\Program Files\QuotationCafe_45\bar\1.bin\NP45Stub.dll
P2 - FPN: [HKLM] [@VideoDownloadConverter_4z.com/Plugin] - (...) -- C:\Program Files\VideoDownloadConverter_4z\bar\1.bin\NP4zStub.dll (.not file.)   =>Adware.VideoDownloadConverter
O2 - BHO: Toolbar BHO - {1e91a655-bb4b-4693-a05e-2edebc4c9d89} . (...) -- C:\PROGRA~1\MAPSGA~2\bar\1.bin\39bar.dll (.not file.)    => Fichier absent
O2 - BHO: Search Assistant BHO - {8561f2a1-d885-4852-8289-81ae4ad0ad99} . (.MindSpark - MindSpark Search Assistant.) -- C:\Program Files\QuotationCafe_45\bar\1.bin\45SrcAs.dll
O2 - BHO: Flip BHO - {63E60077-EDE9-427a-BAD0-2ED15FADA0A8} . (.Unknown owner - Flip - Connect with friends.) -- C:\Program Files\Discovery Tools\ietb.dll
O2 - BHO: Search Assistant BHO - {71c1d63a-c944-428a-a5bd-ba513190e5d2} . (...) -- C:\Program Files\MapsGalaxy_39\bar\1.bin\39SrcAs.dll (.not file.)   =>Adware.MapsGalaxy
O2 - BHO: Toolbar BHO - {8619595f-4eef-4164-b040-fb7436301a06} . (.MindSpark - MindSpark Toolbar Platform.) -- C:\Program Files\QuotationCafe_45\bar\1.bin\45bar.dll
O2 - BHO: Toolbar BHO - {a235e1e3-6296-4710-af39-104a7faa6c7c} . (...) -- C:\PROGRA~1\FROMDO~2\bar\1.bin\65bar.dll (.not file.)    => Fichier absent
O2 - BHO: Search Assistant BHO - {f236ca79-3123-4afb-9f74-e98117ad5625} . (...) -- C:\Program Files\FromDocToPDF_65\bar\1.bin\65SrcAs.dll (.not file.)    => Fichier absent
O3 - Toolbar: QuotationCafe - [HKLM]{99bced2f-1db3-4ecd-8e35-8906428a6cfe} . (.MindSpark - MindSpark Toolbar Platform.) -- C:\Program Files\QuotationCafe_45\bar\1.bin\45bar.dll
O3 - Toolbar: MapsGalaxy - [HKLM]{364ea597-e728-4ce4-bb4a-ed846ef47970} . (...) -- C:\Program Files\MapsGalaxy_39\bar\1.bin\39bar.dll   =>Adware.MapsGalaxy
O3 - Toolbar: VideoDownloadConverter - [HKLM]{48586425-6bb7-4f51-8dc6-38c88e3ebb58} . (...) -- C:\Program Files\VideoDownloadConverter_4z\bar\1.bin\4zbar.dll   =>Adware.VideoDownloadConverter
O3 - Toolbar\WebBrowser: (no name) - [HKCU]{01E04581-4EEE-11D0-BFE9-00AA005B4383} Orphean Key    => Microsoft Internet Explorer Address Bar
O3 - Toolbar\WebBrowser: (no name) - [HKCU]{0E5CBF21-D15F-11D0-8301-00AA005B4383} Orphean Key    => Internet Explorer Links Bar
O3 - Toolbar\WebBrowser: (no name) - [HKCU]{EE5D279F-081B-4404-994D-C6B60AAEBA6D} Orphean Key    => Epson Web-To-Page
O3 - Toolbar\WebBrowser: (no name) - [HKCU]{F2CF5485-4E02-4F68-819C-B92DE9277049} Orphean Key
O3 - Toolbar\WebBrowser: (no name) - [HKCU]{364EA597-E728-4CE4-BB4A-ED846EF47970} Orphean Key    => Orphean Key not necessary
O3 - Toolbar\WebBrowser: (no name) - [HKCU]{48586425-6BB7-4F51-8DC6-38C88E3EBB58} Orphean Key    => Orphean Key not necessary
O3 - Toolbar\WebBrowser: (no name) - [HKCU]{61628E2A-4FF9-4454-992D-D92A8CD27399} Orphean Key    => Orphean Key not necessary
