par H.A.W.X
#6238
Poste moi les rapports de RogueKiller stp.
SysRestore
R0 - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = about:blank
O2 - BHO: (no name) [64Bits] - AutorunsDisabled Clé orpheline
O41 - Driver:  (cmdHlp) . (. - .) - C:\Windows\System32\DRIVERS\cmdhlp.sys (.not file.)
O3 - Toolbar\WebBrowser: (no name) [64Bits] - [HKCU]{71576546-354D-41C9-AAE8-31F2EC22BF0D} Clé orpheline
M0 - MFSP: prefs.js [Paulo - 90o4hpkm.default] https://fr.yahoo.com  =>Toolbar.Yahoo
R0 - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = https://fr.yahoo.com  =>Toolbar.Yahoo
O61 - LFC: 02/08/2013 - 20:22:28 ---A- C:\Users\Paulo\AppData\Local\Comodo\Dragon\User Data\Default\Extensions\cmaiofennmphjldldcpphcechfnnohja\1.1.0.61_0\js\yahoo.js   [225]  =>Toolbar.Yahoo
O61 - LFC: 02/08/2013 - 20:25:29 ---A- C:\Users\Paulo\AppData\Local\Comodo\Dragon\User Data\Default\Extensions\cmaiofennmphjldldcpphcechfnnohja\1.1.0.78_0\js\yahoo.js   [225]  =>Toolbar.Yahoo
O61 - LFC: 02/08/2013 - 20:25:30 ---A- C:\Users\Paulo\AppData\Local\Comodo\Dragon\User Data\Default\Extensions\cmaiofennmphjldldcpphcechfnnohja\1.1.0.78_0\config\yahoo.js   [25060]  =>Toolbar.Yahoo
O69 - SBI: SearchScopes [HKCU] {8EEAC88A-079B-4b2c-80C1-7836F79EB40A} [DefaultScope] - (Yahoo! Search) - https://fr.search.yahoo.com  =>Toolbar.Yahoo
C:\Users\Paulo\AppData\Local\Comodo\Dragon\User Data\Default\Extensions\cmaiofennmphjldldcpphcechfnnohja\1.1.0.61_0\js\yahoo.js   [225]   =>Toolbar.Yahoo^
C:\Users\Paulo\AppData\Local\Comodo\Dragon\User Data\Default\Extensions\cmaiofennmphjldldcpphcechfnnohja\1.1.0.78_0\js\yahoo.js   [225]   =>Toolbar.Yahoo^
C:\Users\Paulo\AppData\Local\Comodo\Dragon\User Data\Default\Extensions\cmaiofennmphjldldcpphcechfnnohja\1.1.0.78_0\config\yahoo.js   [25060]   =>Toolbar.Yahoo^
FirewallRaz
PROXYFix
Emptytemp
    1. Dans ZHPFix clic sur l'îcone : "coller le presse-papier"
    2. Puis Clic sur "GO"
par H.A.W.X
#6254
Ok, il me semblait bien pour RK qu'il avait trouvé pas mal de choses.
Attention plusieurs étape, ne te mélange pas les pinceaux, lit bien ;)
1.
  • Clique sur Scan.
  • Clique sur Host RAZ.
  • Une fois le scan terminé rends toi sur le bureau, le rapport RKreport[X]¤H¤.txt à  été créé.
  • Héberge le rapport RKreport[X]¤H¤.txt sur Sosupload, puis copie/colle le lien fourni dans ta prochaine réponse sur le forum
2.
  • Choisi l'option Suppression
A voir => Tutoriel complet
3.
  • Choisi l'option Recherche
  • Copie et Colle le contenu du rapport qui apparaît à  la fin du scan.
J'attends donc 3 rapports
par teddy
#6255
:hello: il y a 1 soucis avec roguekiller, après le préscan,il n'y a que les touches scan et racc RAZ qui sont disponibles, le carré DRV est rouge
alors qu'il devrait être vert.
En plus mon touchpad ne fonctionne plus, je l'ai désinstallé, il aurait du s'installer de nouveau et fonctionner;ce n'est pas le cas
Cordialement
par H.A.W.X
#6256
Tout est écrit dans les consignes, il est écrit d'abords d'appuyer sur Scan et ensuite ....
H.A.W.X a écrit :1.
  • Clique sur Scan.
2.
3.
par teddy
#6257
Re https://cjoint.com/index.php pour roguekiller
Adwcleaner
# AdwCleaner v2.306 - Rapport créé le 03/08/2013 à  14:57:34
# Mis à  jour le 19/07/2013 par Xplode
# Nom d'utilisateur : Paulo - PAUL-PC
# Mode de démarrage : Normal
# Exécuté depuis : C:\Users\Jeep\Desktop\adwcleaner.exe
# Option [Suppression]
***** [Services] *****
Dossier Supprimé : C:\Users\Jeep\AppData\Roaming\Mozilla\Firefox\Profiles\senbpkc9.default\jetpack
***** [Registre] *****
***** [Navigateurs] *****
-\\ Internet Explorer v10.0.9200.16635
-\\ Mozilla Firefox v22.0 (fr)
Fichier : C:\Users\Paulo\AppData\Roaming\Mozilla\Firefox\Profiles\90o4hpkm.default\prefs.js
Fichier : C:\Users\Jeep\AppData\Roaming\Mozilla\Firefox\Profiles\senbpkc9.default\prefs.js
Supprimée : user_pref("extensions.ghostery.bugs", "{\"copyright\":\"This proprietary database is protected by co[...]
Supprimée : user_pref("extensions.ghostery.lsos", "{\"copyright\":\"This proprietary database is protected by co[...]
AdwCleaner[S2].txt - [1203 octets] - [03/08/2013 14:57:35]
########## EOF - \AdwCleaner[S2].txt - [1263 octets] ##########
et voici le3ème
# AdwCleaner v2.306 - Rapport créé le 03/08/2013 à  15:19:25
# Option [Recherche]
Dossier Présent : C:\Users\Jeep\AppData\Roaming\Mozilla\Firefox\Profiles\senbpkc9.default\jetpack
Présente : user_pref("extensions.ghostery.bugs", "{\"copyright\":\"This proprietary database is protected by co[...]
Présente : user_pref("extensions.ghostery.lsos", "{\"copyright\":\"This proprietary database is protected by co[...]
AdwCleaner[R2].txt - [1198 octets] - [03/08/2013 15:19:25]
AdwCleaner[S2].txt - [1330 octets] - [03/08/2013 14:57:35]
########## EOF - \AdwCleaner[R2].txt - [1318 octets] ##########
Je pensais qu"il fallait clicker scan et de suite hosts RAZ siffle
Bonne réception et merci pour ton aide et pour ta patience :merci:
