Ok, on passe au script, avant dernière étape si tous ce passe bien
Avant ça il faut que tu désactive AVAST !
Aide pour le désactiver ici :
https://www.sosvirus.net/depannages-informatique/viewtopic.php?f ... 3510#p3510
- Copie les lignes ci dessous :
Code : Tout sélectionnerSysRestore
M2 - MFEP: prefs.js [arv_000 - [ofr2][opt]rs0\{33e0daa6-3af3-d8b5-6752-10e949c61516}] [] ComplitlyEngine - Speed up your search with your personal search suggestions tool v1.1 (..)
O2 - BHO: (no name) [64Bits] - {318A227B-5E9F-45bd-8999-7F8F10CA4CF5} Clé orpheline
O3 - Toolbar: (no name) [64Bits] - [HKLM]{318A227B-5E9F-45bd-8999-7F8F10CA4CF5} Clé orpheline
O4 - HKLM\..\Run: [SynTPEnh] C:\Program Files (x86)\Synaptics\SynTP\SynTPEnh.exe (.not file.)
O4 - HKCU\..\Run: [AdobeBridge] Clé orpheline
O4 - HKLM\..\Wow6432Node\Run: [Wondershare Helper Compact] C:\Program Files (x86)\Common Files\Wondershare\Wondershare Helper Compact\WSHelper.exe (.not file.)
O4 - HKUS\S-1-5-21-3118297187-1878732117-1511279401-1003\..\Run: [AdobeBridge] Clé orpheline
[MD5.14739B9810A47332D81AE72A29ECCAAE] [APT] [AutoKMS] (...) -- C:\Windows\AutoKMS\AutoKMS.exe
[MD5.00000000000000000000000000000000] [APT] [MirageAgent] (...) -- C:\Program Files (x86)\CyberLink\YouCam\YCMMirage.exe (.not file.)
[HKCU\Software\Norton]
[HKCU\Software\Symantec]
[HKLM\Software\DomaIQ]
[HKLM\Software\Norton]
[HKLM\Software\Wow6432Node\Symantec]
O43 - CFD: 02/05/2013 - 19:03:13 - [15,309] ----D C:\Program Files (x86)\Norton Internet Security
O43 - CFD: 02/05/2013 - 17:59:31 - [1,825] ----D C:\ProgramData\Norton
O43 - CFD: 04/10/2012 - 15:43:50 - [23,863] ----D C:\ProgramData\NortonInstaller
C:\Users\arv_000\Downloads\Adobe Photoshop 7.0\Adobe photoshop 7.0 keygen.Exe
C:\Users\arv_000\Downloads\Adobe Photoshop 7.0\bs-phot7\keygen.Exe
C:\Users\arv_000\Downloads\Adobe.InDesign.CS6.Multi.Inc.Serial-X-FORCE-MDZ\Cle\xf-mccs6.zip
C:\Users\arv_000\Downloads\Adobe.Photoshop.Lightroom.v5.0.Multilingual.Incl.Keymaker-CORE\Adobe.Photoshop.Lightroom.v5.0.x64.Multilingual.Incl.Keymaker-CORE\CORE10k.EXE
C:\Users\arv_000\Downloads\Adobe.Photoshop.Lightroom.v5.0.Multilingual.Incl.Keymaker-CORE\Adobe.Photoshop.Lightroom.v5.0.x86.Multilingual.Incl.Keymaker-CORE\CORE10k.EXE
C:\Users\arv_000\Downloads\Daemon.Tools.Pro.Advanced.v5.1.0.333.Multilingual.Cracked.6000th.Release-BRD\Crack\Patch.exe
C:\Users\arv_000\Downloads\Patch Adobe CS6 - MPT\adobe.cs6.all.products.activator.(x32.y.x64)_up01-MPT.exe
C:\Users\arv_000\Downloads\Wondershare Video Converter Ultimate v6.5.1.2 + Patch\Patch.exe
C:\Users\arv_000\Downloads\Wondershare.mobilego.for.android.3.3.1.231\wondershare.mobilego.for.android.3.3.1_patch.exe
[HKLM\Software\Google\Chrome\Extensions\kaankaoacjlcnkdfagcnnncmeojkoeai]
[HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\29799DE249E7DBC459FC6C8F07EB8375]
[HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\0238BBE24EA3A70408B81E4BB89C15E5]
[HKLM\Software\Wow6432Node\Google\Chrome\Extensions\nbmafkdmkkckhggblphicnnhlgljnoje]
[HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{318A227B-5E9F-45BD-8999-7F8F10CA4CF5}]
[HKLM\Software\Classes\CLSID\{318A227B-5E9F-45BD-8999-7F8F10CA4CF5}]
[HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{318A227B-5E9F-45BD-8999-7F8F10CA4CF5}]
[HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{8E5E2654-AD2D-48bf-AC2D-D17F00898D06}]
[HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{8E5E2654-AD2D-48bf-AC2D-D17F00898D06}]
[HKLM\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{8E5E2654-AD2D-48bf-AC2D-D17F00898D06}]
C:\Users\arv_000\AppData\Roaming\Mozilla\Firefox\Profiles\[ofr2][opt]rs0\{33e0daa6-3af3-d8b5-6752-10e949c61516}
C:\Users\arv_000\AppData\Local\Google\Chrome\User Data\Default\Extensions\kaankaoacjlcnkdfagcnnncmeojkoeai
FirewallRaz
PROXYFix
HOSTFix
Emptytemp
- Lances ZHPFix, exécuter en tant qu'administrateur sous Windows : 7/8 et Vista
- Dans ZHPFix clic sur l'îcone : "coller le presse-papier"
- Puis Clic sur "GO"
- Confirmes les nettoyages des données en cliquant sur "Oui"
- Une fois le scan terminé rends toi sur le bureau, le fichier ZHPFixReport à été crée.
- Héberge le rapport ZHPFixReport sur SosUpload, puis copie/colle le lien fourni dans ta prochaine réponse.