O4 - HKLM\..\Run: [FromDocToPDF Search Scope Monitor] C:\Program Files\FROMDO~2\bar\1.bin\65srchmn.exe (.not file.)    => Fichier absent
O4 - HKLM\..\Run: [QuotationCafe Search Scope Monitor] . (.MindSpark - MindSpark Toolbar Platform SearchScope Moni.) -- C:\Program Files\QuotationCafe_45\bar\1.bin\45SrchMn.exe
O4 - HKLM\..\Run: [FromDocToPDF_65 Browser Plugin Loader] C:\Program Files\FROMDO~2\bar\1.bin\65brmon.exe (.not file.)    => Fichier absent
O4 - GS\Desktop: Shortcut to Annual Update B &DC.lnk . (...)  -- I:\Annual Update B &DC.doc  (.not file.)    => Fichier absent
O4 - GS\Desktop: Shortcut to mis- data.lnk . (...)  -- \Reads-01\d\MAHALIR THITTAM\2011 - 12\mis- data.xlsx  (.not file.)    => Fichier absent
O4 - GS\Desktop: Shortcut to Scrap.lnk . (...)  -- D:\sponcership letter\july-2013\Scrap.shs  (.not file.)    => Fichier absent
O23 - Service: FromDocToPDFService (FromDocToPDF_65Service) . (...) - C:\Program Files\FROMDO~2\bar\1.bin\65barsvc.exe (.not file.)    => Fichier absent
O23 - Service: QuotationCafeService (QuotationCafe_45Service) . (.COMPANYVERS_NAME - PRODUCTVERS_TITLE.) - C:\Program Files\QuotationCafe_45\bar\1.bin\45barsvc.exe
O23 - Service: MapsGalaxyService (MapsGalaxy_39Service) . (...) - C:\Program Files\MAPSGA~2\bar\1.bin\39barsvc.exe (.not file.)   =>Adware.MapsGalaxy
[MD5.00000000000000000000000000000000] [APT] [At1] (...) -- C:\DOCUME~1\admin\APPLIC~1\DSite\UPDATE~1\UPDATE~1.exe (.not file.)   [0]    => DSite - Update
O42 - Logiciel: QuotationCafe - (.QuotationCafe.) [HKLM] -- QuotationCafe_45bar Uninstall
O42 - Logiciel: MapsGalaxy Toolbar - (.Mindspark Interactive Network.) [HKLM] -- MapsGalaxy_39bar Uninstall   =>Adware.MapsGalaxy
[HKCU\Software\Yahoo]   =>Toolbar.Yahoo
[HKCU\Software\QuotationCafe_45]
[HKCU\Software\yahooinstall]   =>Toolbar.Yahoo
[HKLM\Software\TelevisionFanaticEI]   =>PUP.TelevisionFanatic
[HKLM\Software\QuotationCafe_45]
[HKLM\Software\Yahoo]   =>Toolbar.Yahoo
O43 - CFD: 5/5/2013 - 3:53:10 AM - [0.261] ----D C:\Program Files\SearchSettings   =>Adware.SearchSettings
O43 - CFD: 1/1/2004 - 4:07:55 AM - [3.862] ----D C:\Program Files\QuotationCafe_45
O43 - CFD: 1/1/2004 - 12:09:13 AM - [5.850] ----D C:\Program Files\Yahoo!   =>Toolbar.Yahoo
O43 - CFD: 1/1/2004 - 12:08:58 AM - [0.045] ----D C:\Documents and Settings\admin\Application Data\Yahoo!   =>Toolbar.Yahoo
O47 - AAKE:Key Export SP - "C:\Documents and Settings\admin\Desktop\New Folder (2)\tally9\tally9.exe" [Enabled] .(...) -- C:\Documents and Settings\admin\Desktop\New Folder (2)\tally9\tally9.exe (.not file.)    => Fichier absent
O53 - SMSR:HKLM\...\startupreg\MapsGalaxy Search Scope Monitor  [Key] . (...) -- C:\Program Files\MAPSGA~2\bar\1.bin\39srchmn.exe (.not file.)   =>Adware.MapsGalaxy
O53 - SMSR:HKLM\...\startupreg\MapsGalaxy_39 Browser Plugin Loader  [Key] . (...) -- C:\Program Files\MAPSGA~2\bar\1.bin\39brmon.exe (.not file.)   =>Adware.MapsGalaxy
O53 - SMSR:HKLM\...\startupreg\QuotationCafe Search Scope Monitor  [Key] . (.MindSpark - MindSpark Toolbar Platform SearchScope Moni.) -- C:\Program Files\QUOTAT~2\bar\1.bin\45srchmn.exe
O53 - SMSR:HKLM\...\startupreg\QuotationCafe_45 Browser Plugin Loader  [Key] . (.VER_COMPANY_NAME - VER_DESCRIPTION.) -- C:\Program Files\QuotationCafe_45\bar\1.bin\45brmon.exe
O53 - SMSR:HKLM\...\startupreg\Search Settings  [Key] . (.Unknown owner - Search Settings.) -- C:\Program Files\SearchSettings\SearchSettings.exe   =>Adware.SearchSettings
O53 - SMSR:HKLM\...\startupreg\VideoDownloadConverter Search Scope Monitor  [Key] . (...) -- C:\Program Files\VIDEOD~2\bar\1.bin\4zsrchmn.exe (.not file.)   =>Adware.VideoDownloadConverter
O53 - SMSR:HKLM\...\startupreg\VideoDownloadConverter_4z Browser Plugin Loader  [Key] . (...) -- C:\Program Files\VIDEOD~2\bar\1.bin\4zbrmon.exe (.not file.)   =>Adware.VideoDownloadConverter
O64 - Services: CurCS - 1/1/2004 - C:\Program Files\QuotationCafe_45\bar\1.bin\45barsvc.exe (QuotationCafe_45Service)  .(.COMPANYVERS_NAME - PRODUCTVERS_TITLE.) - LEGACY_QUOTATIONCAFE_45SERVICE
O64 - Services: CurCS - 12/30/1899 - Unknown owner (MapsGalaxy_39Service)  .(...) - LEGACY_MAPSGALAXY_39SERVICE   =>Adware.MapsGalaxy
O69 - SBI: SearchScopes [HKCU] {3329E87E-A95F-457D-A40D-5A53C2B2F614} - (Yahoo!Search) - https://in.search.yahoo.com   =>Toolbar.Yahoo
O69 - SBI: SearchScopes [HKCU] {58B970FE-515F-4984-965F-9D389B7AED4E} - (Yahoo! Search) - https://search.yahoo.com   =>Toolbar.Yahoo
O69 - SBI: SearchScopes [HKCU] {5941bc46-57ca-4649-8c07-aef5f99313f2} [DefaultScope] - (My Web Search) - https://search.mywebsearch.com   =>Adware.MyWebSearch
O69 - SBI: SearchScopes [HKCU] {6A1806CD-94D4-4689-BA73-E35EA1EA9990} - (@ieframe.dll,-12512) - https://www.bing.com    => bing.com
SS - | Auto 1/1/2004 42504 |  (QuotationCafe_45Service) . (.COMPANYVERS_NAME.) - C:\Program Files\QuotationCafe_45\bar\1.bin\45barsvc.exe
SS - | Auto  0 |  (MapsGalaxy_39Service) . (...) - C:\Program Files\MAPSGA~2\bar\1.bin\39barsvc.exe   =>Adware.MapsGalaxy
[HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{71C1D63A-C944-428A-A5BD-BA513190E5D2}]   =>Adware.MapsGalaxy^
[HKLM\SYSTEM\CurrentControlSet\Services\MapsGalaxy_39Service]   =>Adware.MapsGalaxy^
[HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\MapsGalaxy_39bar Uninstall]   =>Adware.MapsGalaxy^
[HKLM\Software\Microsoft\Shared Tools\MSConfig\startupreg\MapsGalaxy Search Scope Monitor]   =>Adware.MapsGalaxy^
[HKLM\Software\Microsoft\Shared Tools\MSConfig\startupreg\MapsGalaxy_39 Browser Plugin Loader]   =>Adware.MapsGalaxy^
[HKLM\Software\Microsoft\Shared Tools\MSConfig\startupreg\Search Settings]   =>Adware.SearchSettings^
[HKLM\Software\Microsoft\Shared Tools\MSConfig\startupreg\VideoDownloadConverter Search Scope Monitor]   =>Adware.VideoDownloadConverter^
[HKLM\Software\Microsoft\Shared Tools\MSConfig\startupreg\VideoDownloadConverter_4z Browser Plugin Loader]   =>Adware.VideoDownloadConverter^
[HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\VDC_is1]   =>Adware.VideoDownloadConverter
[HKCU\Software\VideoDownloadConverter_4z]   =>Adware.VideoDownloadConverter
[HKLM\Software\VideoDownloadConverter_4z]   =>Adware.VideoDownloadConverter
[HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{8E5E2654-AD2D-48bf-AC2D-D17F00898D06}]   =>Toolbar.Avast
[HKLM\Software\Microsoft\Internet Explorer\Toolbar]:{364ea597-e728-4ce4-bb4a-ed846ef47970}   =>Adware.MapsGalaxy^
C:\Program Files\SearchSettings   =>Adware.SearchSettings^
C:\Program Files\Yahoo!   =>Toolbar.Yahoo^
C:\Documents and Settings\admin\Application Data\Yahoo!   =>Toolbar.Yahoo^
C:\Program Files\Video Download Converter   =>Adware.VideoDownloadConverter
C:\Program Files\MapsGalaxy_39\bar\1.bin\39bar.dll   =>Adware.MapsGalaxy^
C:\Program Files\VideoDownloadConverter_4z\bar\1.bin\4zbar.dll   =>Adware.VideoDownloadConverter^
[HKCU\Software\Yahoo]   =>Toolbar.Yahoo^
[HKCU\Software\yahooinstall]   =>Toolbar.Yahoo^
[HKLM\Software\Yahoo]   =>Toolbar.Yahoo^
C:\Program Files\SearchSettings\SearchSettings.exe   =>Adware.SearchSettings^
C:\Program Files\MAPSGA~2\bar\1.bin\39barsvc.exe   =>Adware.MapsGalaxy^
EmptyCLSID
Emptytemp
Sysrestore
Mises à  jour à  effectuer =>
---\\ Web Browser
MSIE: Internet Explorer v7.0.5730.13 => Microsoft Internet Explorer Updates↓ // en IE8, via Windows UpDate
GCIE: Google Chrome v28.0.1500.72 (Defaut) => Google Inc
---\\ Software Update
Adobe Flash Player 11 Plugin => Adobe Systems // Contrôler la version en V:11.8.800.94
Java 7 Update 21 => Oracle // en V:7u25
Liens de téléchargement =>
Adobe Flash Player
https://get.adobe.com/fr/flashplayer/
V11.8.800.94
Décocher avant le téléchargement => Mc Afee Security Scan Plus
Nota => Pour Windows 8, c'est une KB, qui fait la mise à  jour
Java
https://www.oracle.com/technetwork/java/ ... index.html
Java Runtime Environnement--->JRE -> 7u25
***********Le point avec => Java // Oracle *************
...Java Runtime Environnement---> 7u25 à  droite
Cclique sur JRE > Download à  droite.
Coche Accept License Agreement dans la nouvelle page.
Clique sur Windows x86 Offline - 30,25 MB -imagejre-7u25-windows-i586.exe
ou pour la version 64 Bits
Windows x64 Offline - 31,61 MB - jre-7u25-windows-x64.exe
Installe le fichier téléchargé.
Désinstalle toutes les autres versions existantes si présentes sur ton pc dans => Ajout/Suppression de programmes ou => Programmes et fonctionnalités selon le système.
Nota=> Si votre votre navigateur IE est en 64Bits prenez le lien donné en 64bits
Quand cela est fait, reviens avec le rapport de ZHPFix :)
par Elise
#6153
Bonjout Evasion,
merci bcp pour ta rapidite, superman serait jaloux ;)
Voici le rapport ZHPfix
Rapport de ZHPFix 2013.7.20.5 par Nicolas Coolman, Update du 20/07/2013
Fichier d'export Registre :
Run by admin at 1/1/2004 3:33:23 AM
High Elevated Privileges : OK
Windows XP Professional Service Pack 3 (Build 2600)
Recycle Files Deleted
========== Software ==========
DELETED QuotationCafe
DELETED MapsGalaxy Toolbar
========== Memory Process ==========
DELETED Memory Process: C:\Program Files\QuotationCafe_45\bar\1.bin\45SrchMn.exe
========== Registry Key ==========
DELETED [HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\QuotationCafe_45bar Uninstall]
DELETED [HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MapsGalaxy_39bar Uninstall]
DELETED Key: Mozilla Plugin: @FromDocToPDF_65.com/Plugin
DELETED Key: Mozilla Plugin: @QuotationCafe_45.com/Plugin
DELETED Key: Mozilla Plugin: @VideoDownloadConverter_4z.com/Plugin
DELETED Key: CLSID BHO: {1e91a655-bb4b-4693-a05e-2edebc4c9d89}
DELETED Key: CLSID: [HKLM\SOFTWARE\Classes\CLSID\{1e91a655-bb4b-4693-a05e-2edebc4c9d89}]
DELETED Key: CLSID BHO: {8561f2a1-d885-4852-8289-81ae4ad0ad99}
DELETED Key: CLSID: [HKLM\SOFTWARE\Classes\CLSID\{8561f2a1-d885-4852-8289-81ae4ad0ad99}]
DELETED Key: CLSID BHO: {63E60077-EDE9-427a-BAD0-2ED15FADA0A8}
DELETED Key: CLSID: [HKLM\SOFTWARE\Classes\CLSID\{63E60077-EDE9-427a-BAD0-2ED15FADA0A8}]
DELETED Key: CLSID BHO: {71c1d63a-c944-428a-a5bd-ba513190e5d2}
DELETED Key: CLSID: [HKLM\SOFTWARE\Classes\CLSID\{71c1d63a-c944-428a-a5bd-ba513190e5d2}]
DELETED Key: CLSID BHO: {8619595f-4eef-4164-b040-fb7436301a06}
DELETED Key: CLSID: [HKLM\SOFTWARE\Classes\CLSID\{8619595f-4eef-4164-b040-fb7436301a06}]
DELETED Key: CLSID BHO: {a235e1e3-6296-4710-af39-104a7faa6c7c}
DELETED Key: CLSID: [HKLM\SOFTWARE\Classes\CLSID\{a235e1e3-6296-4710-af39-104a7faa6c7c}]
DELETED Key: CLSID BHO: {f236ca79-3123-4afb-9f74-e98117ad5625}
DELETED Key: CLSID: [HKLM\SOFTWARE\Classes\CLSID\{f236ca79-3123-4afb-9f74-e98117ad5625}]
DELETED Key: CLSID: [HKLM\SOFTWARE\Classes\CLSID\{99bced2f-1db3-4ecd-8e35-8906428a6cfe}]
DELETED Key: CLSID: [HKLM\SOFTWARE\Classes\CLSID\{364ea597-e728-4ce4-bb4a-ed846ef47970}]
DELETED Key: CLSID: [HKLM\SOFTWARE\Classes\CLSID\{48586425-6bb7-4f51-8dc6-38c88e3ebb58}]
DELETED Key: CLSID: [HKLM\SOFTWARE\Classes\CLSID\{01E04581-4EEE-11D0-BFE9-00AA005B4383}]
DELETED Key: CLSID: [HKLM\SOFTWARE\Classes\CLSID\{0E5CBF21-D15F-11D0-8301-00AA005B4383}]
DELETED Key: CLSID: [HKLM\SOFTWARE\Classes\CLSID\{EE5D279F-081B-4404-994D-C6B60AAEBA6D}]
DELETED Key: CLSID: [HKLM\SOFTWARE\Classes\CLSID\{F2CF5485-4E02-4F68-819C-B92DE9277049}]
DELETED Key: Service: FromDocToPDF_65Service
DELETED Key: Service: QuotationCafe_45Service
DELETED Key: Service: MapsGalaxy_39Service
DELETED Key: HKCU\Software\Yahoo
DELETED Key: HKCU\Software\QuotationCafe_45
DELETED Key: HKCU\Software\yahooinstall
DELETED Key: HKLM\Software\TelevisionFanaticEI
DELETED Key: HKLM\Software\QuotationCafe_45
DELETED Key: HKLM\Software\Yahoo
DELETED Key: StartupReg: MapsGalaxy Search Scope Monitor
DELETED Key: StartupReg: MapsGalaxy_39 Browser Plugin Loader
DELETED Key: StartupReg: QuotationCafe Search Scope Monitor
DELETED Key: StartupReg: QuotationCafe_45 Browser Plugin Loader
DELETED Key: StartupReg: Search Settings
DELETED Key: StartupReg: VideoDownloadConverter Search Scope Monitor
DELETED Key: StartupReg: VideoDownloadConverter_4z Browser Plugin Loader
DELETED Key: Service Legacy: LEGACY_QUOTATIONCAFE_45SERVICE
DELETED Key: Service Legacy: LEGACY_MAPSGALAXY_39SERVICE
DELETED Key: SearchScopes :{3329E87E-A95F-457D-A40D-5A53C2B2F614}
DELETED Key: SearchScopes :{58B970FE-515F-4984-965F-9D389B7AED4E}
DELETED Key: SearchScopes :{5941bc46-57ca-4649-8c07-aef5f99313f2}
DELETED Key: SearchScopes :{6A1806CD-94D4-4689-BA73-E35EA1EA9990}
NOT FOUND Key: Service: QuotationCafe_45Service
NOT FOUND Key: Service: MapsGalaxy_39Service
NOT FOUND Key: HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{71C1D63A-C944-428A-A5BD-BA513190E5D2}
NOT FOUND Key: HKLM\SYSTEM\CurrentControlSet\Services\MapsGalaxy_39Service
NOT FOUND Key: HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\MapsGalaxy_39bar Uninstall
NOT FOUND Key: HKLM\Software\Microsoft\Shared Tools\MSConfig\startupreg\MapsGalaxy Search Scope Monitor
NOT FOUND Key: HKLM\Software\Microsoft\Shared Tools\MSConfig\startupreg\MapsGalaxy_39 Browser Plugin Loader
NOT FOUND Key: HKLM\Software\Microsoft\Shared Tools\MSConfig\startupreg\Search Settings
NOT FOUND Key: HKLM\Software\Microsoft\Shared Tools\MSConfig\startupreg\VideoDownloadConverter Search Scope Monitor
NOT FOUND Key: HKLM\Software\Microsoft\Shared Tools\MSConfig\startupreg\VideoDownloadConverter_4z Browser Plugin Loader
DELETED Key: HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\VDC_is1
DELETED Key: HKCU\Software\VideoDownloadConverter_4z
DELETED Key: HKLM\Software\VideoDownloadConverter_4z
DELETED Key: HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{8E5E2654-AD2D-48bf-AC2D-D17F00898D06}
NOT FOUND Key: HKCU\Software\Yahoo
NOT FOUND Key: HKCU\Software\yahooinstall
NOT FOUND Key: HKLM\Software\Yahoo
========== Registry Value ==========
DELETED Toolbar: {99bced2f-1db3-4ecd-8e35-8906428a6cfe}
DELETED Toolbar: {364ea597-e728-4ce4-bb4a-ed846ef47970}
DELETED Toolbar: {48586425-6bb7-4f51-8dc6-38c88e3ebb58}
DELETED Toolbar: {01E04581-4EEE-11D0-BFE9-00AA005B4383}
DELETED Toolbar: {0E5CBF21-D15F-11D0-8301-00AA005B4383}
DELETED Toolbar: {EE5D279F-081B-4404-994D-C6B60AAEBA6D}
DELETED Toolbar: {F2CF5485-4E02-4F68-819C-B92DE9277049}
DELETED Toolbar: {61628E2A-4FF9-4454-992D-D92A8CD27399}
DELETED RunValue: FromDocToPDF Search Scope Monitor
DELETED RunValue: QuotationCafe Search Scope Monitor
DELETED RunValue: FromDocToPDF_65 Browser Plugin Loader
DELETED AAKE KeyValue: C:\Documents and Settings\admin\Desktop\New Folder (2)\tally9\tally9.exe
NOT FOUND [HKLM\Software\Microsoft\Internet Explorer\Toolbar]:{364ea597-e728-4ce4-bb4a-ed846ef47970}
========== Repertory ==========
No Empty CLSID Directories
DELETED Window Temporary
DELETED Flash Cookies
========== File ==========
DELETED File***: c:\program files\quotationcafe_45\bar\1.bin\45srchmn.exe
NOT FOUND File: c:\program files\fromdoctopdf_65\bar\1.bin\np65stub.dll
DELETED File: c:\program files\quotationcafe_45\bar\1.bin\np45stub.dll
NOT FOUND File: c:\program files\videodownloadconverter_4z\bar\1.bin\np4zstub.dll
NOT FOUND File: c:\progra~1\mapsga~2\bar\1.bin\39bar.dll
DELETE on Reboot c:\program files\quotationcafe_45\bar\1.bin\45srcas.dll
DELETED File: c:\program files\discovery tools\ietb.dll
NOT FOUND File: c:\program files\mapsgalaxy_39\bar\1.bin\39srcas.dll
DELETE on Reboot c:\program files\quotationcafe_45\bar\1.bin\45bar.dll
NOT FOUND File: c:\progra~1\fromdo~2\bar\1.bin\65bar.dll
NOT FOUND File: c:\program files\fromdoctopdf_65\bar\1.bin\65srcas.dll
NOT FOUND File: c:\program files\mapsgalaxy_39\bar\1.bin\39bar.dll
NOT FOUND File: c:\program files\videodownloadconverter_4z\bar\1.bin\4zbar.dll
NOT FOUND File: c:\program files\fromdo~2\bar\1.bin\65srchmn.exe
NOT FOUND File: c:\program files\quotationcafe_45\bar\1.bin\45srchmn.exe
NOT FOUND File: c:\program files\fromdo~2\bar\1.bin\65brmon.exe
DELETED File: c:\documents and settings\admin\desktop\shortcut to annual update b &dc.lnk
NOT FOUND File: i:\annual update b &dc.doc (.not file.)
DELETED File: c:\documents and settings\admin\desktop\shortcut to mis- data.lnk
DELETED File: c:\documents and settings\admin\desktop\shortcut to scrap.lnk
NOT FOUND File: d:\sponcership letter\july-2013\scrap.shs (.not file.)
NOT FOUND File: c:\program files\fromdo~2\bar\1.bin\65barsvc.exe
DELETED File: c:\program files\quotationcafe_45\bar\1.bin\45barsvc.exe
NOT FOUND File: c:\program files\mapsga~2\bar\1.bin\39barsvc.exe
NOT FOUND File: c:\documents and settings\admin\desktop\new folder (2)\tally9\tally9.exe
NOT FOUND File: c:\program files\mapsga~2\bar\1.bin\39srchmn.exe
NOT FOUND File: c:\program files\mapsga~2\bar\1.bin\39brmon.exe
NOT FOUND File: c:\program files\quotat~2\bar\1.bin\45srchmn.exe
NOT FOUND File: c:\program files\quotationcafe_45\bar\1.bin\45brmon.exe
NOT FOUND File: c:\program files\searchsettings\searchsettings.exe
NOT FOUND File: c:\program files\videod~2\bar\1.bin\4zsrchmn.exe
NOT FOUND File: c:\program files\videod~2\bar\1.bin\4zbrmon.exe
NOT FOUND File: c:\program files\quotationcafe_45\bar\1.bin\45barsvc.exe
NOT FOUND Folder/File: c:\program files\searchsettings
NOT FOUND Folder/File: c:\program files\yahoo!
NOT FOUND Folder/File: c:\documents and settings\admin\application data\yahoo!
NOT FOUND Folder/File: c:\program files\mapsgalaxy_39\bar\1.bin\39bar.dll
NOT FOUND Folder/File: c:\program files\videodownloadconverter_4z\bar\1.bin\4zbar.dll
NOT FOUND Folder/File: c:\program files\searchsettings\searchsettings.exe
NOT FOUND Folder/File: c:\program files\mapsga~2\bar\1.bin\39barsvc.exe
========== Task ==========
DELETED Task: At1
========== Restoration ==========
Restore System Point created succefully
========== Summary ==========
1 : Memory Process
65 : Registry Key
13 : Registry Value
3 : Repertory
42 : File
2 : Software
1 : Task
1 : Restoration
End of clean in 41mn AMs
========== Report File ==========
C:\ZHP\ZHPFix[R1].txt - 1/1/2004 3:33:24 AM [9402]
Pour les mises a jour, ce n'est pas encore ca. Impossible de charger la page de telechargement d'IE8. Pour chrome il dit qu'il est a jour automatiquement (ce qui inclu adobe flashplayer). Impossible de mettre a jour adobeflash player sur le stupide IE, il bloque meme quand je lui dis de debloquer. *cough*Mais quelle idee d'utiliser IE aussi*cough*.
Et pour java, l'ordi concerne est en 32 bits... j'ai essaye avec la version 64 bits, mais il refuse de l'ouvrir.
par Evasion60
#6171
Ok, avec le correctif :bravo1:
Pour les mises a jour, ce n'est pas encore ca. Impossible de charger la page de telechargement d'IE8 // cela se fait avec Windows Update la mise à  jour de IE
Pour chrome il dit qu'il est a jour automatiquement (ce qui inclu adobe flashplayer) // Oui, Chrome inclus dans ses mises à  jour Flash-Player
Impossible de mettre a jour adobeflash player sur le stupide IE // il y a une procédure bien précise à  effectuer pour charger Flash-Player // Applique là  STP (à  un moment il te demande de quitter IE, pour terminer la mise à  jour)
Et pour java, l'ordi concerne est en 32 bits... j'ai essaye avec la version 64 bits, mais il refuse de l'ouvrir. // Si l'ordi est en 32bits, pourquoi tu essaies la 64bits :hein:
Passe se scanner =>
  • Clic sur Démarrer
Reviens dans ta réponse avec son rapport ;)
par Elise
#6187
Bonjour :)
Merci pour les reponses.
J'ai essaye de telecharger Eset online scanneur mais c'est mission impossible, aucune de mes pages ne chargent (about:blank qui charge qui charge et qui charge jusqu'a ce qu'il me dise 'this webpage is unavailable'), que je tente de le faire a partir de ton lien, sur le site d'eset directement ou encore a partir de 'comment ca marche'.
Y a t'il un autre moyen de telecharger le logiciel ?
Merci bien et bonne journee (bientot le week eeeeend)
(je continue d'essayer de telecharger en attendant)
par Evasion60
#6189
Aucun problème pour télécharger esetsmartinstaller_fr.com !
J'ai essayé avec IE10 & FireFox22
par Elise
#6199
Ca ne marche toujours pas, je pense que le probleme vient de la connexion. Je suis en Inde, et parfois c'est meme difficile d'avoir acces a ma messagerie.
Ou d'autres trucs etranges, par exemple pour acceder a ce site, je dois desactiver l'antivirus.
Je sais qu'il ne faut rien telecharger sur des sites sur softonic ou 01.net, connais-tu des solutions alternatives ?
par Evasion60
#6202
:hello: Re Elise
Bien non, j'ai pas d'autre alternative, puisque c'est justement sur une page Web que tu vas mettre à  jour sa base virale, puis scanner :(
Autres choses ?
Sinon j'envoie la fin de désinfection
